【优化算法】吉萨金字塔建造优化算法(GPC)【含Matlab源码 1438期】
海神之光 发表于 2022/05/29 02:09:22 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【优化算法】吉萨金字塔建造优化算法(GPC)【含Mat...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【优化算法】吉萨金字塔建造优化算法(GPC)【含Matlab源码 1438期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
% Giza Pyramids Construction (GPC) Algorithm
clc;
clear;
close all;
%% Problem Definition
CostFunction=@(x) Sphere(x);        % Cost Function
nVar=30;                  % Number of Decision Variables
VarSize=[1 nVar];         % Decision Variables Matrix Size
VarMin=-5.12;             % Decision Variables Lower Bound
VarMax= 5.12;             % Decision Variables Upper Bound
%% Giza Pyramids Construction (GPC) Parameters
MaxIteration=1000;   % Maximum Number of Iterations (Days of work)
nPop=20;             % Number of workers
G = 9.8;             % Gravity
Tetha = 14;          % Angle of Ramp
MuMin = 1;           % Minimum Friction
MuMax = 10;          % Maximum Friction
pSS= 0.5;            % Substitution Probability
%% Initialization
% Empty Stones Structure
stone.Position=[];
stone.Cost=[];
% Initialize Population Array
pop=repmat(stone,nPop,1);
% Initialize Best Solution Ever Found
best_worker.Cost=inf;
% Create Initial Stones
for i=1:nPop
   pop(i).Position=unifrnd(VarMin,VarMax,VarSize);
   pop(i).Cost=CostFunction(pop(i).Position);
   if pop(i).Cost<=best_worker.Cost
       best_worker=pop(i);          % as Pharaoh's special agent
   end
end
% Array to Hold Best Cost Values
BestCost=zeros(MaxIteration,1);
%% Giza Pyramids Construction (GPC) Algorithm Main Loop
for it=1:MaxIteration
    newpop=repmat(stone,nPop,1);
    for i=1:nPop
        newpop(i).Cost = inf;
        V0= rand(1,1);                          % Initial Velocity
        Mu= MuMin+(MuMax-MuMin)*rand(1,1);      % Friction
        d = (V0^2)/((2*G)*(sind(Tetha)+(Mu*cosd(Tetha))));                  % Stone Destination
        x = (V0^2)/((2*G)*(sind(Tetha)));                                   % Worker Movement
        epsilon=unifrnd(-((VarMax-VarMin)/2),((VarMax-VarMin)/2),VarSize);  % Epsilon
        newsol.Position = (pop(i).Position+d).*(x*epsilon);                 % Position of Stone and Worker
      % newsol.Position = (pop(i).Position+d)+(x*epsilon);                  % Note: In some cases or some problems use this instead of the previous line to get better results
        newsol.Position=max(newsol.Position,VarMin);
        newsol.Position=min(newsol.Position,VarMax);
        % Substitution
        z=zeros(size(pop(i).Position));
        k0=randi([1 numel(pop(i).Position)]);
        for k=1:numel(pop(i).Position)
            if k==k0 || rand<=pSS
                z(k)=newsol.Position(k);
            else
                z(k)=pop(i).Position(k);
            end
        end
        newsol.Position=z;
        newsol.Cost=CostFunction(newsol.Position);
        if newsol.Cost <= newpop(i).Cost
           newpop(i) = newsol;
           if newpop(i).Cost<=best_worker.Cost
               best_worker=newpop(i);
           end
        end
    end
    % Merge
    pop=[pop
         newpop];  %#ok
    % Sort
    [~, SortOrder]=sort([pop.Cost]);
    pop=pop(SortOrder);
    % Truncate
    pop=pop(1:nPop);
    % Store Best Cost Ever Found
    BestCost(it)=pop(1).Cost;
    % Show Iteration Information
    disp(['It:' num2str(it) ', Cost => ' num2str(BestCost(it))]);
end
figure;
%plot(BestCost,'LineWidth',2);
semilogy(BestCost,'LineWidth',2);
xlabel('Iteration');
ylabel('Best Cost');
%grid on;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
原文链接:qq912100926.blog.csdn.net/article/details/120915065
