【RGB检测】基于matlab GUI图像RGB检测【含Matlab源码 088期】
海神之光 发表于 2022/05/29 00:26:24 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【RGB检测】基于matlab GUI图像RGB检测【含Matlab源码 088期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得2份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = Color_Detect(varargin)
% COLOR_DETECT MATLAB code for Color_Detect.fig
%      COLOR_DETECT, by itself, creates a new COLOR_DETECT or raises the existing
%      singleton*.
%      H = COLOR_DETECT returns the handle to a new COLOR_DETECT or the handle to
%      COLOR_DETECT('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in COLOR_DETECT.M with the given input arguments.
%      COLOR_DETECT('Property','Value',...) creates a new COLOR_DETECT or raises the
%      applied to the GUI before Color_Detect_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to Color_Detect_OpeningFcn via varargin.
% Edit the above text to modify the response to help Color_Detect
% Last Modified by GUIDE v2.5 22-Jul-2021 12:54:19
gui_Singleton = 1;
                   'gui_OpeningFcn', @Color_Detect_OpeningFcn, ...
                   'gui_OutputFcn',  @Color_Detect_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before Color_Detect is made visible.
function Color_Detect_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to Color_Detect (see VARARGIN)
% Choose default command line output for Color_Detect
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
set(handles.axes1,'Visible','off');
set(handles.axes2,'Visible','off');
set(handles.uipanel1,'visible','off');
set(handles.uipanel2,'visible','off');
set(handles.start,'Enable','off');
set(handles.snap,'Enable','off');
set(handles.oi,'visible','off');
set(handles.dc,'visible','off');
set(handles.uipanel3,'visible','off');
set(handles.startv,'enable','off');
set(handles.text,'enable','off');
set(handles.set,'enable','off');
set(handles.pop,'enable','off');
set(handles.text5,'visible','off');
% UIWAIT makes Color_Detect wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = Color_Detect_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in image.
function image_Callback(hObject, eventdata, handles)
% hObject    handle to image (see GCBO)
set(handles.uipanel1,'visible','on');
set(handles.video,'Enable','off');
% --- Executes on button press in video.
function video_Callback(hObject, eventdata, handles)
% hObject    handle to video (see GCBO)
set(handles.image,'Enable','off');
set(handles.text,'enable','on');
set(handles.pop,'enable','on');
% --- Executes on button press in start.
function start_Callback(hObject, eventdata, handles)
% hObject    handle to start (see GCBO)
im=handles.im; x=handles.x;
switch x
    case 1
        axes(handles.axes2); cla;
        im=handles.im;
r=im(:,:,1); g=im(:,:,2); b=im(:,:,3);
diff=imsubtract(r,rgb2gray(im));
 bw=im2bw(diff,0.18);
 area=bwareaopen(bw,300);
 rm=immultiply(area,r);  gm=g.*0;  bm=b.*0;
 image=cat(3,rm,gm,bm);
 imshow(image);
 % Transparcy part
  %[m n p]=size(im);
    % mask=ones(m,n);
     %i=find(image(:,:,1)==0);
    % mask(i)=.9; % Change Transparacy
     %imshow(im);
     %hold on
     %h=imshow(image);
     %set(h,'AlphaData',mask);
 case 2
        im=handles.im;
diff=imsubtract(g,rgb2gray(im));
 gm=immultiply(area,g);  rm=r.*0;  bm=b.*0;
 imshow(image);
 case 3
        im=handles.im;
diff=imsubtract(b,rgb2gray(im));
 bm=immultiply(area,b);  gm=g.*0;  rm=r.*0;
 imshow(image);
 end
 set(handles.dc,'visible','on');
% --- Executes on button press in red.
function red_Callback(hObject, eventdata, handles)
% hObject    handle to red (see GCBO)
handles.x=1;
guidata(hObject,handles);
set(handles.start,'enable','on');
% --- Executes on button press in green.
function green_Callback(hObject, eventdata, handles)
% hObject    handle to green (see GCBO)
handles.x=2;
% --- Executes on button press in blue.
function blue_Callback(hObject, eventdata, handles)
% hObject    handle to blue (see GCBO)
handles.x=3;
% --- Executes on button press in camera.
function camera_Callback(hObject, eventdata, handles)
% hObject    handle to camera (see GCBO)
imaqreset
info= imaqhwinfo;
name = char(info.InstalledAdaptors(end));
c_info = imaqhwinfo(name);
id = c_info.DeviceInfo.DeviceID(end);
format = char(c_info.DeviceInfo.SupportedFormats(end));
handles.vid= videoinput(name, id, format);
axes(handles.axes1);cla;
h = waitbar(0,'Please wait...');
steps = 200;
for step = 1:steps
    % computations take place here
    waitbar(step / steps)
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
原文链接:qq912100926.blog.csdn.net/article/details/120585276
