【通信】基于matlab GUI循环编码译码【含Matlab源码 1348期】
海神之光 发表于 2022/05/28 23:55:30 2022/05/28
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【通信】基于matlab GUI循环编码译码【含Matlab源码 1348期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得**1*份代码(有效期为订阅日起,三天内有效);
二、循环码简介
1 循环码概念
循环性是指任意码组循环移位后仍然是该编码中的一个码组
多项式表示法
一般情况
2 循环码的运算
2.1 整数的按模运算
2.2 码多项式的按模运算
2.3 循环码的数学表示法
2.4 循环码的生成
2.5 寻求码生成多项式
三、部分源代码
function varargout = co_decode(varargin)
% CO_DECODE M-file for co_decode.fig
%      CO_DECODE, by itself, creates a new CO_DECODE or raises the existing
%      singleton*.
%      H = CO_DECODE returns the handle to a new CO_DECODE or the handle to
%      CO_DECODE('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in CO_DECODE.M with the given input arguments.
%      CO_DECODE('Property','Value',...) creates a new CO_DECODE or raises the
%      applied to the GUI before co_decode_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to co_decode_OpeningFcn via varargin.
% Edit the above text to modify the response to help co_decode
% Last Modified by GUIDE v2.5 02-Oct-2021 13:13:12
gui_Singleton = 1;
                   'gui_OpeningFcn', @co_decode_OpeningFcn, ...
                   'gui_OutputFcn',  @co_decode_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before co_decode is made visible.
function co_decode_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to co_decode (see VARARGIN)
% Choose default command line output for co_decode
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes co_decode wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = co_decode_OutputFcn(hObject, eventdata, handles)
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
% --- Executes during object creation, after setting all properties.
function edit1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
function edit2_Callback(hObject, eventdata, handles)
% hObject    handle to edit2 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit2 as text
%        str2double(get(hObject,'String')) returns contents of edit2 as a double
function edit2_CreateFcn(hObject, eventdata, handles)
end
function edit3_Callback(hObject, eventdata, handles)
% hObject    handle to edit3 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit3 as text
%        str2double(get(hObject,'String')) returns contents of edit3 as a double
function edit3_CreateFcn(hObject, eventdata, handles)
end
function edit4_Callback(hObject, eventdata, handles)
% hObject    handle to edit4 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit4 as text
%        str2double(get(hObject,'String')) returns contents of edit4 as a double
function edit4_CreateFcn(hObject, eventdata, handles)
end
function edit5_Callback(hObject, eventdata, handles)
% hObject    handle to edit5 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit5 as text
%        str2double(get(hObject,'String')) returns contents of edit5 as a double
function edit5_CreateFcn(hObject, eventdata, handles)
end
function edit6_Callback(hObject, eventdata, handles)
% hObject    handle to edit6 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit6 as text
%        str2double(get(hObject,'String')) returns contents of edit6 as a double
function edit6_CreateFcn(hObject, eventdata, handles)
end
function edit7_Callback(hObject, eventdata, handles)
% hObject    handle to edit7 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit7 as text
%        str2double(get(hObject,'String')) returns contents of edit7 as a double
function edit7_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on button press in pushbutton2.
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%循环码编码%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
function pushbutton2_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton2 (see GCBO)
global C1; %%编码生成序列
global gx; %%输入的生成多项式序列
n=get(handles.edit1,'string');
n=str2num(n);
k=get(handles.edit2,'string');
k=str2num(k);
g=get(handles.edit3,'string');
r=n-k;
gx=zeros(1,r+1);
for i=1:r+1
    gx(i)=str2num(g(i));
end
mm=get(handles.edit4,'string');
m=zeros(1,k);
for i=1:k
   m(i)=str2num(mm(i));
end
%=========================调用Code_Fun编码函数=============================%
C1=Code_Fun( n,k, gx,m);
C=mat2str(C1);
for i=1:7
    X(i)=C(2*i);
end
set(handles.edit5,'string',X);
axes(handles.axes2);
stem(C1,'LineWidth',2.5);title('循环编码生成序列');
% --- Executes on button press in pushbutton5.
function pushbutton5_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton5 (see GCBO)
global C1;
global R;
n=str2num(n);
[R,E]= Erros( n,C1 );
E1=mat2str(E); %将数值转换为字符串
R1=mat2str(R);
for i=1:n
    E2(i)=E1(2*i); %去掉字符串中的【】符号
end
for i=1:n
    R2(i)=R1(2*i);
end
set(handles.edit8,'string',E2);
set(handles.edit9,'string',R2);
% --- Executes on button press in pushbutton3.
%==============================梅吉特译码==================================%
function pushbutton3_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton3 (see GCBO)
global R;
n=str2num(n);
k=str2num(k);
%=============================调用译码函数=================================%
RC=Decode_Fun(n,R );
C=mat2str(RC);
for i=1:n
    X(i)=C(2*i);
end
set(handles.edit7,'string',X);
axes(handles.axes4);
M=zeros(1,k);
for i=1:k
    M(i)=RC(i);
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
  • 276
  • 277
  • 278
  • 279
  • 280
  • 281
  • 282
  • 283
  • 284
  • 285
  • 286
  • 287
  • 288
  • 289
  • 290
  • 291
  • 292
  • 293
  • 294
  • 295
  • 296
  • 297
  • 298
  • 299
  • 300
  • 301
  • 302
  • 303
  • 304
  • 305
  • 306
  • 307
  • 308
  • 309
  • 310
  • 311
  • 312
  • 313
  • 314
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
原文链接:qq912100926.blog.csdn.net/article/details/120585465
