Redis随项目启动或CRUD进行缓存数据
baidaguo 发表于 2022/05/26 00:17:21 2022/05/26
【摘要】 1.首先介绍项目启动时缓存数据库数据到redis(以缓存用户表数据为例) 1.1.创建UserCache类 /** *@Description 用户缓存 *@param *@return *@...
1.1.创建UserCache类
 *@Description 用户缓存
 *@param
 *@return
 *@author wang hq
@Component
public class UserCache {
    @Autowired
    private RedisService redisService;
    @Autowired
    private UserDao userDao;
    private static UserCache userCache;
    @PostConstruct
    public void init() {
        userCache = this;
        userCache.redisService = this.redisService;
        userCache.userDao = this.userDao;
     * @param userDtos
     * @return
     * @将数据库查询出来的数据 进行格式化 并存入 map和redis
    public static void init(List<UserDto> userDtos) {
        userCache.redisService.del(Constant.REDIS_USER);
        for (UserDto userDto : userDtos) {
            userCache.redisService.hSet(Constant.REDIS_USER, String.valueOf(userDto.getId()), userDto);
     * @param id
     * @param value
     * @修改缓存中的数据
    public static void modify(Integer id, UserDto value) {
        if (value == null && id == null) {
            new Throwable("id and value is not null!");
        //修改
        userCache.redisService.hSet(Constant.REDIS_USER, String.valueOf(id), value);
     * @param id
     * @删除缓存中的数据
    public static void delete(Integer id) {
        if (id == null) {
            new Throwable("id is not null!");
        userCache.redisService.hDel(Constant.REDIS_USER, String.valueOf(id));
     * @param users
     * @删除缓存中的数据
    public static void deleteList(List<Integer> users) {
        if (users == null) {
        for (Integer id : users) {
     * @param id
     * @return
     * @从缓存中获取appid对应的value
    public static UserDto userDto(Integer id) {
        if (id != null) {
        if (userCache.redisService.hGet(Constant.REDIS_USER, String.valueOf(id)) != null) {
            return JSONObject.parseObject(JSONObject.toJSONString(userCache.redisService.hGet(Constant.REDIS_USER, String.valueOf(id))), UserDto.class);
        UserDto userDto = new UserDto();
        userDto.setId(id);
        userDto = userCache.userDao.findOne(userDto, null);
        modify(id, userDto);
        return userDto;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
1.2.创建DemoRunner
@Order(3)
@Component
public class DemoRunner implements ApplicationRunner {
	@Autowired
	@Override
	public void run(ApplicationArguments applicationArguments) throws Exception {
		UserCache.init(userDao.findAll(new User(), null));
到这里后启动项目会发现用户数据已缓存到Redis表中在这里插入图片描述
若是做了上面操作后报RedisService注入错误的问题时 可参考https://blog.csdn.net/weixin_45735355/article/details/118308909?spm=1001.2014.3001.5501即可解决
2.CRUD操作时同步到Redis缓存
2.1 插入
Integer flag = userDao.save(user);
if (flag > 0) {
    UserCache.modify(user.getId(), JSONObject.parseObject(JSONObject.toJSONString(user), UserDto.class));
2.2 删除
Integer flag = userDao.delete(user);
        if (flag > 0) {
            UserCache.delete(user.getId());
        return flag;
更新
Integer flag = userDao.update(user);
        if (flag > 0) {
            TypeDictCache.modify(user.getId(), JSONObject.parseObject(JSONObject.toJSONString(user), UserDto.class));
        return flag;
文章来源: baidaguo.blog.csdn.net,作者:白大锅,版权归原作者所有,如需转载,请联系作者。
原文链接:baidaguo.blog.csdn.net/article/details/118416674
