【路径规划】基于matlab无线充电车辆路径和速度预测【含Matlab源码 1473期】
海神之光 发表于 2022/05/29 00:40:56 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【路径规划】基于matlab无线充电车辆路径和速度预测【含Matlab源码 1473期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭99.9元支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
clc;
clear all;
close all;
global Qk ax ay Dik tou beta indA indB
%% Intialization
Nnodes=1;
Emax=1000;
Emin=5;
nk=8;
V=20;
Ra=10+(100-10).*rand(1,nk); % data rate
%% New
T=50; %patrolling cycle time constraint
% v,a---velocity and accelration
%% Charging behavior eqn 1
Ptx=10;
Gtx=3;
Grx=2;
lamda=20e-3;
Lp=0.3;
eta=0.9;
beta=0.2316;
tou= ((Gtx.*Grx.*eta./Lp).*(lamda./4.*pi).^2).*Ptx
   % Distance4 bw node and chaerger
   d=10; %--- Modified
   Prx=@(d)(tou./(d+beta).^2)
   Prx(2)
   % Tx power of Charger
D=15;
itr=5;
for i1=1:itr
noOfNodes=nk;
figure(1);
axis tight manual
clf;
hAx1 = axes;
hold on;
a=1;
b=nk;
r =floor( a + (b-a).*(rand(2,1)));
while(r(1)==r(2))
end
sor =r(1);%source node
des=r(2);%destination node
R =5.5; %node transmission range
a=1;
b=noOfNodes;
%X=floor(a + (b-a).*rand(1,noOfNodes));
%Y=floor(a + (b-a).*rand(1,noOfNodes));
X = 1+(30-1)*rand(1,nk);
Y = 1+(30-1)*rand(1,nk);
 X1= 10+(20-10)*rand(1,1);
 Y1= 10+(20-5)*rand(1,1);
 X2= 5+(15-5)*rand(1,1);
 Y2= 10+(10-5)*rand(1,1);
%Z =[1 0.1 0.6 0.8 0.6 0 0.1 1 1 1];
%plotting network topology
%i2=1;
for i2 = 1:noOfNodes
 plot(X(i2),Y(i2),'o','LineWidth',1,...
              'MarkerEdgeColor','k',...
              'MarkerFaceColor','y',...
              'MarkerSize',8');
          xlabel('X in m')
          ylabel('Y in m')
    text(X(i2), Y(i2), num2str(i2),'FontSize',10);
    %% Destination
      plot(X2,Y2,'^','LineWidth',1,...
              'MarkerFaceColor','r',...
              'MarkerSize',14');
hold on
end
axis([0 40 -5 40])
M_max = 14; %// number of cells in vertical direction
N_max = 10; %// number of cells in horizontal direction
trans = 1;  %// hexagon orientation (0 or 1)
%// Do the plotting:
hold on
C11={};
C={};
ab=1;
ik=1;
for x=0:7%:2;
      ik=x;
  for y=0:5
  if(mod(ik,2))
      x0=3+4.3*x;
      y0=3+3*2*y;
      hexagon(2,x0,y0);
      C11{x+1,y+1}=[x0;y0];
%       C{ab}=[x0;y0];
      hold on
      plot(x0,y0,'ok','MarkerFaceColor','k')
       cote=2;
       x1=cote*sqrt(2)*[-1 -0.5 0.5 1 0.5 -0.5 -1]+x0;
       y1=cote*sqrt(9)*[0 -0.5 -0.5 0 0.5 0.5 0]+y0;
  else
       x0=3+4.3*x;
       y0=3*2*y;
       hexagon(2,x0,y0);
       C11{x+1,y+1}=[3+4.3*x;3*2*y];
       hold on
       plot(3+4.3*x,3*2*y,'ok', 'MarkerFaceColor','k')
       cote=2;
  end
    C{ab}=[x0,y0];
 %% Inside the polygon or not
    [in,on] = inpolygon(X,Y,x1,y1);
     Nk(ab)=numel(find(in==1));% set of sensor node
     ind=[];
     ind=find(in==1);
     if(isempty(ind))
     Dik{ab}=0;
     Qk(ab)=0;
     else
     Dik{ab}=sqrt((X(ind)-x0).^2 +(Y(ind)-y0).^2 ); % distance froom node i to its cell center
     Qk(ab)=1;
     end
     %Tk --> Time stays of WCV
     ab=ab+1;
  end
end
% axis([0 30 0 30])
% grid
%% Travelling path Model
k=ab-1;
Z=ones(1,k); %% important
aa=cell2mat(C.');
Xa=aa(:,1);
Ya=aa(:,2);
    %% WCV
     plot(Xa(1)+2,Ya(1)+2,'o','LineWidth',1,...
              'MarkerFaceColor','g',...
              'MarkerSize',12');
     plot(Xa(1),Ya(1),'o','LineWidth',1,...
              'MarkerFaceColor','k',...
              'MarkerSize',14');
          xlabel('X in m')
          ylabel('Y in m')
    hold on
    text(Xa(1), Ya(1),'Vechile Stay Room','FontSize',10);
    hold on
saveas(gcf,'fileint.fig','fig')
% %% Existing Routing
 s=cell2mat(C.');
 ax=s(:,1);
 ay=s(:,2);
%%   Routing
  indA=find(Qk==1);
  indB=find(Qk~=1);
  G=randperm(numel(indA));
  path1 = indA(G);
%% OPTIMIZATION
% %% Problem Definition
CostFunction=@(x) Sphere(x);        % Cost Function
ik=1;
  %cost1=1000;
  eff1=inf;
while(ik<=4000)
    T1=1000.*rand(1);
    T=CostFunction(T1);
    eff=(T);
  if(eff<=eff1)
     eff1=eff;
     TT=T1;
  end
  costh1(ik)=eff1;
  costh(ik)=eff;
  ik=ik+1;
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
原文链接:qq912100926.blog.csdn.net/article/details/121054731
