【优化算法】未来搜索优化算法(FSA)【含Matlab源码 1448期】
海神之光 发表于 2022/05/28 23:47:26 2022/05/28
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【优化算法】未来搜索优化算法(FSA)【含Matlab...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【优化算法】未来搜索优化算法(FSA)【含Matlab源码 1448期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
%Future search algorithm for爋ptimization
%Cite this article
clc
clear
n=30;      % Population size
iteration=1000;  % Maximum number of "iterations"
r_time=30; % Number of runtime
d=1000;       % Number of dimensions
% Lower limit/bounds/ a vector
 Lb=-100*ones(1,d);
% Upper limit/bounds/ a vector
 Ub=100*ones(1,d);
for r=1:r_time;
% Initialize the population/solutions
for i=1:n,
  S(i,:)=Lb+(Ub-Lb).*rand(1,d);
  for k=1:d
            if S(i,k)>Ub(k), S(i,k)=Ub(k); end
            if S(i,k)<Lb(k), S(i,k)=Lb(k); end
        end
  Fitness(i)=Fun(S(i,:));
end
% Find the initial best solution
[fmin,I]=min(Fitness);
best=S(I,:);
Lbe=S;
Lbest=Fitness;
%%main global loop
iter=0;                      % Iterations?counter
for t=1:iteration,
    %%main local loop
    for i=1:n,
             S(i,:)=S(i,:)+(-S(i,:)+best)*rand+(-S(i,:)+Lbe(i,:))*rand;
          for k=1:d
        end
     % Evaluate new solutions
           Fnew(i)=Fun(S(i,:));
     % Update the loacal best solution
           if (Fnew(i)<=Lbest(i))
                Lbe(i,:)=S(i,:);
                Lbest(i)=Fnew(i);
           end
          % Update the current global best solution
          if Fnew(i)<=fmin,
                best=S(i,:);
                fmin=Fnew(i);
          end
        end
        % loop of  the initial update
        for i=1:n,
             Si(i,:)=best+(best-Lbe(i,:)).*rand;
        for k=1:d
            if Si(i,k)>Ub(k), Si(i,k)=Ub(k); end
            if Si(i,k)<Lb(k), Si(i,k)=Lb(k); end
        end
             Fitness(i)=Fun(Si(i,:));
             if ( Fitness(i)<=Fnew(i))
                S(i,:)=Si(i,:);
                Lbe(i,:)=Si(i);
             end
       end
        [fmini,I]=min(Fitness);
besti=Si(I,:);
if fmini<=fmin,
                best=besti;
                fmin=fmini;
          end
       iter=iter+1;
       fgbest(iter)=fmin;
       iter_counter(iter)=iter;
end
% Output/display for each runtime
disp(['Number of Iterations: ',num2str(iter)]);
disp(['Best =',num2str(best),' fmin=',num2str(fmin)]);
gbest_r(r,:)=fgbest;
best_r(r,:)=best;
gbest(r)=min(fgbest);
end
[gbestscore,I]=min(gbest);
bestposition=best_r(I,:);
semilogy(gbest_r(I,:),'-r');
disp(['Number of runtime: ',num2str(r)]);
disp(['Best =',num2str(bestposition),' fmin=',num2str(gbestscore)]);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
原文链接:qq912100926.blog.csdn.net/article/details/120937610
