【优化算法】缎面弓箭鸟优化(SBO)【含Matlab源码 1432期】
海神之光 发表于 2022/05/29 02:15:27 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【优化算法】缎面弓箭鸟优化(SBO)【含Matlab源...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【优化算法】缎面弓箭鸟优化(SBO)【含Matlab源码 1432期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function SBO
%% This function implements the basic School Based Optimization (SBO) algorithm for 10-bar truss optimization
% For more information about this method and other algorithms check the following papers:
global D
% Specity SBO parameters
Itmax=300;        % Maximum number of iterations
NClass=5;        % Number of classes in the school
PopSize=15;        % Population size of each class
% Optimization problem parameters
D=Data10;        % For truss function evaluate the functio to get the initial parameters
LB=D.LB;        % Lowerbound
UB=D.UB;        % Upperbound
FN='ST10';        % Name of analyzer function
%% Randomely generate initial designs between LB and UB
Cycle=1;
for I=1:PopSize
    for NC=1:NClass
        Designs{NC}(I,:)=LB+rand(1,size(LB,2)).*(UB-LB);                   % Row vector
    end
end
% Analysis the designs
for NC=1:NClass
    [PObj{NC},Obj{NC}]=Analyser(Designs{NC},FN);
    Best{NC}=[];
end
%% SBO loop
for Cycle=2:Itmax
    for NC=1:NClass
        % Identify best designs and keep them
        [Best{NC},Designs{NC},PObj{NC},Obj{NC},WMeanPos{NC}]=Specifier(PObj{NC},Obj{NC},Designs{NC},Best{NC});
        TeachersPObj(NC,1)=Best{NC}.GBest.PObj;
        TeachersDes(NC,:)=Best{NC}.GBest.Design;
    end
    for NC=1:NClass
        % Select a teacher
        SelectedTeacher=TeacherSelector(Best,NC,TeachersPObj);
        % Apply Teaching
        [Designs{NC},PObj{NC},Obj{NC}]=Teaching(LB,UB,Designs{NC},PObj{NC},Obj{NC},TeachersDes(SelectedTeacher,:),WMeanPos{NC},FN);
        % Apply Learning
        [Designs{NC},PObj{NC},Obj{NC}]=Learning(LB,UB,Designs{NC},Obj{NC},PObj{NC},FN);
    end
    % Find best so far solution and Mean
    CumPObj=[];
    for NC=1:NClass
        ClassBestPObj(NC,1)=Best{NC}.GBest.PObj;
        ClassMean(NC,1)=mean(PObj{NC});
        CumPObj=[CumPObj;PObj{NC}];
    end
    [~,b]=min(ClassBestPObj);
    OveralBestPObj=Best{b}.GBest.PObj;
    OveralBestObj=Best{b}.GBest.Obj;
    OveralBestDes=Best{b}.GBest.Design;
    % Plot time history of the best solution vs. iteration and print the
    % results
    hold on;plot(Cycle,Best{b}.GBest.PObj,'b*');xlabel('Iteration');ylabel('Best solution value');pause(0.0001)
    fprintf('Cycle: %6d, Best (Penalized): %6.4f, Objective: %6.4f\n',Cycle,OveralBestPObj,OveralBestObj);
end
Solution.PObj=OveralBestPObj;% Objective value for best non-penalized solution
Solution.Design=OveralBestDes;% Design for best non-penalized solution
%% Save the results
save('SBO_Results.mat','Solution')
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
原文链接:qq912100926.blog.csdn.net/article/details/120917776
