【光学】基于matlab GUI菲涅尔系数计算【含Matlab源码 1165期】
海神之光 发表于 2022/05/29 00:49:25 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【光学】基于matlab GUI菲涅尔系数计算【含Matlab源码 1165期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、菲涅尔系数计算简介
基于matlab GUI菲涅尔系数计算:通过平面波反射系数演示,解释不儒斯特角,展示垂直极化系数与水平极化系数的幅度和相位关系。
三、部分源代码
function varargout = Fresnel(varargin)
% FRESNEL MATLAB code for Fresnel.fig
%      FRESNEL, by itself, creates a new FRESNEL or raises the existing
%      singleton*.
%      H = FRESNEL returns the handle to a new FRESNEL or the handle to
%      FRESNEL('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in FRESNEL.M with the given input arguments.
%      FRESNEL('Property','Value',...) creates a new FRESNEL or raises the
%      applied to the GUI before Fresnel_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to Fresnel_OpeningFcn via varargin.
% Edit the above text to modify the response to help Fresnel
% Last Modified by GUIDE v2.5 28-May-2021 12:02:27
gui_Singleton = 1;
                   'gui_OpeningFcn', @Fresnel_OpeningFcn, ...
                   'gui_OutputFcn',  @Fresnel_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before Fresnel is made visible.
function Fresnel_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to Fresnel (see VARARGIN)
% Choose default command line output for Fresnel
set(handles.uipanel11,'Visible','off');
set(handles.uipanel7,'Visible','on');
set(handles.uipanel8,'Visible','on');
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes Fresnel wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = Fresnel_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in radiobutton_Rs.
function radiobutton_Rs_Callback(hObject, eventdata, handles)
% hObject    handle to radiobutton_Rs (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of radiobutton_Rs
% --- Executes on button press in radiobutton2.
function radiobutton2_Callback(hObject, eventdata, handles)
% hObject    handle to radiobutton2 (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of radiobutton2
% --- Executes on button press in radiobutton3.
function radiobutton3_Callback(hObject, eventdata, handles)
% hObject    handle to radiobutton3 (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of radiobutton3
% --- Executes on button press in radiobutton4.
function radiobutton4_Callback(hObject, eventdata, handles)
% hObject    handle to radiobutton4 (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of radiobutton4
% --- Executes on button press in radiobutton5.
function radiobutton5_Callback(hObject, eventdata, handles)
% hObject    handle to radiobutton5 (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of radiobutton5
% --- Executes on button press in radiobutton6.
function radiobutton6_Callback(hObject, eventdata, handles)
% hObject    handle to radiobutton6 (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of radiobutton6
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
n1 = str2double(get(handles.edit_n1,'String'));
n2 = str2double(get(handles.edit_n2,'String'));
if isnan(n1)
    errordlg('Input must be a number','Error');
end
if isnan(n2)
end
Incidence = pi/2;%入射角范围
d = 0.1*pi/180;
xx = 0:d:Incidence;%入射角
%画图的横坐标
X = xx.*180/pi;
Transmission = asin((n1*sin(xx))./n2);%透射角
[ver,hor] = find((n1*sin(xx))./n2 > 1);%大于全反射角置零
Transmission(ver,hor) = 0;
%选择输出参数
line_rs = get(handles.radiobutton_rrs,'Value');
line_rp = get(handles.radiobutton_rp,'Value');
line_ts = get(handles.radiobutton_ts,'Value');
line_tp = get(handles.radiobutton_tp,'Value');
line_ps = get(handles.radiobutton_ps,'Value');
line_Ts = get(handles.radiobutton_Ts,'Value');
line_Tp = get(handles.radiobutton_Tp,'Value');
line_pp = get(handles.radiobutton_pp,'Value');
line_Tn = get(handles.radiobutton_Tn,'Value');
line_pn = get(handles.radiobutton_pn,'Value');
%计算透反射系数
rs = -sin(xx - Transmission)./sin(xx + Transmission);
ts = 2*sin(Transmission).*cos(xx)./sin(xx + Transmission);
rp = tan(xx - Transmission)./tan(xx + Transmission);
tp = 2*sin(Transmission).*cos(xx)./(sin(xx + Transmission).*cos(xx - Transmission));
%计算透反射比
ps = rs.*rs;
Ts = n2.*cosd(Transmission)./(n1.*cosd(xx)).*ts.*ts;
pp = rp.*rp;
Tp = n2.*cosd(Transmission)./(n1.*cosd(xx)).*tp.*tp;
%选择光波类型
Model = get(handles.popupmenu_model,'Value');%1为线偏光,2为自然光
if Model == 1 %线偏光
    %绘图
    %透、反射系数部分
    axes(handles.axes1);
    if line_rs == 1
        plot(X,rs,'color','r');
        hold on
    end
    if line_ts == 1
        plot(X,ts,'color','m');
        hold on
    end
    if line_rp == 1
        plot(X,rp,'color','g');
        hold on
    end
    if line_tp == 1
        plot(X,tp,'color','c');
    end
    hold off
    %透、反射比部分
    axes(handles.axes2);
    if line_ps == 1
        plot(X,ps,'b');
        hold on
    end
    if line_Ts == 1
        plot(X,Ts,'y');
        hold on
    end
    if line_pp == 1
        plot(X,pp,'r');
    end
    if line_Tp == 1
        plot(X,Tp,'g');
    end
    hold off
else%自然光
    cla reset
    %set(handles.axes1,'Visible','off')
    pn = (ps + pp)./2;
    Tn = 1 - pn;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 门云阁.MATLAB物理计算与可视化[M].清华大学出版社,2013.
原文链接:qq912100926.blog.csdn.net/article/details/119251303
