Jetpack Compose-Text【上】
坚果派 发表于 2022/05/28 14:00:47 2022/05/28
【摘要】 Text@Composablefun Text( text: String, modifier: Modifier = Modifier, color: Color = Color.Unspecified, fontSize: TextUnit = TextUnit.Unspecified, fontStyle: FontStyle? = null, fo...
Text
@Composable
fun Text(
    text: String,
    fontWeight: FontWeight? = null,
    fontFamily: FontFamily? = null,
    letterSpacing: TextUnit = TextUnit.Unspecified,
    textDecoration: TextDecoration? = null,
    textAlign: TextAlign? = null,
    lineHeight: TextUnit = TextUnit.Unspecified,
    overflow: TextOverflow = TextOverflow.Clip,
    softWrap: Boolean = true,
    maxLines: Int = Int.MAX_VALUE,
    onTextLayout: (TextLayoutResult) -> Unit = {},
    style: TextStyle = LocalTextStyle.current
Text 是 Compose 中最基本的布局组件,它可以显示文字
@Composable
fun TextDemo() {
    Text("Hello World")
从 res 中加载文字
@Composable
fun TextDemo() {
    Text(stringResource(id = R.string.content))
<resources>
    <string name="app_name">composestudy</string>
    <string name="content">秋刀鱼不会过期</string>
</resources>
1. style 参数
style 参数可以帮助我们配置文本的行高,颜色,粗体等设置
package com.example.composestudy
import android.os.Bundle
import androidx.activity.ComponentActivity
import androidx.activity.compose.setContent
import androidx.compose.foundation.layout.Column
import androidx.compose.material.MaterialTheme
import androidx.compose.material.Text
import androidx.compose.runtime.Composable
import androidx.compose.ui.tooling.preview.Preview
class MainActivity : ComponentActivity() {
    override fun onCreate(savedInstanceState: Bundle?) {
        super.onCreate(savedInstanceState)
        setContent {
                TextDemo()
   @Composable
fun TextDemo() {
       Column{
           Text(
               text = "这是一个标题",
               style = MaterialTheme.typography.h6
           Text(
               text ="我是内容",
               style = MaterialTheme.typography.body2
@Preview(name = "Light Mode")
@Composable
fun PreviewMessageCard() {
        TextDemo()
image-20220527163229462
文字间距
import androidx.compose.foundation.layout.fillMaxWidth
import androidx.compose.ui.Alignment
import androidx.compose.ui.Modifier
import androidx.compose.ui.text.TextStyle
import androidx.compose.ui.text.font.FontWeight
import androidx.compose.ui.unit.sp
        setContent {
                TextDemo()
@Composable
fun TextDemo() {
    Column(
        modifier = Modifier.fillMaxWidth(),
        horizontalAlignment = Alignment.CenterHorizontally
        Text(
            text = "大前端之旅",
            style = TextStyle(
                fontWeight = FontWeight.W900, //设置字体粗细
                fontSize = 20.sp,
                letterSpacing = 7.sp
@Composable
        TextDemo()
image-20220527163500913
2. maxLines 参数
使用 maxLines 参数可以帮助我们将文本限制在指定的行数之间,如果文本足够短则不会生效,如果文本超过 maxLines 所规定的行数,则会进行截断
@Composable
fun TextDemo() {
    Column{
        Text(
            text = "男人最好的状态是,25岁的时候能带着30岁的成熟去经营爱情,30岁的时候还带着18岁的不怕,去勇敢爱💪",
            style = MaterialTheme.typography.h6,
            maxLines = 1,
        Text(
            text ="大前端之旅",
overflow 处理溢出
使用 overflow 参数可以帮助我们处理溢出的视觉效果
@Composable
fun TextDemo() {
    Column{
        Text(
            maxLines = 1,
            overflow = TextOverflow.Ellipsis
        Text(
         text ="大前端之旅",
image-20220527163645854
3. textAlign 参数
当我们在 Text 中设置了 fillMaxWidth() 之后,我们可以指定 Text 的对齐方式
@Composable
fun TextDemo() {
    Column {
        Text(
            text = "每天摸鱼",
            textAlign = TextAlign.Left
        Text(
            text = "这好吗",
            textAlign = TextAlign.Center
        Text(
            text = "这非常的好",
            textAlign = TextAlign.Right
注意
需要注意区分的是,TextAlign 设置的是文本的对齐方式,而不是位置方向
如果需要实现 Text 组件居中,或者水平位置中其他方向,请参考这里
4. lineHeight 参数
使用 lineHeight 参数可以让我们指定 Text 中每行的行高间距
Column {
    Text(
        text = "大前端之旅".repeat(15),
    Spacer(Modifier.padding(vertical = 15.dp))
    Text(
        lineHeight = 30.sp
image-20220527164350417
5. fontFamily 参数
使用 fontFamily 参数可以让我们自定义字体,它的调用方法是这样的:
Column {
    Text("Hello World", fontFamily = FontFamily.Serif)
    Text("Hello World", fontFamily = FontFamily.SansSerif)
你也可以加载 res/font 下的字体。
创建一个 font 文件夹可以右键 res 文件夹,选择 Android Resource Directory -> 选择 font
Text(
    fontFamily = FontFamily(
        Font(R.font.pingfang, FontWeight.W700)
