【优化算法】多目标利希滕贝格算法(MOLA)【含Matlab源码 1434期】
海神之光 发表于 2022/05/29 01:02:38 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【优化算法】多目标利希滕贝格算法(MOLA)【含Mat...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【优化算法】多目标利希滕贝格算法(MOLA)【含Matlab源码 1434期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
%              MULTI-OBJECTIVE LICHTENBERG ALGORITHM (MOLA)
close all
clear all
clc
format long
set(0,'DefaultAxesFontName', 'Times New Roman')
set(0,'DefaultAxesFontSize', 14)
set(0,'DefaultTextFontname', 'Times New Roman')
set(0,'DefaultTextFontSize', 26)
% Search Space
LB = zeros(1,10);  %lower bounds
UB = ones(1,10);   %upper bounds
% Optimizator Parameters
pop = 100;         %Population
n_iter = 100;      %Max number os iterations/gerations
ref = 0.4;         %if more than zero, a second LF is created with refinement % the size of the other
IntCon = [];       %Avoid if there are no variables that must be integers. Ex.: IntCon = [1,2];
Np = 100000;       %Number of Particles (If 3D, better more than 10000)
S_c = 1;           %Stick Probability: Percentage of particles that can don´t stuck in the
                   %cluster. Between 0 and 1. Near 0 there are more aggregate, the density of
                   %cluster is bigger and difusity is low. Near 1 is the opposite.
Rc = 150;          %Creation Radius (if 3D, better be less than 80, untill 150)
M = 0;             %If M = 0, no lichtenberg figure is created (it is loaded a optimized figure); if 1, a single is created and used in all iterations; If 2, one is created for each iteration.(creating an LF figure takes about 2 min)
d = length(UB);    %problem dimension
ngrid = 30;        %Number of grids in each dimension
Nr = 100;          %Maximum number of solutions in PF
% MOLA
[x,fval] = LA_optimization(@objectives,d,pop,LB,UB,ref,n_iter,Np,Rc,S_c,M,ngrid,Nr,IntCon,@constraint);
% Figure
figure
plot(fval(:,1),fval(:,2),'ZDataSource','',...
    'MarkerFaceColor',[0 0 1],...
    'MarkerEdgeColor',[0 0 0],...
    'MarkerSize',8,...
    'Marker','o',...
    'LineWidth',1.1,...
    'LineStyle','none',...
    'Color',[0 0 0]);
hold on
box on
legend('PF');
title('Non-dominated Solutions','fontweight','bold');
xlabel('Y_1')
ylabel('Y_2')
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
原文链接:qq912100926.blog.csdn.net/article/details/120917589
