【语音处理】基于matlab GUI音乐多次回声图谱显示【含Matlab源码 1733期】
海神之光 发表于 2022/05/29 01:00:11 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【语音处理】基于matlab GUI音乐多次回声图谱显示【含Matlab源码 1733期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = s2gui(varargin)
% S2GUI M-file for s2gui.fig
%      S2GUI, by itself, creates a new S2GUI or raises the existing
%      singleton*.
%      H = S2GUI returns the handle to a new S2GUI or the handle to
%      S2GUI('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in S2GUI.M with the given input arguments.
%      S2GUI('Property','Value',...) creates a new S2GUI or raises the
%      applied to the GUI before s2gui_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to s2gui_OpeningFcn via varargin.
% Edit the above text to modify the response to help s2gui
% Last Modified by GUIDE v2.5 14-Jun-2021 14:46:06
gui_Singleton = 1;
                   'gui_OpeningFcn', @s2gui_OpeningFcn, ...
                   'gui_OutputFcn',  @s2gui_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before s2gui is made visible.
function s2gui_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to s2gui (see VARARGIN)
% Choose default command line output for s2gui
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes s2gui wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = s2gui_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in signalload.
function signalload_Callback(hObject, eventdata, handles)
% hObject    handle to signalload (see GCBO)
[theFile, thePath] = uigetfile('*.wav','请选择一个WAV文件 ');
    if(ischar(theFile)),
        %读音频文件
       [x, fs, nBits]=wavread(fullfile(thePath,theFile));
       xx=x(:,1);
       handles.wavdata.x1  = xx(1:2048);
       handles.wavdata.x0 = xx(1:2048);
       handles.wavdata.y1 = xx(1:2048);
       handles.wavdata.y2 = xx(1:2048);
       handles.wavdata.y3 = xx(1:2048);
       handles.wavdata.fs = fs;
       handles.wavdata.nBits = nBits;
    end
    guidata(hObject,handles);
% --- Executes on button press in systemload.
function systemload_Callback(hObject, eventdata, handles)
% hObject    handle to systemload (see GCBO)
        %读音频文件
       [h, fs, nBits]=wavread(fullfile(thePath,theFile));
       hh=h(:,1);
       handles.wavdata.hp = hh(1:2048);
       handles.wavdata.fs1 = fs;
    end
% --- Executes on button press in startorigin.
function startorigin_Callback(hObject, eventdata, handles)
% hObject    handle to startorigin (see GCBO)
if(isempty(handles.wavdata)),
    uiwait(msgbox('Please press the button "Load" to select a *.wav file.',...
        'Warn','none','modal'));
    return;
end
 player = audioplayer(handles.wavdata.x1, handles.wavdata.fs, handles.wavdata.nBits);
play(player);
 %画图
axes(handles.originintime);
cla;
plot((1:2048)*1/handles.wavdata.fs,handles.wavdata.x1);
axes(handles.origininfreq);
cla;
Y=fft(handles.wavdata.x1,2048);
plot(linspace(-pi,pi,2048),fftshift(abs(Y)));
% --- Executes on button press in startoneecho.
function startoneecho_Callback(hObject, eventdata, handles)
% hObject    handle to startoneecho (see GCBO)
    return;
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]韩纪庆,张磊,郑铁然.语音信号处理(第3版)[M].清华大学出版社,2019.
[2]柳若边.深度学习:语音识别技术实践[M].清华大学出版社,2019.
[3]宋云飞,姜占才,魏中华.基于MATLAB GUI的语音处理界面设计[J].科技信息. 2013,(02)
原文链接:qq912100926.blog.csdn.net/article/details/123078153
