【细胞分割】基于matlab GUI原子力显微镜图像分析【含Matlab源码 1371期】
海神之光 发表于 2022/05/29 00:42:24 2022/05/29
【摘要】 一、AFM简介 理论知识参考文献:原子力显微镜(AFM)图像的计算机辅助分析 二、部分源代码 function varargout = AFManalysis(varargin) % AFMANAL...
一、AFM简介
二、部分源代码
% AFMANALYSIS M-file for AFManalysis.fig
%      AFMANALYSIS, by itself, creates a new AFMANALYSIS or raises the existing
%      singleton*.
%      H = AFMANALYSIS returns the handle to a new AFMANALYSIS or the handle to
%      AFMANALYSIS('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in AFMANALYSIS.M with the given input arguments.
%      AFMANALYSIS('Property','Value',...) creates a new AFMANALYSIS or raises the
%      applied to the GUI before AFManalysis_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to AFManalysis_OpeningFcn via varargin.
% Edit the above text to modify the response to help AFManalysis
% Last Modified by GUIDE v2.5 07-Dec-2010 22:56:55
gui_Singleton = 1;
                   'gui_OpeningFcn', @AFManalysis_OpeningFcn, ...
                   'gui_OutputFcn',  @AFManalysis_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before AFManalysis is made visible.
function AFManalysis_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to AFManalysis (see VARARGIN)
% Choose default command line output for AFManalysis
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes AFManalysis wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = AFManalysis_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbuttonBrowse.
function pushbuttonBrowse_Callback(hObject, eventdata, handles)
[FileName,PathName] = uigetfile('*.jpg','Select the image file');
if PathName ~= 0    %if user not select cancel
addpath(PathName);  %add path to file search
imagearray = imread(FileName);
handles.imagesize = size(imagearray);
axes(handles.Image);
imshow(imagearray,'InitialMagnification','fit');
%handles.imagegray = rgb2gray(imagearray);
handles.imagearray = imagearray;
end
% hObject    handle to pushbuttonBrowse (see GCBO)
% --- Executes during object creation, after setting all properties.
function Image_CreateFcn(hObject, eventdata, handles)
handles.Image= hObject;
imshow('square.png');
% hObject    handle to Image (see GCBO)
% handles    empty - handles not created until after all CreateFcns called
% Hint: place code in OpeningFcn to populate Image
% --- Executes on slider movement.
function sliderimthreshhold_Callback(hObject, eventdata, handles)
s = handles.imagesize;
handles.slidervalth = get(handles.sliderth,'Value');
handles.imagebin = im2bw(handles.imagearray, 1-handles.slidervalth);
handles.imagebin = bwareaopen(handles.imagebin, round(s(1,1)*handles.slidervalfilter));
bouparam = str2num(get(handles.boundrypara,'string'));
h = fspecial('gaussian',bouparam,bouparam);
handles.imagebin = imfilter(handles.imagebin,h);
handles.imageedge = edge(handles.imagebin);
imagewithboundry = handles.imagearray;
for i = 1:1:s(1,1)
    for j = 1:1:s(1,2)
        if handles.imageedge(i,j) == 1
            imagewithboundry(i,j,:)= 0;
        end
    end
end
%imagewithboundry = imadd(handles.imagearray(:,:,1), handles.imageedge);
imshow(imagewithboundry,'InitialMagnification','fit');
[L, num] = bwlabel(handles.imagebin);
area = bwarea(handles.imagebin)/num;
dia  = ((area*6)/pi)^(1/3);
dianm = dia*(str2num(get(handles.imagesizenm,'string'))/s(1,1));
num = num2str(num);
set(handles.npno,'string',num)
areanm = (pi/6)*((dianm)^3);
areanm = num2str(areanm);
set(handles.nparea,'string',area)
dianm = num2str(dianm);
set(handles.npdia,'string',dianm)
% hObject    handle to sliderimthreshhold (see GCBO)
% Hints: get(hObject,'Value') returns position of slider
%        get(hObject,'Min') and get(hObject,'Max') to determine range of slider
function sliderimthreshhold_CreateFcn(hObject, eventdata, handles)
handles.sliderth = hObject;
%handles.imagebin = im2bw(handles.image,0);
% Hint: slider controls usually have a light gray background.
if isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor',[.9 .9 .9]);
end
function sliderremovesmallpatch_Callback(hObject, eventdata, handles)
handles.slidervalfilter = get(handles.sliderremovesmallpatch,'Value');
%handles.imagebin = im2bw(handles.imagearray, 1-handles.slidervalth);
handles.imagebin2 = bwareaopen(handles.imagebin, round(s(1,1)*handles.slidervalfilter));
handles.imageedge = edge(handles.imagebin2);
for i = 1:1:s(1,1)
    for j = 1:1:s(1,2)
        end
    end
end
[L, num] = bwlabel(handles.imagebin2);
num = num2str(num);
% hObject    handle to sliderremovesmallpatch (see GCBO)
function sliderremovesmallpatch_CreateFcn(hObject, eventdata, handles)
handles.sliderremovesmallpatch = hObject;
handles.slidervalfilter = 0;
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]赵勇,方宗德,庞辉,王侃伟.基于量子粒子群优化算法的最小交叉熵多阈值图像分割[J].计算机应用研究. 2008,(04)
[6]王轶文,谢建明,张惠,孙啸,陆祖宏.原子力显微镜(AFM)图像的计算机辅助分析[J].山东生物医学工程. 2002,(03)
原文链接:qq912100926.blog.csdn.net/article/details/120635454
