【旗帜识别】基于matlab GUI旗帜识别【含Matlab源码 157期】
海神之光 发表于 2022/05/29 02:20:18 2022/05/29
【摘要】 一、数字图像处理简介 图像处理基础教程链接 1 【基础教程】基于matlab图像处理(表示方法+数据结构+基本格式+类型转换+读取+点运算+代数运算)【含Matlab源码 834期】 2 【基础教程】基...
一、数字图像处理简介
图像处理基础教程链接
2 【基础教程】基于matlab图像处理(读写+显示+运算+转换+变换+增强+滤波+分析+统计)【含Matlab源码 144期】
3 【基础教程】基于matlab图像增强+复原+分割【含Matlab源码 056期】
二、部分源代码
function varargout = flash_card(varargin)
% FLASH_CARD MATLAB code for flash_card.fig
%      FLASH_CARD, by itself, creates a new FLASH_CARD or raises the existing
%      singleton*.
%      H = FLASH_CARD returns the handle to a new FLASH_CARD or the handle to
%      FLASH_CARD('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in FLASH_CARD.M with the given input arguments.
%      FLASH_CARD('Property','Value',...) creates a new FLASH_CARD or raises the
%      applied to the GUI before flash_card_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to flash_card_OpeningFcn via varargin.
% Edit the above text to modify the response to help flash_card
% Last Modified by GUIDE v2.5 09-Mar-2021 14:00:14
gui_Singleton = 1;
                   'gui_OpeningFcn', @flash_card_OpeningFcn, ...
                   'gui_OutputFcn',  @flash_card_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before flash_card is made visible.
function flash_card_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to flash_card (see VARARGIN)
% Choose default command line output for flash_card
handles.output = hObject;
set(handles.hard_prob,'UserData',str2double(get(handles.hard_prob,'string')))
set(handles.medium_prob,'UserData',str2double(get(handles.medium_prob,'string')))
set(handles.easy_prob,'UserData',str2double(get(handles.easy_prob,'string')))
handles.probs=[];
handles.names=[];
handles.D=[];
handles.current_card=[];
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes flash_card wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = flash_card_OutputFcn(hObject, eventdata, handles)
function file_1_Callback(hObject, eventdata, handles)
% hObject    handle to file_1 (see GCBO)
function gen_flash_card_file(d)
if d==0
    msgbox('Please select a valid folder');
    return;
end
dout=dir(d);
fname=sprintf('%s/flash_card.txt',d);
if exist(fname,'file')
    qans=questdlg(sprintf('A list file %s already exists, overwrite?',fname));
    if ~strcmp(qans,'Yes')
       return;
    end
else
    qans=questdlg(sprintf('List file %s doesn''t exist, create?',fname));
        return;
    end
end
fout=fopen(fname,'w');
for fid=1:length(dout)
    fname=dout(fid).name;
    if dout(fid).isdir; continue; end; % skip directories
    fprintf(fout,'%s;%s;1\n',fname,strip(fname));
end
fclose(fout);
msgbox(sprintf('List file flash_card.txt created under %s',d));
function fname=strip(fname)
fname=strrep(fname,'_',' ');
ids=findstr(fname,'.');
if ~isempty(ids)
    fname=fname(1:ids(1)-1);
end
function exit_1_Callback(hObject, eventdata, handles)
% hObject    handle to exit_1 (see GCBO)
close(handles.figure1);
function tool_2_Callback(hObject, eventdata, handles)
% hObject    handle to tool_2 (see GCBO)
function generate_3_Callback(hObject, eventdata, handles)
% hObject    handle to generate_3 (see GCBO)
popupmessage('flash_card_help.txt','Flash Card Help');
function load_1_Callback(hObject, eventdata, handles)
% hObject    handle to load_1 (see GCBO)
d=uigetdir;
if d==0
    disable_buttons(handles);
    disable_menus(handles);
    return;
end
enable_menus(handles);
save_probs(hObject, handles); % save previous probabilities
if ~exist(sprintf('%s/flash_card.txt',d),'file')
    gen_flash_card_file(d);
end
[names,probs]=load_data(d);
if isempty(names)
else
    enable_buttons(handles);
end
handles.names=names;
handles.probs=probs;
handles.D=d;
get_next_card(hObject,handles);
function disable_menus(handles)
set(handles.Untitled_2,'enable','off');
set(handles.Untitled_3,'enable','off');
function enable_menus(handles)
set(handles.Untitled_2,'enable','on');
set(handles.Untitled_3,'enable','on');
function disable_buttons(handles)
set(handles.pushbutton1,'enable','off');
set(handles.pushbutton2,'enable','off');
set(handles.pushbutton3,'enable','off');
set(handles.pushbutton4,'enable','off');
function enable_buttons(handles)
set(handles.pushbutton4,'enable','on');
function [names,probs]=load_data(d)
names=[]; probs=[];
fin=fopen(fname,'r');
if fin <0;
    msgbox(sprintf('Cannot open list file %s',fname));
    return;
end
did=1;
disable_ui;
try
  while 1
    tline=fgetl(fin);
    if ~ischar(tline); break; end;
    sids=strfind(tline,';');
    names(did).fname=tline(1:sids(1)-1);
    names(did).pname=tline(sids(1)+1:sids(2)-1);
    probs(did)=str2double(tline(sids(2)+1:end));
    did=did+1;
  end
catch
    msgbox('flash_card.txt is corrupted. Please regenerate list file from Tool Menu');
    fclose(fin);
    return;
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]陈浩,方勇,朱大洲,王成,陈子龙.基于蚁群算法的玉米植株热红外图像边缘检测[J].农机化研究. 2015,37(06)
原文链接:qq912100926.blog.csdn.net/article/details/120686848
