PHP:多维数组扁平化
彭世瑜 发表于 2022/05/19 23:18:47 2022/05/19
【摘要】 代码示例 <?php $arr = [ [ '1', '2' ], [ '1', '4', '5' ], ]; function...
代码示例
<?php
$arr = [
        '1', '2'
        '1', '4', '5'
function flatten($arr)
    $result = [];
    foreach ($arr as $k => $v) {
        if (is_array($v)) {
            $result = array_merge($result, flatten($v));
            $result[] = $v;
    return $result;
print_r(json_encode(flatten($arr)));
// ["1","2","1","4","5"]
// 去重处理,注意需要取值操作
print_r(json_encode(array_values(array_unique(flatten($arr)))));
// ["1","2","4","5"]
  • 26
  • 27
  • 28
  • 29
  • 30
参考
php 如何扁平化下面的数组?
原文链接:pengshiyu.blog.csdn.net/article/details/124868187
