【图像分割】基于matlab HSV彩色空间图像分割【含Matlab源码 1474期】
海神之光 发表于 2022/05/29 01:22:00 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【图像分割】基于matlab HSV彩色空间图像分割【含Matlab源码 1474期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、图像分割简介
理论知识参考:【基础教程】基于matlab图像处理图像分割【含Matlab源码 191期】
三、部分源代码
clear all
RGB = imread('capsicum.bmp');
figure(1);
imshow(RGB);
imwrite(RGB,'分割结果\capsicum.jpg','jpg');
HSV = rgb2hsv(RGB); % Transform from RGB to HSV
H = HSV(:,:,1);
%figure(2);
%imshow(H);
S = HSV(:,:,2);
%figure(3);
%imshow(S);
V = HSV(:,:,3);
%figure(4);
%imshow(V);
H = H+0.22;
INDEX = find(H>1);
H(INDEX) = H(INDEX) - 1;
%figure(24);
%imshow(H);
imwrite(H,'分割结果\capsicum_H_revolve.jpg','jpg');
% Color quantization
QH = 32;
QS = 4;
QV = 2;
scopeH = 1 / QH;
scopeS = 1 / QS;
scopeV = 1 / QV;
siz = size(H);
M = siz(1) * siz(2);
temp = zeros(siz);
HHH = temp;
SSS = temp;
VVV = temp;
% Quantize H
for i = 1:QH
    k = find((H < i*scopeH) & (H >= (i-1)*scopeH));
    HHH(k) = i;
end
% Quantize S
for i = 1:QS
    k = find((S < i*scopeS) & (S >= (i-1)*scopeS));
    SSS(k) = i;
end
% Quantize V
for i = 1:QV
    k = find((V < i*scopeV) & (V >= (i-1)*scopeV));
    VVV(k) = i
end
% Color label
QI = temp;         % label matrix, used to statistic Ck
for i = 1:siz(1)
    for j = 1:siz(2)
        QI(i,j) = (HHH(i,j) -1)*QS*QV + (SSS(i,j) - 1)*QV + VVV(i,j);
    end
end
eQI = uint8(QI);
figure(36);
imshow(eQI);
imwrite(eQI,'分割结果\capsicum_quantitation.jpg','jpg');
%imwrite(eQI,['Lajiao_VQofHSV','.bmp'],'bmp');
%figure(112);
%EDG2 = edge(eQI,'canny');
%imshow(EDG2);
%imwrite(EDG2,['Lajiao_VQofHSV_edg','.bmp'],'bmp');
% Double PCNN
%%%link parameter%%
[row, col] = size(QI);
Va = max(max(QI));
Vb = min(min(QI));
F = QI;
vl = 1;
vt = 500;
l_deta = 1;
l_t = 0.5;
link_a = l_deta*1 / l_t;
beta = 0.01;
t_deta = 1;
t_t = 25;
threshold = t_deta*1 / t_t;
%step = 20;%optimize
step = 18;
TEMP=zeros(row,col);
%%%%%%%%%%% to create W %%%%%%%%%%%%%%
%Ws=[0 1 0;1 1 1;0 1 0];
 radius=9;
 halfR = round(radius/2);
 deta = 2;
 for i = 1:radius
    for j = 1:radius
     if i==halfR & j==halfR
          K_r(halfR, halfR)=1;
          K_r2(halfR, halfR)=1;
       else
         K_r(i,j) = 1/sqrt((i-halfR)^2 + (j-halfR)^2);
      end
    end
 end
 Ws = K_r;
%%%%%%% start program %%%%%%%%%%%%%
%%%% factor loop %%%%%
Y_threshold = TEMP;
Y_time = TEMP;
Y1 = TEMP;
Y2 = TEMP;
Y = TEMP;
Ya = TEMP;
Yb = TEMP;
Edge_image=TEMP;
L = TEMP;
U = TEMP;
T1 = TEMP + Va;
T2 = TEMP + Vb;
j = 1;
%%% determine when exit loop
accuYTrue = 1;
iterTrue = 1;
accY = TEMP;  % Accumulate total neuros of firing
while iterTrue
    j
    L = link24(Y,L,Ws,link_a,vl);
    invar_fig=1;change_mark=0;k=0;
     m=1;%% fast linking %%
     while (invar_fig==1)
          m
          mid_Y=Y;
          U=internal24(F,L,Y,beta);
          Y1 = pulse1(U, T1);
          %Y2 = pulse2(U, T2);
          Y = Y1; % + Y2;
          %Y=pulse_p(U,T,L);
          if (mid_Y==Y)
             invar_fig=0;
          elseif m>30 & change_mark==0
             mid_Y1=mid_Y;
             mid_Y2=Y;
             change_mark=1;
          elseif change_mark==1 & k<1
             k=1;
          elseif k==1
             %if mid_Y1==mid_Y & mid_Y2==Y
                invar_fig=0;
                %else
               % change_mark=0;k=0;
               % end
          end
      end
    %%%%save threshold for fired pixels (sigle-pass)%%%%%%
    %%%%%%%statistc numbers of nurons in plusing areas %%%%%%
    index1 = find(Y1 ~= 0);%find index of element of noequal zero(index of pulsing neurons)
    q = size(index1, 1);
    if q ~= 0     %%% statistic pulsing neurons %%%
        for yy = 1:row
            for zz = 1:col
                if(Y1(yy, zz) == 1)
                    Y_threshold(yy, zz) = round(T1(yy, zz));
                    Y_time(yy, zz) = j;
                end
            end
        end   %%% statistic end %%%
    end
    Ya = Ya + Y1;
    T1 = threshold1(T1, Ya, Va, step);  %decrement threshold(linear decay)%%%%%%%%%%
    j=j+1;
    accY = accY + Y;
    index = find(accY == 0);
    size(index);
    if ans(1) == 0
        iterTrue = 0;
    end                       % Exit loop
end
figure(57);
Y_pcnn = uint8(Y_threshold)
imshow(Y_pcnn);
imwrite(Y_pcnn,'分割结果\capsicum_pcnn_segm2.bmp','bmp');
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]赵勇,方宗德,庞辉,王侃伟.基于量子粒子群优化算法的最小交叉熵多阈值图像分割[J].计算机应用研究. 2008,(04)
原文链接:qq912100926.blog.csdn.net/article/details/121087558
