【Codeforces 1443 C】The Delivery Dilemma,贪心,排序
小哈里 发表于 2022/05/10 23:57:04 2022/05/10
【摘要】 problem C. The Delivery Dilemma time limit per test2 seconds memory limit per test256 megabytes input...
problem
inputstandard input
outputstandard output
Petya is preparing for his birthday. He decided that there would be n different dishes on the dinner table, numbered from 1 to n. Since Petya doesn’t like to cook, he wants to order these dishes in restaurants.
Unfortunately, all dishes are prepared in different restaurants and therefore Petya needs to pick up his orders from n different places. To speed up this process, he wants to order courier delivery at some restaurants. Thus, for each dish, there are two options for Petya how he can get it:
the dish will be delivered by a courier from the restaurant i, in this case the courier will arrive in ai minutes,
Petya goes to the restaurant i on his own and picks up the dish, he will spend bi minutes on this.
Each restaurant has its own couriers and they start delivering the order at the moment Petya leaves the house. In other words, all couriers work in parallel. Petya must visit all restaurants in which he has not chosen delivery, he does this consistently.
For example, if Petya wants to order n=4 dishes and a=[3,7,4,5], and b=[2,1,2,4], then he can order delivery from the first and the fourth restaurant, and go to the second and third on your own. Then the courier of the first restaurant will bring the order in 3 minutes, the courier of the fourth restaurant will bring the order in 5 minutes, and Petya will pick up the remaining dishes in 1+2=3 minutes. Thus, in 5 minutes all the dishes will be at Petya’s house.
Find the minimum time after which all the dishes can be at Petya’s home.
Input
The first line contains one positive integer t (1≤t≤2⋅105) — the number of test cases. Then t test cases follow.
Each test case begins with a line containing one integer n (1≤n≤2⋅105) — the number of dishes that Petya wants to order.
The second line of each test case contains n integers a1…an (1≤ai≤109) — the time of courier delivery of the dish with the number i.
The third line of each test case contains n integers b1…bn (1≤bi≤109) — the time during which Petya will pick up the dish with the number i.
The sum of n over all test cases does not exceed 2⋅105.
Output
For each test case output one integer — the minimum time after which all dishes can be at Petya’s home.
Example
inputCopy
4
4
3 7 4 5
2 1 2 4
4
1 2 3 4
3 3 3 3
2
1 2
10 10
2
10 10
1 2
outputCopy
5
3
2
3
solution
题意:
+ n(2e5)个菜肴,外卖为ai,自取为bi。总用时为max(max(ai),sum(bi)),求最少用时
思路:
+ 如果我们的某个外卖时间x,那么所有y<x都外卖,因为不影响结果。
+ 所以对ai降序排序,对bi求前缀和。当自取和大于外卖时,剩下的都点外卖,之前的自取和外卖选更大值。
#include<bits/stdc++.h>
using namespace std;
typedef long long LL;
const int maxn = 2e5+10;
LL a[maxn], b[maxn];
int main(){
	ios::sync_with_stdio(false);
	int T;  cin>>T;
	while(T--){
		int n;  cin>>n;
		vector<pair<LL,LL> >v;
		for(int i = 0; i < n; i++)cin>>a[i];
		for(int i = 0; i < n; i++){
			cin>>b[i];  v.push_back({a[i],b[i]});
		sort(v.rbegin(),v.rend());
		LL sum = 0, ans, ok = 0;
			sum += v[i].second;
			if(sum>=v[i].first){
				ok = 1;
				ans = max(v[i].first,sum-v[i].second);
				break;
		if(ok==1)cout<<ans<<"\n";
		else cout<<sum<<"\n";
	return 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
文章来源: gwj1314.blog.csdn.net,作者:小哈里,版权归原作者所有,如需转载,请联系作者。
原文链接:gwj1314.blog.csdn.net/article/details/113478967
评论(0
