【图像分割】基于matlab超像素SFFCM图像分割【含Matlab源码 1374期】
海神之光 发表于 2022/05/29 00:21:18 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源: 【图像分割】基于matlab超像素SFFCM图像分割【含Matlab源码 1374期】 获取代码方式2: 通过紫极神光博客主页开通CSDN...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过紫极神光博客主页开通CSDN年度会员,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、图像分割简介
理论知识参考:【基础教程】基于matlab图像处理图像分割【含Matlab源码 191期】
三、部分源代码
clear all
close all
cluster=2;
f_ori=imread('113044.jpg');
% Note that you can repeat the program for several times to obtain the best
% segmentation result for image '12003.jpg'
%% generate superpixels
%SFFCM only needs a minimal structuring element for MMGR, we usually set SE=2 or SE=3 for
%MMGR.
SE=3;
L1=w_MMGR_WT(f_ori,SE);
L2=imdilate(L1,strel('square',2));
[~,~,Num,centerLab]=Label_image(f_ori,L2);
%% fast FCM
Label=w_super_fcm(L2,centerLab,Num,cluster);
Lseg=Label_image(f_ori,Label);
figure,imshow(Lseg);
function varargout = colorspace(Conversion,varargin)
%Ó¦ÓÃ˵Ã÷£ºf2=colorspace('HSV<-RGB',f);f2ΪÊä³ö£¬fΪÊäÈë,¡®HSV<-RGB¡¯±íʾ´ÓRGB²ÊÉ«¿Õ¼äת»»µ½HSV²ÊÉ«¿Õ¼ä
%COLORSPACE  Convert a color image between color representations.
%   B = COLORSPACE(S,A) converts the color representation of image A
%   where S is a string specifying the conversion.  S tells the
%   source and destination color spaces, S = 'dest<-src', or
%   alternatively, S = 'src->dest'.  Supported color spaces are
%     'RGB'              R'G'B' Red Green Blue (ITU-R BT.709 gamma-corrected)
%     'YPbPr'            Luma (ITU-R BT.601) + Chroma
%     'YCbCr'/'YCC'      Luma + Chroma ("digitized" version of Y'PbPr)
%     'YUV'              NTSC PAL Y'UV Luma + Chroma
%     'YIQ'              NTSC Y'IQ Luma + Chroma
%     'YDbDr'            SECAM Y'DbDr Luma + Chroma
%     'JPEGYCbCr'        JPEG-Y'CbCr Luma + Chroma
%     'HSV'/'HSB'        Hue Saturation Value/Brightness
%     'HSL'/'HLS'/'HSI'  Hue Saturation Luminance/Intensity
%     'XYZ'              CIE XYZ
%     'Lab'              CIE L*a*b* (CIELAB)
%     'Luv'              CIE L*u*v* (CIELUV)
%     'Lch'              CIE L*ch (CIELCH)
%  All conversions assume 2 degree observer and D65 illuminant.  Color
%  space names are case insensitive.  When R'G'B' is the source or
%  destination, it can be omitted. For example 'yuv<-' is short for
%  'yuv<-rgb'.
%  MATLAB uses two standard data formats for R'G'B': double data with
%  intensities in the range 0 to 1, and uint8 data with integer-valued
%  intensities from 0 to 255.  As MATLAB's native datatype, double data is
%  the natural choice, and the R'G'B' format used by colorspace.  However,
%  for memory and computational performance, some functions also operate
%  with uint8 R'G'B'.  Given uint8 R'G'B' color data, colorspace will
%  first cast it to double R'G'B' before processing.
%  If A is an Mx3 array, like a colormap, B will also have size Mx3.
%  [B1,B2,B3] = COLORSPACE(S,A) specifies separate output channels.
%  COLORSPACE(S,A1,A2,A3) specifies separate input channels.
