【图像处理】基于matlab GUI美颜系统【含Matlab源码 809期】
海神之光 发表于 2022/05/28 23:15:36 2022/05/28
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【图像处理】基于matlab GUI美颜系统【含Matlab源码 809期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,私...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、图像处理简介
图像处理知识点:
1 数字图像处理及matlab实现知识点总结1-4
2 数字图像处理及matlab实现知识点总结 5-10
三、部分源代码
function varargout = beautiful2(varargin)
% BEAUTIFUL2 M-file for beautiful2.fig
%      BEAUTIFUL2, by itself, creates a new BEAUTIFUL2 or raises the existing
%      singleton*.imaqhwinfo
%      H = BEAUTIFUL2 returns the handle to a new BEAUTIFUL2 or the handle to
%      BEAUTIFUL2('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in BEAUTIFUL2.M with the given input arguments.
%      BEAUTIFUL2('Property','Value',...) creates a new BEAUTIFUL2 or raises the
%      applied to the GUI before untitled_OpeningFunction gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to beautiful2_OpeningFcn via varargin.
% Copyright 2002-2003 The MathWorks, Inc.
% Edit the above text to modify the response to help beautiful2
% Last Modified by GUIDE v2.5 22-Apr-2021 10:13:32
gui_Singleton = 1;
                   'gui_OpeningFcn', @beautiful2_OpeningFcn, ...
                   'gui_OutputFcn',  @beautiful2_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before beautiful2 is made visible.
function beautiful2_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to beautiful2 (see VARARGIN)
% Choose default command line output for beautiful2
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
choose=importdata('choose.jpg' );
beauty=importdata('beauty.jpg' );
save=importdata('save.jpg' );
%camera=importdata('camera.jpg' );
%shoot=importdata('shoot.jpg' );
set(handles.pushbutton1,'CDATA',choose);
set(handles.pushbutton2,'CDATA',beauty);
set(handles.pushbutton3,'CDATA',save);
%set(handles.pushbutton4,'CDATA',camera);
%set(handles.pushbutton5,'CDATA',shoot);
% UIWAIT makes beautiful2 wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = beautiful2_OutputFcn(hObject, eventdata, handles) %设置背景
%设置背景
backgroundImage = importdata('background3.jpg');
axes(handles.axes3);
image(backgroundImage);
axis off;
%摄像头实时画面
global vid;
vid = videoinput('winvideo');
% --- Executes during object creation, after setting all properties.
function text1_CreateFcn(hObject, eventdata, handles)
% hObject    handle to text1 (see GCBO)
% handles    empty - handles not created until after all CreateFcns called
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)  %读取图片
% hObject    handle to pushbutton1 (see GCBO)
[filename,pathname]=uigetfile({'*.jpg';'*.bmp';'*.gif'},'选择图片');
if isequal(filename,0)
    -disp('Users Selected Canceled');
else
str=[pathname filename];
im = imread(str);
axes(handles.axes1);
imshow(im);
axes(handles.axes2);
imshow(im);
end;
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)%美颜
% hObject    handle to pushbutton2 (see GCBO)
img=getimage;
I= double(img);
IM1=RF(I,30,100); % RF滤波
IM2=IM1-I + 128;
IM3=imfilter(IM2,fspecial('gaussian',[3 3],100));%高斯模糊
opacity = 40;%透明度
IM = (I*(100 - opacity)+(I+2*IM3 - 256)*opacity)/100;%合成
IM = imfilter(IM,fspecial('gaussian',[1 1],10));%再次高斯滤波
MH=IM;
imshow(IM);
guidata(hObject,handles);
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)%保存图片
% hObject    handle to pushbutton3 (see GCBO)
[filename,pathname]=uiputfile({'*.bmp';},'保存图片','Undefined.bmp');
 % Error checking.
if ~isa(obj, 'imaqdevice')
    error(message('imaq:getsnapshot:invalidType'));
elseif (length(obj) > 1)
    error(message('imaq:getsnapshot:OBJ1x1'));
elseif ~isvalid(obj)
    error(message('imaq:getsnapshot:invalidOBJ'));
end
% Get single frame.
try
end;
    if exist('joint_image', 'var') && ~isempty(joint_image)
        J = double(joint_image);
        if (size(I,1) ~= size(J,1)) || (size(I,2) ~= size(J,2))
            error('Input and joint images must have equal width and height.');
        end
    else
        J = I;
    end
    [h w num_joint_channels] = size(J);
    %% Compute the domain transform (Equation 11 of our paper).
    % Estimate horizontal and vertical partial derivatives using finite
    % differences.
    dIcdx = diff(J, 1, 2);
    dIcdy = diff(J, 1, 1);
    dIdx = zeros(h,w);
    dIdy = zeros(h,w);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]陈浩,方勇,朱大洲,王成,陈子龙.基于蚁群算法的玉米植株热红外图像边缘检测[J].农机化研究. 2015,37(06)
原文链接:qq912100926.blog.csdn.net/article/details/116004476
