传智学成在线Nginx.conf完整配置
baidaguo 发表于 2022/05/26 22:57:17 2022/05/26
【摘要】 #user nobody; worker_processes 1; #error_log logs/error.log; #error_log logs/error.log notice; ...
#user  nobody;
worker_processes  1;
#error_log  logs/error.log  info;
#pid        logs/nginx.pid;
events {
    worker_connections  1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    sendfile        on;
    #tcp_nopush     on;
    #keepalive_timeout  0;
    keepalive_timeout  65;
    #gzip  on;
	#cms页面预览
	upstream cms_server_pool{
	server 127.0.0.1:31001 weight=10;
	#图片服务
	upstream img_server_pool{
	server 192.168.25.133:80 weight=10;
	#静态资源服务
	upstream static_server_pool{
		server 127.0.0.1:91 weight=10;
	#前端动态门户
    upstream dynamic_portal_server_pool{
			server 127.0.0.1:10001 weight=10;
	#后台搜索(公开api)
	upstream search_server_pool{
	   server 127.0.0.1:40100 weight=10;
	#前端ucenter
	upstream ucenter_server_pool{
	  server  127.0.0.1:13000 weight=10;
	#学习服务
	upstream learning_server_pool{
		server 127.0.0.1:40600 weight=10;
	#认证服务
	upstream auth_server_pool{
		server 127.0.0.1:40400 weight=10;
	#微服务网关
	upstream api_server_pool{
		server 127.0.0.1:50201 weight=10;
	#前端教学管理
	upstream teacher_server_pool{
		server 127.0.0.1:12000 weight=10;
	#文件服务
	upstream filesystem_server_pool{
		server 127.0.0.1:22100 weight=10;
	#媒资服务
	upstream media_server_pool{
		server 127.0.0.1:31400 weight=10;
    server {
        listen       80;
        server_name  www.xuecheng.com;
		ssi on;
		ssi_silent_errors on;
        location / {
            alias   C:/CODE/JAVA/xczx/XcEduUI/xc-ui-pc-static-portal/;
            index  index.html index.htm;
		location /static/company/ {
			proxy_pass http://static_server_pool;
		location /static/teacher/ {
		location /static/stat/ {
		location /course/detail/ {
		#前端门户课程搜索
		location ^~ /course/search {
			proxy_pass http://dynamic_portal_server_pool;
		#后端搜索服务
		location /openapi/search/ {
			proxy_pass http://search_server_pool/search/;
		 #分类信息
		location /static/category/ {
		#开发环境webpack定时加载此文件
		location ^~ /__webpack_hmr {
			proxy_pass http://dynamic_portal_server_pool/__webpack_hmr;
		#开发环境nuxt访问_nuxt
		location ^~ /_nuxt/ {
			proxy_pass http://dynamic_portal_server_pool/_nuxt/;
		#静态资源,包括系统所需要的图片,js、css等静态资源
		location /static/img/ {
			alias   C:/CODE/JAVA/xczx/XcEduUI/xc-ui-pc-static-portal/img/;
		location /static/css/ {
			alias   C:/CODE/JAVA/xczx/XcEduUI/xc-ui-pc-static-portal/css/;
		location /static/js/ {
			alias   C:/CODE/JAVA/xczx/XcEduUI/xc-ui-pc-static-portal/js/;
		location /static/plugins/ {
			alias   C:/CODE/JAVA/xczx/XcEduUI/xc-ui-pc-static-portal/plugins/;
			add_header Access-Control-Allow-Origin http://ucenter.xuecheng.com;
			add_header Access-Control-Allow-Credentials true;
			add_header Access-Control-Allow-Methods GET;
		location /plugins/ {
		#页面预览
		location /cms/preview/ {
			proxy_pass http://cms_server_pool/cms/preview/;
		#认证
		location ^~ /openapi/auth/ {
			proxy_pass http://auth_server_pool/auth/;
		#微服务网关
		location /api {
			proxy_pass http://api_server_pool;
        error_page   500 502 503 504  /50x.html;
        location = /50x.html {
            root   html;
	#学成网图片服务
	server {
		listen       80;
		server_name img.xuecheng.com;
		#个人中心
		location /group1 {
			proxy_pass http://img_server_pool;
		#location /group2 {
		#	proxy_pass http://img_server_pool;
	#学成网静态资源
	server {
		listen       91;
		server_name localhost;
		#公司信息
		alias   C:/CODE/JAVA/xczx/XcEduUI/course-static/static/company/;
		#老师信息
		alias   C:/CODE/JAVA/xczx/XcEduUI/course-static/static/teacher/;
		#统计信息
		alias   C:/CODE/JAVA/xczx/XcEduUI/course-static/static/stat/;
		alias  C:/CODE/JAVA/xczx/XcEduUI/course-static/static/course/detail/;
		#分类信息
			alias  C:/CODE/JAVA/xczx/XcEduUI/course-static/static/category/;
	#学成网媒体服务代理
	map $http_origin $origin_list{
		default http://www.xuecheng.com;
		"~http://www.xuecheng.com" http://www.xuecheng.com;
		"~http://ucenter.xuecheng.com" http://ucenter.xuecheng.com;
	#学成网媒体服务代理
	server {
		listen       80;
		server_name video.xuecheng.com;
		location /video/ {
			proxy_pass http://video_server_pool;
			add_header Access-Control-Allow-Origin $origin_list;
			#add_header Access-Control-Allow-Origin *;
	#媒体服务
    upstream video_server_pool{
     server 127.0.0.1:90 weight=10;
	#学成网媒体服务
	server {
	listen       90;
		#视频存放目录
		location /video/ {
			alias C:/Java_Soft/xczx/video/;
   #学成网用户中心
	server {
	listen       80;
	server_name ucenter.xuecheng.com;
		#个人中心
		location / {
			proxy_pass http://ucenter_server_pool;
		#学习服务
		location ^~ /api/learning/ {
			proxy_pass http://learning_server_pool/learning/;
		#认证
	#学成网教学管理中心
	server {
		listen       80;
		server_name teacher.xuecheng.com;
		#个人中心
		location / {
			proxy_pass http://teacher_server_pool;
		location /api {
		location /filesystem {
			proxy_pass http://filesystem_server_pool;
		#媒资管理
		location ^~ /api/media/ {
			proxy_pass http://media_server_pool/media/;
		#认证
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
  • 276
  • 277
  • 278
  • 279
  • 280
  • 281
  • 282
  • 283
  • 284
  • 285
  • 286
  • 287
  • 288
  • 289
  • 290
  • 291
  • 292
  • 293
  • 294
  • 295
  • 296
  • 297
  • 298
  • 299
  • 300
  • 301
  • 302
  • 303
  • 304
  • 305
  • 306
  • 307
  • 308
  • 309
  • 310
  • 311
  • 312
  • 313
  • 314
  • 315
  • 316
  • 317
  • 318
  • 319
  • 320
  • 321
  • 322
  • 323
  • 324
文章来源: baidaguo.blog.csdn.net,作者:白大锅,版权归原作者所有,如需转载,请联系作者。
原文链接:baidaguo.blog.csdn.net/article/details/117992326
