【优化算法】混沌博弈优化算法(CGO)【含Matlab源码 1803期】
海神之光 发表于 2022/05/29 00:15:39 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【优化算法】混沌博弈优化算法(CGO)【含Matlab源码 1803期】 二、部分源代码 % Chaos Game Optimizati...
一、获取代码方式
获取代码方式1:
二、部分源代码
%  Chaos Game Optimization (CGO) source codes version 1.0
clc;clear all;
%% Get Required Problem Information
ObjFuncName = @(x) Sphere(x); % @YourCostFunction ;
Var_Number = 10 ; % Number of your variables ;
LB = -10 *ones(1,Var_Number) ;  % Lower bound of variable ;
UB = 10 *ones(1,Var_Number) ;  % Upper bound of variable ;
%% Get Required Algorithm Parameters
MaxIter = 100 ; % Maximum number of generations ;
Seed_Number = 25 ; % Maximum number of initial eligible points ;
%% Outputs:
% BestSeed        (Best solution)
% BestFitness     (final Best fitness)
% Conv_History    (Convergence History Curve)
%% initialization
for i=1:Seed_Number
    % Initializing the Position of initial eligible points
    Seed(i,:)=unifrnd(LB,UB);
    % Initializing the fitness of initial eligible points
    Fun_eval(i,:)=feval(ObjFuncName,Seed(i,:));
end
%% Search Process of the CGO
for Iter=1:MaxIter
    for i=1:Seed_Number
        % Update the best Seed
        [~,idbest]=min(Fun_eval);
        BestSeed=Seed(idbest,:);
        %% Generate New Solutions
        % Random Numbers
        I=randi([1,2],1,12); % Beta and Gamma
        Ir=randi([0,1],1,5);
        % Random Groups
        RandGroupNumber=randperm(Seed_Number,1);
        RandGroup=randperm(Seed_Number,RandGroupNumber);
        % Mean of Random Group
        MeanGroup=mean(Seed(RandGroup,:)).*(length(RandGroup)~=1)...
            +Seed(RandGroup(1,1),:)*(length(RandGroup)==1);
        % New Seeds
        Alfa(1,:)=rand(1,Var_Number);
        Alfa(2,:)= 2*rand(1,Var_Number)-1;
        Alfa(3,:)= (Ir(1)*rand(1,Var_Number)+1);
        Alfa(4,:)= (Ir(2)*rand(1,Var_Number)+(~Ir(2)));
        ii=randi([1,4],1,3);
        SelectedAlfa=Alfa(ii,:);
        NewSeed(1,:)=Seed(i,:)+SelectedAlfa(1,:).*(I(1)*BestSeed-I(2)*MeanGroup);
        NewSeed(2,:)=BestSeed+SelectedAlfa(2,:).*(I(3)*MeanGroup-I(4)*Seed(i,:));
        NewSeed(3,:)=MeanGroup+SelectedAlfa(3,:).*(I(5)*BestSeed-I(6)*Seed(i,:));
        NewSeed(4,:)=unifrnd(LB,UB);
        for j=1:4
            % Checking/Updating the boundary limits for Seeds
            NewSeed(j,:)=bound(NewSeed(j,:),UB,LB);
            % Evaluating New Solutions
            Fun_evalNew(j,:)=feval(ObjFuncName, NewSeed(j,:));
        end
        Seed=[Seed; NewSeed];
        Fun_eval=[Fun_eval; Fun_evalNew];
    end
    [Fun_eval, SortOrder]=sort(Fun_eval);
    Seed=Seed(SortOrder,:);
    [BestFitness,idbest]=min(Fun_eval);
    Seed=Seed(1:Seed_Number,:);
    Fun_eval=Fun_eval(1:Seed_Number,:);
    % Store Best Cost Ever Found
    Conv_History(Iter)=BestFitness;
    % Show Iteration Information
    disp(['Iteration ' num2str(Iter) ': Best Cost = ' num2str(Conv_History(Iter))]);
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
原文链接:qq912100926.blog.csdn.net/article/details/123605069
