SAP Fiori Elements List Report Smart Table Toolbar 的 XML 视图实现
汪子熙 发表于 2022/05/21 23:07:31 2022/05/21
【摘要】 http://localhost:8080/resources/sap/suite/ui/generic/template/ListReport/view/fragments/SmartTableToolbar.fragment.xmlSmartTableToolbar.fragment.xml 里,包含了 BreakoutActions.fragment:http://localhost:...
http://localhost:8080/resources/sap/suite/ui/generic/template/ListReport/view/fragments/BreakoutActions.fragment.xml
源代码:
<core:FragmentDefinition xmlns:template="http://schemas.sap.com/sapui5/extension/sap.ui.core.template/1"
						 xmlns="sap.m" xmlns:core="sap.ui.core" xmlns:build="sap.build">
	<template:if test="{= ${tmpEntitySet>EntitySet} === ${parameter>/entitySet} }">
		<template:repeat list="{tmpEntitySet>Actions}" var="customaction">
			<!--all break out actions which are neither determining nor global-->
			<template:if test="{= !${customaction>determining} &amp;&amp; !${customaction>global}}">
				<Button id="{parts: [{path: 'customaction>'}, {path: 'tabItem>'}], formatter: 'sap.suite.ui.generic.template.js.AnnotationHelper.getBreakoutActionButtonId'}"
						enabled="{parts: [{path: 'customaction>'}, {path: 'tabItem>'}], formatter: 'sap.suite.ui.generic.template.js.AnnotationHelper.getBreakoutActionEnabledKey'}"
						text="{customaction>text}"
						press="{customaction>press}" type="Transparent">
					<layoutData>
						<OverflowToolbarLayoutData priority = "{customaction>importance}"/>
					</layoutData>
				</Button>
            </template:if>
		</template:repeat>
	</template:if>
</core:FragmentDefinition>
运行时,该 XML 视图源代码被 XMLPreprocessor.js 解析:
SmartTableToolbar.fragment.xml 里包含了 BreakoutActions.fragment.xml:
getBreakoutActionButtonId:
