【优化算法】差分进化优化杂草优化(DIWO)【含Matlab源码 1482期】
海神之光 发表于 2022/05/29 01:19:48 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【优化算法】差分进化优化杂草优化(DIWO)【含Mat...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【优化算法】差分进化优化杂草优化(DIWO)【含Matlab源码 1482期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
clc;
clear;
close all;
tic;
%%%%%%%%%%%%%%1 参数设定%%%%%%%%%%%
N0=30;
 itmax=30;
dim=30;
pmax=50;
smax=10;
smin=1;
n=3;
delta_initial=3;
delta_final=0.001;
G=0.5;
CR=0.1;
xini=-40+10*rand(N0,dim);
%%%%%%%%%%%%%%%%%%%%%%主循环%%%%%%%%%%%%%%%%%%%%%%%%
iter=1;
while iter<=itmax
    Niter=N0;
  e=[];
    for i=1:Niter
fit=sum(xini(i,:).^2);
e=[e;fit];
    end
%%%%%%%%%%%%2 生长繁殖%%%%%%%%%%
Nseed=round(-(smax-smin)/(max(e)-min(e))*(e-min(e))+smax);
%%%%%%%%%%%%%3 空间扩散%%%%%%%%%
delta_iter=(itmax-iter)^n/(itmax)^n*(delta_initial-delta_final)+delta_final;
M=size(Nseed);
[aa bb]=sort(e);
fit_median=mean(e);
m={};
a=[];
b=[];
for i=1:M(1,1)
    if e(i)>=fit_median
    delta_i=(1+0.5*(e(i)-fit_median)/(max(e)-fit_median))*delta_iter;
else
    delta_i=(1-0.5*(fit_median-e(i))/(fit_median-min(e)))*delta_iter;
    end
  for  j=1:dim
%       x_iter=normrnd(xini(i,j),delta_iter^2,[1,Nseed(i,1)]);
k=rand();
 x_iter=(rand()+k*rand()-k)*normrnd(xini(i,j),delta_iter^2,[1,Nseed(i,1)])+1e-006*rand();
a=x_iter;
b=[b,a'];
  end
m{i}=b';
b=[];
end
f=[];
   for i=1:M(1,1)
   for j=1:Nseed(i,1)
    c=m{i};
   d=c(:,j);
fitness_seed=sum(d(:,1).^2);
end
X=[m,xini];                                 %新种群
F=[e;f];                                    %新种群的适应度值
Niter=Niter+sum(Nseed(:,1));                %新种群个体数量
V=size(X);
q=[];
    h=X{i};
    B=size(h);
    for j=1:B(1,2)
    l=h(:,j);
    q=[q,l];
    end
end
o=q';
%%%%%%%%%%4 竞争排除%%%%%%%%%%%%
   fitmin=g(1:pmax,1);
   Niter=pmax;
else
    fitmin=g;
end
xini=q(:,p(1:Niter,1));
iter=iter+1
yy=min(fitmin);
 end
%%%%%%%%%%%%%对经过一代繁殖后的杂草种群进行DE操作,产生新种群%%%%%%%%%%%%
it=1;
 while  it<=50
v=zeros(Niter,dim);
    u=zeros(Niter,dim);
for i=1:Niter
   p=randint(3,1,[1 Niter]);
r1=p(1);
r2=p(2);
r3=p(3);
for j=1:dim
v(i,j)=o(r1,j)+G*(o(r2,j)-o(r3,j));
 rk=randint(1,1,[1 dim]);
        else
            u(i,j)=o(i,j);
        end
    end
fitu=sum(u(i,:).^2);
if fitu<F(i)
       o(i,:)=u(i,:);
        F(i)=fitu;
end
end
    it=it+1
 end
F
figure(1)
plot(1:itmax,EB(1:itmax))
y=min(fitmin);
y
toc
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
[3]施媛波.基于改进的群居蜘蛛优化云计算任务调度算法[J].电脑编程技巧与维护. 2021,(04)
原文链接:qq912100926.blog.csdn.net/article/details/121134581
