【故障诊断分析】基于matlab GUI小波包能量可视化设计【含Matlab源码 1788期】
海神之光 发表于 2022/05/28 23:13:56 2022/05/28
【摘要】 一、案例简介 1 借用小波包分解和小波能量熵函数; 2 西储大学轴承故障数据; 3 提取小波能量方便快捷; 二、部分源代码 function varargout = wavlet_package_e...
一、案例简介
1 借用小波包分解和小波能量熵函数;
2 西储大学轴承故障数据;
3 提取小波能量方便快捷;
二、部分源代码
function varargout = wavlet_package_energy_GUI(varargin)
% WAVLET_PACKAGE_ENERGY_GUI MATLAB code for wavlet_package_energy_GUI.fig
%      WAVLET_PACKAGE_ENERGY_GUI, by itself, creates a new WAVLET_PACKAGE_ENERGY_GUI or raises the existing
%      singleton*.
%      H = WAVLET_PACKAGE_ENERGY_GUI returns the handle to a new WAVLET_PACKAGE_ENERGY_GUI or the handle to
%      WAVLET_PACKAGE_ENERGY_GUI('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in WAVLET_PACKAGE_ENERGY_GUI.M with the given input arguments.
%      WAVLET_PACKAGE_ENERGY_GUI('Property','Value',...) creates a new WAVLET_PACKAGE_ENERGY_GUI or raises the
%      applied to the GUI before wavlet_package_energy_GUI_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to wavlet_package_energy_GUI_OpeningFcn via varargin.
% Edit the above text to modify the response to help wavlet_package_energy_GUI
% Last Modified by GUIDE v2.5 10-Mar-2022 12:18:06
gui_Singleton = 1;
                   'gui_OpeningFcn', @wavlet_package_energy_GUI_OpeningFcn, ...
                   'gui_OutputFcn',  @wavlet_package_energy_GUI_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before wavlet_package_energy_GUI is made visible.
function wavlet_package_energy_GUI_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to wavlet_package_energy_GUI (see VARARGIN)
% Choose default command line output for wavlet_package_energy_GUI
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes wavlet_package_energy_GUI wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = wavlet_package_energy_GUI_OutputFcn(hObject, eventdata, handles)
% --- Executes on selection change in listbox1.
function listbox1_Callback(hObject, eventdata, handles)
% hObject    handle to listbox1 (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns listbox1 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from listbox1
% --- Executes during object creation, after setting all properties.
function listbox1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: listbox controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
% --- Executes on selection change in popupmenu1.
function popupmenu1_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu1 (see GCBO)
position1=get(handles.popupmenu1,'value')
if position1==1
load('99.mat');
x=X099_DE_time;
title_1='0号hp=2';
end
if position1==2
position_sub=2;
load('3003.mat');
x=X058_DE_time;
title_1='4号故障hp=2';
end
if position1==3
position_sub=3;
load('248.mat');
x=X248_DE_time;
title_1='7号hp=2: 负载3点位置:';
end
if position1==4
position_sub=4;
load('187.mat');
x=X187_DE_time;
title_1='10号hp=2:';
end
position_sub=2;
figure(1)
plot(x)
grid on
figure(2)
wpt=wpdec(x,4,'db1');
plot(wpt);
for i=0:15
    figure(3);
    rfs=wprcoef(wpt,[4,i]);
    subplot(4,4,i+1);
    plot(rfs);
    grid on;
    title(['[4',num2str(i),']']);
    axis([0 12000 min(rfs) max(rfs)]);
end
for i=0:3
    figure(4);
    subplot(4,1,i+1);
    plot(rfs);
    grid on;
end
for i=1:4
    wpt=wpdec(x,i,'db1');
    e=wenergy(wpt);
    E=zeros(1,length(e));
    for j=1:2^i
        E(j)=sum(abs(wprcoef(wpt,[i,j-1])).^2);
    end
    figure(5)
    subplot(4,1,i);
    bar(e);
    axis([0 length(e) 0 130]);
    title(['第',num2str(i),'层']);
    for j=1:length(e)
        text(j-0.2,e(j)+20,num2str(e(j),'%2.2f'));
    end
   if i==4
       figure(100)
    subplot(4,1,position1);
    bar(e);
    title([title_1,'第',num2str(i),'层能量']);
    for j=1:length(e)
    end
   end
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
原文链接:qq912100926.blog.csdn.net/article/details/123534455
