【优化算法】梯度优化算法(GBO)【含Matlab源码 1464期】
海神之光 发表于 2022/05/29 00:06:02 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【优化算法】梯度优化算法(GBO)【含Matlab源码...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【优化算法】梯度优化算法(GBO)【含Matlab源码 1464期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
clear
close all
clc
nP=50;          % Number of Population
Func_name='F1'; % Name of the test function, range from F1-F14
MaxIt=500;      % Maximum number of iterations
% Load details of the selected benchmark function
[lb,ub,dim,fobj]=BenchmarkFunctions(Func_name);
[Best_fitness,BestPositions,Convergence_curve] = GBO(nP,MaxIt,lb,ub,dim,fobj);
%% Plots
figure,
hold on
semilogy(Convergence_curve,'Color','b','LineWidth',3);
title('Convergence curve')
xlabel('Iteration');
ylabel('Best fitness obtained so far');
axis tight
grid off
box on
legend('GBO')
%___________________________________________________________________%                                                           %
%  Gradien-Based Optimizer source code (Developed in MATLAB R2017a) %
%  programming: Iman Ahmadianfar                                    %
%         e-Mail: im.ahmadian@gmail.com                             %
%                 i.ahmadianfar@bkatu.ac.ir                         %
% Source codes demo version 1.0
% Main paper (Please refer to the main paper):
% Gradient-Based Optimizer: A New Metaheuristic Optimization Algorithm
% Iman Ahmadianfar, Omid Bozorg-Haddad, Xuefeng Chu
% Information Sciences,2020
% DOI: https://doi.org/10.1016/j.ins.2020.06.037
% https://www.sciencedirect.com/science/article/pii/S0020025520306241
% Website of GBO: http://imanahmadianfar.com/
% You can find and run the GBO code online at http://imanahmadianfar.com/
% You can find the GBO paper at https://doi.org/10.1016/j.ins.2020.06.037
% Please follow the paper for related updates in researchgate: https://www.researchgate.net/profile/Iman_Ahmadianfar
%  Co-author:
%             Omid Bozorg-Haddad(OBHaddad@ut.ac.ir)
%             Xuefeng Chu(xuefeng.chu@ndsu.edu)
% _____________________________________________________
% This function initialize the first population
function X=initialization(nP,dim,ub,lb)
Boundary_no= size(ub,2); % numnber of boundaries
% If the boundaries of all variables are equal and user enter a signle
% number for both ub and lb
if Boundary_no==1
    X=rand(nP,dim).*(ub-lb)+lb;
end
% If each variable has a different lb and ub
if Boundary_no>1
    for i=1:dim
        X(:,i)=rand(nP,1).*(ub(i)-lb(i))+lb(i);
    end
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
[3]施媛波.基于改进的群居蜘蛛优化云计算任务调度算法[J].电脑编程技巧与维护. 2021,(04)
原文链接:qq912100926.blog.csdn.net/article/details/120990380
