【数学建模】基于matlab贫困生评测系统【含Matlab源码 1744期】
海神之光 发表于 2022/05/29 01:15:57 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【数学建模】基于matlab贫困生评测系统【含Matlab源码 1744期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,私...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = susan(varargin)
% susan M-file for susan.fig
%      susan, by itself, creates a new susan or raises the existingbianji
%      singleton*.
%      H = susan returns the handle to a new susan or the handle to
%      susan('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in susan.M with the given input arguments.
%      susan('Property','Value',...) creates a new susan or raises the
%      applied to the GUI before susan_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to susan_OpeningFcn via varargin.
% Edit the above text to modify the response to help susan
% Last Modified by GUIDE v2.5 25-Apr-2020 21:07:48
gui_Singleton = 1;
                   'gui_OpeningFcn', @susan_OpeningFcn, ...
                   'gui_OutputFcn',  @susan_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before susan is made visible.
function susan_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to susan (see VARARGIN)
% Choose default command line output for susan
handles.output = hObject;
% Update handles structure
%姓名 name[i] 为第i个学生的姓名
%关系 guanxi1[i] 为第i个学生的第一位亲人
guidata(hObject, handles);
global baocunflag;
baocunflag=0;
global nummax;
nummax=1;
global stunum;
stunum=1;%记录第几个学生
global sum;
sum=zeros(1000,1);
global name ;
name={'',''};
global ID ;
ID=[];
global grade ;
grade=1;
global renkou ;
renkou=5;
global hukou ;
hukou=1;
global gucan ;
gucan=1;
global danqin ;
danqin=1;
global lieshi ;
lieshi=1;
global guanxi1 ;
guanxi1=[];
global guanxi2;
guanxi2=[];
global guanxi3 ;
guanxi3=[];
global guanxi4 ;
guanxi4=[];
global age1 ;
age1=[];
global age2 ;
age2=[];
global age3 ;
age3=[];
global age4 ;
age4=[];
global danwei1 ;
danwei1=[1];
global danwei2;
danwei2=1;
global danwei3 ;
danwei3=1;
global danwei4 ;
danwei4=1;
global shouru1 ;
shouru1=[];
global shouru2 ;
shouru2=[];
global shouru3 ;
shouru3=[];
global shouru4 ;
shouru4=[];
global health1 ;
health1=1;
global health2 ;
health2=1;
global health3 ;
health3=1;
global health4 ;
health4=1;
global yueshouru ;
yuehsouru=[];
global zizhu ;
zizhu=[];
global qiankuan ;
qiankuan=[];
global guanflag;
guanflag=5;
set(handles.renkou,'Value',5);
% UIWAIT makes susan wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function sumsum=fguanxi(age,danwei,shouru,health)
sumsum=0;
if age<45
    sumsum=sumsum+8;
else if age>=45 && age<55
        sumsum=sumsum+9;
    else if age>=55
            sumsum=sumsum+10;
        end
    end
end
switch danwei
    case 1
        sumsum=sumsum+8;
    case 2
        sumsum=sumsum+8;
    case 3
        sumsum=sumsum+9;
    case 4
        sumsum=sumsum+10;
    otherwise
        sumsum=sumsum+8;
end
if shouru<2000
    sumsum=sumsum+10;
else if shouru>=2000 && shouru<3000
        sumsum=sumsum+9;
    else if shouru>=3000 && shouru<4000
            sumsum=sumsum+8;
        else if shouru>=4000 && shouru<5000
                sumsum=sumsum+7;
            else if shouru>=5000
                    sumsum=sumsum+6;
                end
            end
        end
    end
end
switch health
    case 1
        sumsum=sumsum+8;
    case 2
        sumsum=sumsum+9;
    case 3
        sumsum=sumsum+10;
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]李昕.MATLAB数学建模[M].清华大学出版社.2017
[2]王健,赵国生.MATLAB数学建模与仿真[M].清华大学出版社.2016
[3]余胜威.MATLAB数学建模经典案例实战[M].清华大学出版社.2015
原文链接:qq912100926.blog.csdn.net/article/details/123155180
