【图像融合】基于matlab对比度和结构提取多模态解剖图像融合【含Matlab源码 1539期】
海神之光 发表于 2022/05/29 01:20:01 2022/05/29
【摘要】 一、图像融合简介 应用多模态图像的配准与融合技术,可以把不同状态的医学图像有机地结合起来,为临床诊断和治疗提供更丰富的信息。介绍了多模态医学图像配准与融合的概念、方法及意义。最后简单介绍了小波变换分析方...
一、图像融合简介
应用多模态图像的配准与融合技术,可以把不同状态的医学图像有机地结合起来,为临床诊断和治疗提供更丰富的信息。介绍了多模态医学图像配准与融合的概念、方法及意义。最后简单介绍了小波变换分析方法。
二、部分源代码
clear; close all; clc; warning off
%% A Novel Multi-Modality Anatomical Image FusionMethod Based on Contrast and Structure Extraction
% F = fuseImage(I,scale)
%Inputs:
%I - a mulyi-modal anatomical image sequence
%scale - scale factor of dense SIFT, the default value is 16
%% load images from the folder that contain multi-modal image to be fused
%I=load_images('./Dataset\CT-MRI\Pair 1');
I=load_images('./Dataset\MR-T1-MR-T2\Pair 1');
%I=load_images('./Dataset\MR-Gad-MR-T1\Pair 1');
% Show source input images
figure;
no_of_images = size(I,4);
for i = 1:no_of_images
    subplot(2,1,i); imshow(I(:,:,:,i));
end
suptitle('Source Images');
F=fuseImage(I,16);
%% Output: F - the fused image
F=rgb2gray(F);
figure;
imshow(F);
function [ F ] = fuseImage(I,scale)
addpath('Pyramid_Decomposition');
addpath('Guided_Filter');
addpath('Dense_SIFT');
tic
[H, W, C, N]=size(I);
imgs=im2double(I);
IA=zeros(H,W,C,N);
for i=1:N
IA(:,:,:,i)=enhnc(imgs(:,:,:,i));
end
imgs_gray=zeros(H,W,N);
for i=1:N
    imgs_gray(:,:,i)=rgb2gray(IA(:,:,:,i));
end
% %dense sift calculation
dsifts=zeros(H,W,32,N, 'single');
for i=1:N
    img=imgs_gray(:,:,i);
    ext_img=img_extend(img,scale/2-1);
    [dsifts(:,:,:,i)] = DenseSIFT(ext_img, scale, 1);
end
%local contrast
contrast_map=zeros(H,W,N);
for i=1:N
    contrast_map(:,:,i)=sum(dsifts(:,:,:,i),3);
end
%winner-take-all weighted average strategy for local contrast
[x, labels]=max(contrast_map,[],3);
clear x;
for i=1:N
    mono=zeros(H,W);
    mono(labels==i)=1;
    contrast_map(:,:,i)=mono;
end
%% Structure
h = [1 -1];
structure_map=zeros(H,W,N);
for i=1:N
structure_map(:,:,i) = abs(conv2(imgs_gray(:,:,i),h,'same')) + abs(conv2(imgs_gray(:,:,i),h','same')); %EQ 13
end
%winner-take-all weighted average strategy for structure
[a, label]=max(structure_map,[],3);
clear x;
for i=1:N
    monoo=zeros(H,W);
    monoo(label==i)=1;
    structure_map(:,:,i)=monoo;
end
weight_map=structure_map.*contrast_map;
%weight map refinement using Guided Filter
for i=1:N
    weight_map(:,:,i) = fastGF(weight_map(:,:,i),12,0.25,2.5);
end
% normalizing weight maps
weight_map = weight_map + 10^-25; %avoids division by zero
weight_map = weight_map./repmat(sum(weight_map,3),[1 1 N]);
%% Pyramid Decomposition
% create empty pyramid
pyr = gaussian_pyramid(zeros(H,W,3));
nlev = length(pyr);
% multiresolution blending
for i = 1:N
    % construct pyramid from each input image
    % blend
    for b = 1:nlev
        w = repmat(pyrW{b},[1 1 3]);
        pyr{b} = pyr{b} + w .*pyrI{b};
    end
end
% reconstruct
F = reconstruct_laplacian_pyramid(pyr);
toc
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]朱俊林.浅析多模态医学图像的配准与融合技术[J].医疗卫生装备. 2005,(12)
原文链接:qq912100926.blog.csdn.net/article/details/121590311
