springboot启动失败的问题('hibernate.dialect' not set)
程序员欣宸 发表于 2022/05/18 07:58:26 2022/05/18
【摘要】 一个常见的启动失败问题,在此做简单分析和记录
欢迎访问我的GitHub
这里分类和汇总了欣宸的全部原创(含配套源码):https://github.com/zq2599/blog_demos
  • springboot版本是1.3.0.M1,连接的mysql版本为8,用spring-boot-starter-data-jpa操做数据库,启动springboot报错如下:
2018-02-21 11:25:47.637  WARN 12992 --- [           main] ationConfigEmbeddedWebApplicationContext : Exception encountered during context initialization - cancelling refresh attempt
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'entityManagerFactory' defined in class path resource [org/springframework/boot/autoconfigure/orm/jpa/HibernateJpaAutoConfiguration.class]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Access to DialectResolutionInfo cannot be null when 'hibernate.dialect' not set
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1578)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:545)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
	at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:304)
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:300)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:195)
	at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1011)
	at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:802)
	at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:521)
	at org.springframework.boot.context.embedded.EmbeddedWebApplicationContext.refresh(EmbeddedWebApplicationContext.java:118)
	at org.springframework.boot.SpringApplication.refresh(SpringApplication.java:678)
	at org.springframework.boot.SpringApplication.doRun(SpringApplication.java:339)
	at org.springframework.boot.SpringApplication.run(SpringApplication.java:274)
	at org.springframework.boot.SpringApplication.run(SpringApplication.java:931)
	at org.springframework.boot.SpringApplication.run(SpringApplication.java:920)
	at com.business.backend.BizApplication.main(BizApplication.java:122)
Caused by: org.hibernate.HibernateException: Access to DialectResolutionInfo cannot be null when 'hibernate.dialect' not set
	at org.hibernate.engine.jdbc.dialect.internal.DialectFactoryImpl.determineDialect(DialectFactoryImpl.java:104)
	at org.hibernate.engine.jdbc.dialect.internal.DialectFactoryImpl.buildDialect(DialectFactoryImpl.java:71)
	at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.configure(JdbcServicesImpl.java:205)
	at org.hibernate.boot.registry.internal.StandardServiceRegistryImpl.configureService(StandardServiceRegistryImpl.java:111)
	at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:234)
	at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:206)
	at org.hibernate.cfg.Configuration.buildTypeRegistrations(Configuration.java:1887)
	at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1845)
	at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl$4.perform(EntityManagerFactoryBuilderImpl.java:857)
	at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl$4.perform(EntityManagerFactoryBuilderImpl.java:850)
	at org.hibernate.boot.registry.classloading.internal.ClassLoaderServiceImpl.withTccl(ClassLoaderServiceImpl.java:425)
	at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl.build(EntityManagerFactoryBuilderImpl.java:849)
	at org.springframework.orm.jpa.vendor.SpringHibernateJpaPersistenceProvider.createContainerEntityManagerFactory(SpringHibernateJpaPersistenceProvider.java:60)
	at org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean.createNativeEntityManagerFactory(LocalContainerEntityManagerFactoryBean.java:343)
	at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.afterPropertiesSet(AbstractEntityManagerFactoryBean.java:318)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1637)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1574)
	... 16 common frames omitted
2018-02-21 11:25:47.647  INFO 12992 --- [           main] o.apache.catalina.core.StandardService   : Stopping service Tomcat
  • 这一句比较关键:
  • 原来是Hibernate SQL方言没有设置导致的,在properties文件中增加下面这行:
spring.jpa.database-platform=org.hibernate.dialect.MySQLDialect
  • 再启动springboot,这次启动成功了;
  • 将Hibernate SQL方言整理如下表:
数据库 方言
DB2 org.hibernate.dialect.DB2Dialect
DB2 AS/400 org.hibernate.dialect.DB2400Dialect
DB2 OS390 org.hibernate.dialect.DB2390Dialect
PostgreSQL org.hibernate.dialect.PostgreSQLDialect
MySQL org.hibernate.dialect.MySQLDialect
MySQL with InnoDB org.hibernate.dialect.MySQLInnoDBDialect
MySQL with MyISAM org.hibernate.dialect.MySQLMyISAMDialect
Oracle (any version) org.hibernate.dialect.OracleDialect
Oracle 9i/10g org.hibernate.dialect.Oracle9Dialect
Sybase org.hibernate.dialect.SybaseDialect
Sybase Anywhere org.hibernate.dialect.SybaseAnywhereDialect
Microsoft SQL Server org.hibernate.dialect.SQLServerDialect
SAP DB org.hibernate.dialect.SAPDBDialect
Informix org.hibernate.dialect.InformixDialect
HypersonicSQL org.hibernate.dialect.HSQLDialect
Ingres org.hibernate.dialect.IngresDialect
Progress org.hibernate.dialect.ProgressDialect
Mckoi SQL org.hibernate.dialect.MckoiDialect
Interbase org.hibernate.dialect.InterbaseDialect
Pointbase org.hibernate.dialect.PointbaseDialect
FrontBase org.hibernate.dialect.FrontbaseDialect
Firebird org.hibernate.dialect.FirebirdDialect
欢迎关注华为云博客:程序员欣宸
学习路上,你不孤单,欣宸原创一路相伴…
