【LMS时间序列预测】基于matlab LMS麦基玻璃时间序列预测【含Matlab源码 1443期】
海神之光 发表于 2022/05/29 02:04:08 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【时间序列预测】基于matlab LMS麦基玻璃时间序...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【时间序列预测】基于matlab LMS麦基玻璃时间序列预测【含Matlab源码 1443期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
%% Mackey Glass Time Series Prediction Using Least Mean Square (LMS)
clc
clear all
close all
%% Loading Time series data
% I generated a series y(t) for t = 0,1, . . . ,3000, using
% mackey glass series equation with the following configurations:
% b = 0.1, a = 0.2, Tau = 20, and the initial conditions y(t - Tau) = 0.
load Dataset\Data.mat
teacher_forcing=1; % recurrent ARMA modelling with forced desired input after defined time steps
%% Training and Testing datasets
% For training
Tr=Data(100:2500,1);    % Selecting a Interval of series data t = 100~2500
Ts=Data(2500:3000,1);   % Selecting a Interval of series data t = 2500~3000
Ys(Ts)=Data(Ts,2);      % Selecting a chuck of series data y(t)
%% LMS Parameters
U=zeros(M+1,1); % Initial values of taps
W=zeros(M+1,1); % Initial weight of LMS
MSE=[];         % Initial mean squared error (MSE)
%% Learning weights of LMS (Training)
tic % start
for t=Tr(1):Tr(end)-time_steps
    U(1:end-1)=U(2:end);    % Shifting of tap window
    if (teacher_forcing==1)
        if rem(t,time_steps)==0 || (t==Tr(1))
            U(end)=Yr(t);           % Input (past/current samples)
        else
            U(end)=Yp(t-1);          % Input (past/current samples)
        end
    else
    end
    Yp(t)=W'*U;                         % Predicted output
    e(t)=Yr(t+time_steps)-Yp(t);        % Error in predicted output
    W=W+eta*e(t)*U;     % Weight update rule of LMS
end
training_time=toc; % total time including training and calculation of MSE
%% Prediction of a next outcome of series using previous samples (Testing)
tic % start
U=U*0;  % Reinitialization of taps (optional)
for t=Ts(1):Ts(end)-time_steps+1
        if rem(t,time_steps)==0 || (t==Ts(1))
            U(end)=Ys(t);           % Input (past/current samples)
        else
        end
    else
    end
    Yp(t)=W'*U;             % Calculating output (future value)
    e(t)=Ys(t+time_steps-1)-Yp(t);        % Error in predicted output
    E(t)=e(t).^2;   % Current mean squared error (MSE)
end
testing_time=toc; % total time including testing and calculation of MSE
%% Results
figure(1)
plot(Tr,10*log10(E(Tr)));   % MSE curve
hold on
plot(Ts(1:end-time_steps+1),10*log10(E(Ts(1:end-time_steps+1))),'r');   % MSE curve
grid minor
title('Cost Function');
xlabel('Iterations (samples)');
ylabel('Mean Squared Error (MSE)');
legend('Training Phase','Test Phase');
figure(2)
hold on
plot(Tr(2*M:end),Yp(Tr(2*M:end))','r')   % Predicted values during training
plot(Ts,Ys(Ts),'--b');        % Actual unseen data
plot(Ts(1:end-time_steps+1),Yp(Ts(1:end-time_steps+1))','--r');  % Predicted values of mackey glass series (testing)
xlabel('Time: t');
ylabel('Output: Y(t)');
title('Mackey Glass Time Series Prediction Using Least Mean Square (LMS)')
ylim([min(Ys)-0.5, max(Ys)+0.5])
legend('Training Phase (desired)','Training Phase (predicted)','Test Phase (desired)','Test Phase (predicted)');
mitr=10*log10(mean(E(Tr)));  % Minimum MSE of training
mits=10*log10(mean(E(Ts(1:end-time_steps+1))));  % Minimum MSE of testing
display(sprintf('Total training time is %.5f, \nTotal testing time is %.5f \nMSE value during training %.3f (dB),\nMSE value during testing %.3f (dB)', ...
training_time,testing_time,mitr,mits));
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
[3]周品.MATLAB 神经网络设计与应用[M].清华大学出版社,2013.
[4]陈明.MATLAB神经网络原理与实例精解[M].清华大学出版社,2013.
[5]方清城.MATLAB R2016a神经网络设计与应用28个案例分析[M].清华大学出版社,2018.
原文链接:qq912100926.blog.csdn.net/article/details/120937902
