【细胞分割】基于matlab GUI阈值+边缘+形态学+种子点+主动轮廓图像分割【含Matlab源码 1477期】
海神之光 发表于 2022/05/29 01:57:33 2022/05/29
【摘要】 一、图像分割简介 理论知识参考:【基础教程】基于matlab图像处理图像分割【含Matlab源码 191期】 二、部分源代码 function varargout = bishe2(varargi...
一、图像分割简介
二、部分源代码
function varargout = bishe2(varargin)
% BISHE2 MATLAB code for bishe2.fig
%      BISHE2, by itself, creates a new BISHE2 or raises the existing
%      singleton*.
%      H = BISHE2 returns the handle to a new BISHE2 or the handle to
%      BISHE2('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in BISHE2.M with the given input arguments.
%      BISHE2('Property','Value',...) creates a new BISHE2 or raises the
%      applied to the GUI before bishe2_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to bishe2_OpeningFcn via varargin.
% Edit the above text to modify the response to help bishe2
% Last Modified by GUIDE v2.5 26-Oct-2021 16:50:25
gui_Singleton = 1;
                   'gui_OpeningFcn', @bishe2_OpeningFcn, ...
                   'gui_OutputFcn',  @bishe2_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before bishe2 is made visible.
function bishe2_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to bishe2 (see VARARGIN)
% Choose default command line output for bishe2
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes bishe2 wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = bishe2_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
%% 按钮实现打开文件功能
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
global yuantu;
%文件打开对话框
[filename,pathname]=uigetfile({'*.bmp';'*.jpg';'*.gif'},'选择图片');
if isequal(filename,0)|isequal(pathname,0)
    errordlg('没有打开图像','出错');
return;
else
file=[pathname,filename];
yuantu=imread(file);%读入图像
%设置显示的坐标轴
axes(handles.axes1);
%显示图像
imshow(yuantu);title('原始图像');
end
% --- Executes on button press in pushbutton2.
%% 按钮实现图像灰度化
function pushbutton2_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton2 (see GCBO)
global yuantu;
axes(handles.axes2);
f= rgb2gray(yuantu);
imshow(f);title('灰度图像');
% --- Executes on button press in pushbutton3.
%% 按钮实现基于阈值的细胞分割算法
function pushbutton3_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton3 (see GCBO)
global yuantu;
axes(handles.axes3);
%%%%%%%%%%%%%%%大松算法
level=graythresh(yuantu);     %确定灰度阈值
BW=im2bw(yuantu,level);
imshow(BW);
title('基于阈值的细胞分割');
% --- Executes on button press in pushbutton4.
%% 按钮实现基于边缘的细胞分割算法
function pushbutton4_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton4 (see GCBO)
global yuantu;
%将axes4作为当前的坐标轴
axes(handles.axes4);
%获取popupmenu1的句柄为c
c=get(handles.popupmenu1,'value');
f=im2bw(yuantu);
[g_sobel_default , ts] = edge(f, 'sobel');
[g_log_default,tlog]=edge(f, 'log');
[g_canny_default,tc]=edge(f, 'canny' );
[g_prewitt_default,tp]=edge(f, 'prewitt');
[g_roberts_default,tr]=edge(f, 'roberts' );
g_sobel_best=edge(f, 'sobel' ,0.25);
g_log_best=edge(f, 'log',0.003,2.25);
g_canny_best=edge(f, 'canny' ,[0.04 0.10],1.5);
switch c
    case 1 %使用sobel算子边缘检测
        imshow(g_sobel_default);title('sobel图像边缘提取(自动阈值)');
    case 2 %使用log特算子边缘检测
        imshow(g_log_default);title('log图像边缘提取(自动阈值)');
    case 3 %使用canny算子边缘检测
        imshow(g_canny_default);title('canny图像边缘提取(自动阈值)');
    case 4 %使用log特算子边缘检测
        imshow(g_prewitt_default);title('prewitt图像边缘提取(自动阈值)');
    case 5 %使用canny算子边缘检测
        imshow(g_roberts_default);title('Roberts图像边缘提取(自动阈值)');
    case 6 %使用sobel算子边缘检测
        imshow(g_sobel_best);title('sobel算子边缘检测');
    case 7 %使用log特算子边缘检测
        imshow(g_log_best);title('log算子边缘检测');
    case 8 %使用canny算子边缘检测
        imshow(g_canny_best);title('canny算子边缘检测');
    case 9
        blood=rgb2gray(yuantu);
        [m,n]=size(blood);                % 求出图象大小
        b=double(blood);                  % 将blood转为双精度浮点类型
        N =sqrt(100) * randn(m,n);        % 生成方差为10的白噪声
        I=b+N;                            % 噪声干扰图象
        z0=max(max(I));                   % 求出图象中最大的灰度
        z1=min(min(I));                   % 最小的灰度
        T=(z0+z1)/2;                      % 求最大和最小灰度的平均值
        TT=0;
        S0=0; n0=0;
        S1=0; n1=0;
        allow=0.5;                       % 新旧阈值的允许接近程度
        d=abs(T-TT);                     % 数的绝对值
        count=0;                         % 记录几次循环
        while(d>=allow)                  % 迭代最佳阈值分割算法
            count=count+1;
            for i=1:m
                for j=1:n
                    if (I(i,j)>=T)
                        S0=S0+I(i,j);    % 图像中各个大于平均灰度值的点的灰度之和
                        n0=n0+1;         % 图像中各个大于平均灰度值的点的总数
                    end
                    if (I(i,j)<T)
                        S1=S1+I(i,j);    % 图像中各个小于平均灰度值的点的灰度之和
                        n1=n1+1;         % 图像中各个小于平均灰度值的点的总数
                    end
                end
            end
            T0=S0/n0;                    % 所有大于平均灰度值的点的平均灰度值
            T1=S1/n1;                    % 所有小于平均灰度值的点的平均灰度值
            TT=(T0+T1)/2;                % 平均值
            d=abs(T-TT);                 % 两个平均值的差
            T=TT;
        end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]赵勇,方宗德,庞辉,王侃伟.基于量子粒子群优化算法的最小交叉熵多阈值图像分割[J].计算机应用研究. 2008,(04)
原文链接:qq912100926.blog.csdn.net/article/details/121087711
