【图像分割】基于matlab C-V模型水平集图像分割【含Matlab源码 1456期】
海神之光 发表于 2022/05/29 00:29:33 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【图像分割】基于matlab C-V模型水平集图像分割...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【图像分割】基于matlab C-V模型水平集图像分割【含Matlab源码 1456期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、图像分割简介
理论知识参考:【基础教程】基于matlab图像处理图像分割【含Matlab源码 191期】
三、部分源代码
%   Matlad code implementing Chan-Vese model in the paper 'Active Contours Without Edges'
clear all;
close all;
Img=imread('Head.bmp');
% Img=imread('vessel3.bmp'); % Note: this an example of images with intensity inhomogeneity.
                             % CV model does not work for this image.
Img=double(Img(:,:,1));
% get the size
[nrow,ncol] =size(Img);
ic=nrow/2;
jc=ncol/2;
r=10;  %起始园半径
initialLSF = sdf2circle(nrow,ncol,ic,jc,r);
u=initialLSF;
numIter = 200;
timestep = 0.5;
lambda_1=1;
lambda_2=1;
% h = 1;
h = 1;
epsilon=1;
nu = 0.001*255*255;  % tune this parameter for different images
% figure;
% imagesc(Img,[0 255]);colormap(gray)
% hold on;
% contour(u,[0 0],'r');
% start level set evolution
% for k=1:numIter
%     u=EVOL_CV(Img, u, nu, lambda_1, lambda_2, timestep, epsilon, 1);   % update level set function
%     if mod(k,10)==0
%         pause(.1);
%         hold on;
%         hold off;
%     end
% end;
% figure;
% imagesc(Img, [0, 255]);colormap(gray);hold on;
% title('Initial contour');
for k=1:numIter
    if mod(k,10)==0
        pause(.1);
         hold on;
        iterNum=[num2str(k), ' iterations'];
        title(['process of evolution,',iterNum]);
        hold off;
    end
end;
figure;
totalIterNum=[num2str(k), ' iterations'];
title(['Final contour, ', totalIterNum]);
function [C1,C2]= binaryfit(Img,H_phi)
%   [C1,C2]= binaryfit(phi,U,epsilon) computes c1 c2 for optimal binary fitting
%   input:
%       Img: input image
%       phi: level set function
%       epsilon: parameter for computing smooth Heaviside and dirac function
%   output:
%       C1: a constant to fit the image U in the region phi>0
%       C2: a constant to fit the image U in the region phi<0
%   Author: Chunming Li, all right reserved
%   email: li_chunming@hotmail.com
%   URL:   http://www.engr.uconn.edu/~cmli/research/
a= H_phi.*Img;
numer_1=sum(a(:));
denom_1=sum(H_phi(:));
C1 = numer_1/denom_1;
b=(1-H_phi).*Img;
numer_2=sum(b(:));
c=1-H_phi;
denom_2=sum(c(:));
C2 = numer_2/denom_2;
function f = sdf2circle(nrow,ncol, ic,jc,r)
%   sdf2circle(nrow,ncol, ic,jc,r) computes the signed distance to a circle
%   input:
%       nrow: number of rows
%       ncol: number of columns
%       (ic,jc): center of the circle
%       r: radius of the circle
%   output:
%       f: signed distance to the circle
%   created on 04/26/2004
%   author: Chunming Li
%   Copyright (c) 2004-2006 by Chunming Li
[X,Y] = meshgrid(1:ncol, 1:nrow);
f = sqrt((X-jc).^2+(Y-ic).^2)-r;
%f=sdf2circle(100,50,51,25,10);figure;imagesc(f)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]赵勇,方宗德,庞辉,王侃伟.基于量子粒子群优化算法的最小交叉熵多阈值图像分割[J].计算机应用研究. 2008,(04)
原文链接:qq912100926.blog.csdn.net/article/details/121087512
