【语音加密】基于matlab GUI语音信号加密解密(带面板)【含Matlab源码 181期】
海神之光 发表于 2022/05/28 23:32:55 2022/05/28
【摘要】 一、简介(附课程作业报告) 课程设计原理及设计方案 语音语音加密原理框图在对语音信号进行预处理、加密解密分析之后,将各个步骤联系起来绘出了语音加密原理框图如下: 二、部分源代码 functio...
一、简介(附课程作业报告)
  1. 课程设计原理及设计方案
二、部分源代码
function varargout = Signal_encryption_gui1(varargin)
% SIGNAL_ENCRYPTION_GUI1 MATLAB code for Signal_encryption_gui1.fig
%      SIGNAL_ENCRYPTION_GUI1, by itself, creates a new SIGNAL_ENCRYPTION_GUI1 or raises the existing
%      singleton*.
%      H = SIGNAL_ENCRYPTION_GUI1 returns the handle to a new SIGNAL_ENCRYPTION_GUI1 or the handle to
%      SIGNAL_ENCRYPTION_GUI1('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in SIGNAL_ENCRYPTION_GUI1.M with the given input arguments.
%      SIGNAL_ENCRYPTION_GUI1('Property','Value',...) creates a new SIGNAL_ENCRYPTION_GUI1 or raises the
%      applied to the GUI before Signal_encryption_gui1_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to Signal_encryption_gui1_OpeningFcn via varargin.
% Edit the above text to modify the response to help Signal_encryption_gui1
% Last Modified by GUIDE v2.5 17-Jul-2017 13:59:22
gui_Singleton = 1;
                   'gui_OpeningFcn', @Signal_encryption_gui1_OpeningFcn, ...
                   'gui_OutputFcn',  @Signal_encryption_gui1_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before Signal_encryption_gui1 is made visible.
function Signal_encryption_gui1_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to Signal_encryption_gui1 (see VARARGIN)
% Choose default command line output for Signal_encryption_gui1
global k1 k2 u1 u2 k11 k22 u11 u22
k1=0.3;u1=3.7;k2=0.6;u2=3.9;
k11=0.3;u11=3.7;k22=0.6;u22=3.9;
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
%设置GUI背景
ha=axes('units','normalized','position',[0 0 1 1]);
uistack(ha,'down')
H=imread('03.jpg');
image(H)
colormap gray
set(ha,'handlevisibility','off','visible','off');
% UIWAIT makes Signal_encryption_gui1 wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = Signal_encryption_gui1_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
%录音5秒
fs=8000;                    %语音信号采样频率为8000
Data=1:64;Data=(Data'*Data)/64;
uiwait(msgbox('开始录音','录音','custom',Data,hot(64)));
y=audiorecorder(fs,16,1);
recordblocking(y, 5);
myRecording = getaudiodata(y);
audiowrite('F:\MATLAB\Matlab\bin\workplace\Signal_Encrypion\s.wav',myRecording,fs);
msgbox('录音结束','录音','custom',Data,hot(64));
% hObject    handle to pushbutton1 (see GCBO)
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
global k1 k2 u1 u2
k1=str2double(get(handles.edit1,'string'));
u1=str2double(get(handles.edit3,'string'));
k2=str2double(get(handles.edit2,'string'));
u2=str2double(get(handles.edit4,'string'));
% hObject    handle to pushbutton2 (see GCBO)
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
global k11 k22 u11 u22
k11=str2double(get(handles.edit5,'string'));
u11=str2double(get(handles.edit7,'string'));
k22=str2double(get(handles.edit6,'string'));
u22=str2double(get(handles.edit8,'string'));
% hObject    handle to pushbutton3 (see GCBO)
% --- Executes on button press in pushbutton4.
function pushbutton4_Callback(hObject, eventdata, handles)
x=audioread('s.wav');
t=(0:length(x)-1)/44100;
axes(handles.axes1);
plot(handles.axes1,t,x)                  %做原始语音信号的时域图形
grid on;  axis tight;
title('原始语音信号');
xlabel('time(s)');
ylabel('幅度');
% hObject    handle to pushbutton4 (see GCBO)
% --- Executes on button press in pushbutton5.
function pushbutton5_Callback(hObject, eventdata, handles)
fs=44100;                    %语音信号采样频率为44100
Y=fft(x);             %对信号做2048点FFT变换
global N f
N=length(Y);
f=fs*(0:N/2-1)/N;
plot(handles.axes1,f,abs(Y(1:length(f))))           %做原始语音信号的FFT频谱图
title('原始语音信号FFT频谱')
xlabel('Hz');
ylabel('幅度');
% hObject    handle to pushbutton5 (see GCBO)
% --- Executes on button press in pushbutton6.
function pushbutton6_Callback(hObject, eventdata, handles)
sound(x)
% hObject    handle to pushbutton6 (see GCBO)
% --- Executes on button press in pushbutton7.
function pushbutton7_Callback(hObject, eventdata, handles)
x1=ceil(1000*x);             %预处理语音信号(原始信号扩大1000倍)
x2=dec_to_bin(x1);           %将语音信号由10进制转化为2进制
%利用Logistic混沌映射,对语音信号进行加密
global k1 k2 u1 u2
z1=k1;z2=k2;
for m=1:80                     %迭代80次,达到充分混沌状态
    z1=u1*z1*(1-z1);
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]韩纪庆,张磊,郑铁然.语音信号处理(第3版)[M].清华大学出版社,2019.
[2]柳若边.深度学习:语音识别技术实践[M].清华大学出版社,2019.
原文链接:qq912100926.blog.csdn.net/article/details/122372865