% Pascal Getreuer 2005-2006
%%% Input parsing %%%
if nargin < 2, error('Not enough input arguments.'); end
[SrcSpace,DestSpace] = parse(Conversion);
if nargin == 2
   Image = varargin{1};
elseif nargin >= 3
   Image = cat(3,varargin{:});
else
   error('Invalid number of input arguments.');
end
FlipDims = (size(Image,3) == 1);
if FlipDims, Image = permute(Image,[1,3,2]); end
if ~isa(Image,'double'), Image = double(Image)/255; end
if size(Image,3) ~= 3, error('Invalid input size.'); end
SrcT = gettransform(SrcSpace);
DestT = gettransform(DestSpace);
if ~ischar(SrcT) & ~ischar(DestT)
   % Both source and destination transforms are affine, so they
   % can be composed into one affine operation
   T = [DestT(:,1:3)*SrcT(:,1:3),DestT(:,1:3)*SrcT(:,4)+DestT(:,4)];
   Temp = zeros(size(Image));
   Temp(:,:,1) = T(1)*Image(:,:,1) + T(4)*Image(:,:,2) + T(7)*Image(:,:,3) + T(10);
   Temp(:,:,2) = T(2)*Image(:,:,1) + T(5)*Image(:,:,2) + T(8)*Image(:,:,3) + T(11);
   Temp(:,:,3) = T(3)*Image(:,:,1) + T(6)*Image(:,:,2) + T(9)*Image(:,:,3) + T(12);
   Image = Temp;
elseif ~ischar(DestT)
   Image = rgb(Image,SrcSpace);
   Temp(:,:,1) = DestT(1)*Image(:,:,1) + DestT(4)*Image(:,:,2) + DestT(7)*Image(:,:,3) + DestT(10);
   Temp(:,:,2) = DestT(2)*Image(:,:,1) + DestT(5)*Image(:,:,2) + DestT(8)*Image(:,:,3) + DestT(11);
   Temp(:,:,3) = DestT(3)*Image(:,:,1) + DestT(6)*Image(:,:,2) + DestT(9)*Image(:,:,3) + DestT(12);
   Image = Temp;
else
   Image = feval(DestT,Image,SrcSpace);
end
%%% Output format %%%
if nargout > 1
   varargout = {Image(:,:,1),Image(:,:,2),Image(:,:,3)};
else
   varargout = {Image};
end
return;
function [SrcSpace,DestSpace] = parse(Str)
% Parse conversion argument
if isstr(Str)
   Str = lower(strrep(strrep(Str,'-',''),' ',''));
   k = find(Str == '>');
   if length(k) == 1         % Interpret the form 'src->dest'
      SrcSpace = Str(1:k-1);
      DestSpace = Str(k+1:end);
   else
      k = find(Str == '<');
      if length(k) == 1      % Interpret the form 'dest<-src'
         DestSpace = Str(1:k-1);
         SrcSpace = Str(k+1:end);
      else
         error(['Invalid conversion, ''',Str,'''.']);
      end
   end
   SrcSpace = alias(SrcSpace);
   DestSpace = alias(DestSpace);
else
   SrcSpace = 1;             % No source pre-transform
   DestSpace = Conversion;
   if any(size(Conversion) ~= 3), error('Transformation matrix must be 3x3.'); end
end
return;
function Space = alias(Space)
Space = strrep(Space,'cie','');
if isempty(Space)
   Space = 'rgb';
end
switch Space
case {'ycbcr','ycc'}
   Space = 'ycbcr';
case {'hsv','hsb'}
   Space = 'hsv';
case {'hsl','hsi','hls'}
   Space = 'hsl';
case {'rgb','yuv','yiq','ydbdr','ycbcr','jpegycbcr','xyz','lab','luv','lch'}
   return;
end
return;
function T = gettransform(Space)
% Get a colorspace transform: either a matrix describing an affine transform,
% or a string referring to a conversion subroutine
switch Space
case 'ypbpr'
   T = [0.299,0.587,0.114,0;-0.1687367,-0.331264,0.5,0;0.5,-0.418688,-0.081312,0];
case 'yuv'
   % R'G'B' to NTSC/PAL YUV
   T = [0.299,0.587,0.114,0;-0.147,-0.289,0.436,0;0.615,-0.515,-0.100,0];
case 'ydbdr'
   % R'G'B' to SECAM YDbDr
   T = [0.299,0.587,0.114,0;-0.450,-0.883,1.333,0;-1.333,1.116,0.217,0];
case 'yiq'
   % R'G'B' in [0,1] to NTSC YIQ in [0,1];[-0.595716,0.595716];[-0.522591,0.522591];
   T = [0.299,0.587,0.114,0;0.595716,-0.274453,-0.321263,0;0.211456,-0.522591,0.311135,0];
case 'ycbcr'
   % R'G'B' (range [0,1]) to ITU-R BRT.601 (CCIR 601) Y'CbCr
   % Poynton, Equation 3, scaling of R'G'B to Y'PbPr conversion
   T = [65.481,128.553,24.966,16;-37.797,-74.203,112.0,128;112.0,-93.786,-18.214,128];
case 'jpegycbcr'
   T = [0.299,0.587,0.114,0;-0.168736,-0.331264,0.5,0.5;0.5,-0.418688,-0.081312,0.5]*255;
case {'rgb','xyz','hsv','hsl','lab','luv','lch'}
   T = Space;
otherwise
   error(['Unknown color space, ''',Space,'''.']);
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]赵勇,方宗德,庞辉,王侃伟.基于量子粒子群优化算法的最小交叉熵多阈值图像分割[J].计算机应用研究. 2008,(04)
原文链接:qq912100926.blog.csdn.net/article/details/120635576
