ROS1机器人多机网络通信案例turtlesim
zhangrelay 发表于 2022/05/12 00:57:27 2022/05/12
【摘要】 ROS1 kinetic+melodic+noetic,可以直接互通,c++程序全部通用的。 按:ROS1/2机器人多机网络通信配置-更新-2022 talker-listener 手机端发布,电脑端接收 电脑端发布,手机端接收。 python乱码: rostopic pub -r 1 /chatter std_m...
talker-listener
手机端发布,电脑端接收
电脑端发布,手机端接收。
python乱码:
rostopic pub -r 1 /chatter std_msgs/String "data: '做一个欢乐的机器人,很难吗^_^'"
乱码如下:
使用c++:
中文支持,哇卡卡!
当然如果源码编译肯定ok的。
发和收都是ok。
 1815  sudo apt install remmina remmina-plugin-vnc
 1816  ifconfig
 1817  ping 192.168.8.111
 1818  rostopic list
 1819  sudo apt install ros-noetic-fkie-multimaster
 1820  sudo apt install ros-noetic-fkie-node-manager
 1821  sudo apt install ros-noetic-fkie-potree-rviz-plugin
 1822  sudo apt install ros-noetic-fkie-master-sync
 1823  hostname
 1824  roscore
 1825  rosrun turtlesim turtle_teleop_key
 1826  sudo apt install ros-noetic-fkie-master-discovery
 1827  roscore
 1828  export ROS_IP=192.168.8.100
 1829  roscore
 1830  gedit .bashrc
 1831  rosrun master_discovery_fkie master_discovery
 1832  rosrun fkie_master_discovery master_discovery
 1833  rosrun master_discovery_fkie master_discovery
 1834  rosrun fkie_master_discovery master_discovery
 1835  rosrun fkie_master_discovery master_discovery _robot_host=[192.168.8.111]
 1836  rosrun fkie_master_discovery master_discovery _robot_host:=[192.168.8.111]
 1837  rosrun fkie_master_discovery master_discovery _robot_hosts:=[192.168.8.111]
 1838  rosrun fkie_node_manager_daemon node_manager_daemon
 1839  rosrun fkie_node_manager node_manager
 1840  sudo apt install python3-grpcio python3-grpc-tools
 1841  rosrun fkie_node_manager node_manager
 1842  rosrun fkie_node_manager_daemon node_manager_daemon
 1843  rosrun fkie_master_sync master_sync
 1844  ping 192.168.8.111
 1845  rosrun fkie_node_manager remote_nm.py
 1846  rostopic list
 1847  rostopic echo /master_discovery/linkstats
 1848  node_manager
 1849  rosrun turtlesim turtlesim_node
 1850  node_manager
 1851  sudo apt install ros-noetic-fkie-multimaster
 1852  sudo apt install python3-grpcio python3-grpc-tools
 1853  gedit
 1854  node_manager
 1855  ifconfig
 1856  sudo gedit /etc/hosts
 1857  sudo gedit /etc/hostname
 1858  sudo gedit /etc/hosts
 1859  gedit
 1860  roscore
 1861  ping ubuntu-phablet
 1862  roscore
 1863  rosrun turtlesim turtlesim_node
 1864  rostopic list
 1865  rosrun fkie_master_discovery master_discovery _robot_hosts:=[192.168.8.111]
 1866  rosrun usb_cam usb_cam_node
 1867  roslaunch usb_cam usb_cam-test.launch
 1868  rosrun roscpp_tutorials talker
 1869  rosrun roscpp_tutorials listener
 1870  rosrun roscpp_tutorials talker
 1871  rostopic pub -r 1 /chatter std_msgs/String "data: '做一个欢乐的机器人,很难吗^_^'"
 1872  rqt
 1873  rostopic echo /chatter /
 1874  rostopic echo /chatter
 1875  rosrun roscpp_tutorials listener
原文链接:zhangrelay.blog.csdn.net/article/details/124675229
