【优化算法】粒子群优化模拟器【含Matlab源码 1553期】
海神之光 发表于 2022/05/29 02:29:36 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【优化算法】粒子群优化模拟器【含Matlab源码 1553期】 二、部分源代码 function varargout = main(var...
一、获取代码方式
获取代码方式1:
二、部分源代码
function varargout = main(varargin)
% MAIN MATLAB code for main.fig
%      MAIN, by itself, creates a new MAIN or raises the existing
%      singleton*.
%      H = MAIN returns the handle to a new MAIN or the handle to
%      MAIN('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in MAIN.M with the given input arguments.
%      MAIN('Property','Value',...) creates a new MAIN or raises the
%      applied to the GUI before main_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to main_OpeningFcn via varargin.
% Edit the above text to modify the response to help main
% Last Modified by GUIDE v2.5 29-Jan-2021 18:29:42
gui_Singleton = 1;
                   'gui_OpeningFcn', @main_OpeningFcn, ...
                   'gui_OutputFcn',  @main_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before main is made visible.
function main_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to main (see VARARGIN)
% Choose default command line output for main
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes main wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = main_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in about_button.
function about_button_Callback(hObject, eventdata, handles)
% hObject    handle to about_button (see GCBO)
about;
% --- Executes on button press in close_button.
function close_button_Callback(hObject, eventdata, handles)
% hObject    handle to close_button (see GCBO)
clearvars -global;
clear all;
close all;
% --- Executes on selection change in fun_selector.
function fun_selector_Callback(hObject, eventdata, handles)
% hObject    handle to fun_selector (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns fun_selector contents as cell array
%        contents{get(hObject,'Value')} returns selected item from fun_selector
% --- Executes during object creation, after setting all properties.
function fun_selector_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
global FUN;
% Hint: popupmenu controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
% --- Executes on button press in plot_button.
function plot_button_Callback(hObject, eventdata, handles)
% hObject    handle to plot_button (see GCBO)
global FUN;
% Searching for the selected function
fun_val = get(handles.fun_selector,'Value');
if(fun_val <= 12), [FUN.z, FUN.xy_lim, FUN.n] = pso_eval(fun_val);
else    % Custom
    pso_customGUI;
    uiwait(pso_customGUI);
end
% Updating the ROI info
set(handles.ROI_lim1,'String',num2str(FUN.xy_lim(1)));
set(handles.ROI_lim2,'String',num2str(FUN.xy_lim(2)));
% Plotting the graphs
ezmesh(handles.function_graph, FUN.z, FUN.xy_lim, FUN.n);
axis(handles.function_graph, 'square');
xlabel(handles.function_graph, 'x');
ylabel(handles.function_graph, 'y');
zlabel(handles.function_graph, 'z');
title(handles.function_graph, '');
rotate3d(handles.function_graph);
ezcontour(handles.contour_graph, FUN.z, FUN.xy_lim, FUN.n);
axis(handles.contour_graph, 'square');
xlabel(handles.contour_graph, 'x');
ylabel(handles.contour_graph, 'y');
title(handles.contour_graph, '');
function pop_size_Callback(hObject, eventdata, handles)
% hObject    handle to pop_size (see GCBO)
% Hints: get(hObject,'String') returns contents of pop_size as text
%        str2double(get(hObject,'String')) returns contents of pop_size as a double
function pop_size_CreateFcn(hObject, eventdata, handles)
% Hint: edit controls usually have a white background on Windows.
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
原文链接:qq912100926.blog.csdn.net/article/details/121604744
