【编辑器】Vim学习笔记
小哈里 发表于 2022/05/11 01:03:48 2022/05/11
【摘要】 0x00先放几个比较好的学习资料 1.Vim入门基础 http://www.jianshu.com/p/bcbe916f97e1 2.vim配置 http://blog.csdn.net/g_brig...
0x00先放几个比较好的学习资料
2.vim配置 http://blog.csdn.net/g_brightboy/article/details/14229139
3.简明Vim练级攻略 http://coolshell.cn/articles/5426.html
4.http://blog.csdn.net/mu_zhou233/article/details/53045831
0x01然后是配置文件
字体 Mac上用Monaco 20号(Monaco字体太漂亮了太可爱了),Windows上用16号
"2017.7.20  g++ with macvim By gwj
let s:cpo_save = &cpo
set cpo&vim
colorscheme macvim
set cin
set tabstop=4
set softtabstop=4
set shiftwidth=4
set nu
set guitablabel=%M%t
set ruler
set autoindent
set smartindent
filetype on
syntax on
set showmatch
set guifont=Monaco:h20
set mouse=a
set selection=exclusive
set selectmode=mouse,key
nnoremap <F7> <Esc>:w<CR>:!g++ % -Wall -o
nnoremap <F8> <Esc>:!./
nnoremap <F9> <Esc>:w<CR>:!g++ % -Wall -o a
nnoremap <F10> <Esc>:!./a<CR>
set printexpr=system('open\ -a\ Preview\ '.v:fname_in)\ +\ v:shell_error
let $SSH_ASKPASS = simplify($VIM . '/../../MacOS') . '/macvim-askpass'
let $SUDO_ASKPASS = $SSH_ASKPASS
let &cpo = s:cpo_save
unlet s:cpo_save
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
" Candy? MacOS
set number
set ruler
set tabstop=4
set shiftwidth=4
set autoindent
set smartindent
filetype on
syntax on
colorscheme solarized
set showmatch
set mouse=a
nnoremap <F9> <Esc>:w<CR>:!g++ % -Wall -o a<CR>
"mhy12345
"Configure of Vundle
set nocompatible              " be iMproved, required
filetype off                  " required
" set the runtime path to include Vundle and initialize
set rtp+=~/.vim/bundle/Vundle.vim
call vundle#begin()
" alternatively, pass a path where Vundle should install plugins
"call vundle#begin('~/some/path/here')
" Default Plugin
Plugin 'VundleVim/Vundle.vim'
Plugin 'vim-airline/vim-airline'
Plugin 'vim-airline/vim-airline-themes'
Plugin 'Valloric/YouCompleteMe'
" All of your Plugins must be added before the following line
call vundle#end()            " required
filetype plugin indent on    " required
" To ignore plugin indent changes, instead use:
"filetype plugin on
" Brief help
" :PluginList       - lists configured plugins
" :PluginInstall    - installs plugins; append `!` to update or just :PluginUpdate
" :PluginSearch foo - searches for foo; append `!` to refresh local cache
" :PluginClean      - confirms removal of unused plugins; append `!` to auto-approve removal
" see :h vundle for more details or wiki for FAQ
" Put your non-Plugin stuff after this line
"Old encoding setting...
set fileencodings=utf-8,ucs-bom,gb18030,gbk,gb2312,cp936
set termencoding=utf-8
set encoding=utf-8
"Configure airline
let molokai_original=1
let g:airline_theme="molokai"
"始终显示状态栏
set laststatus=2
"打开tabline功能,方便查看Buffer和切换,省去了minibufexpl插件
let g:airline#extensions#tabline#enabled = 1
let g:airline#extensions#tabline#buffer_nr_show = 1
"设置切换Buffer快捷键"
nnoremap <C-tab> :bn<CR>
nnoremap <C-s-tab> :bp<CR>
" 关闭状态显示空白符号计数
let g:airline#extensions#whitespace#enabled = 0
let g:airline#extensions#whitespace#symbol = '!'
" 设置consolas字体"前面已经设置过
"set guifont=Consolas\ for\ Powerline\ FixedD:h11
if !exists('g:airline_symbols')
  let g:airline_symbols = {}
endif
"End
"YouCompleteMe
let g:ycm_global_ycm_extra_conf='~/.vim/bundle/YouCompleteMe/cpp/ycm/.ycm_extra_conf.py'
let g:airline_powerline_fonts = 1
"Own configure
nnoremap <leader>f :YcmCompleter FixIt<CR>
function Compile()
    if &filetype == 'cpp'
        exec "!g++ % -o %< -g -Wall -Wextra -Wconversion -std=c++11"
    elseif &filetype == 'c'
        exec "!gcc % -o %< -g -Wall -Wextra -Wconversion"
    elseif &filetype == 'pas'
        exec "!fpc % -g"
    elseif &filetype == 'tex'
        exec "!xelatex '%'"
    elseif &filetype == 'java'
        exec "!javac %"
    elseif &filetype == 'scss'
        exec "!sass % > %<.css"
    endif
endfunction
function Debug()
        exec "!gdb ./%<"
        exec "!open './%<.pdf'"
        exec "!jdb %<"
    endif
endfunction
function Run()
        exec "!time ./%<"
        exec "!java %<"
    elseif &filetype == 'ruby'
        exec "!ruby %"
    elseif &filetype == 'html'
        exec "!firefox %"
    elseif &filetype == 'php'
        exec "!php %"
    elseif &filetype == 'sh'
        exec "!bash %"
    endif
endfunction
set hlsearch
set mouse=a
set smartindent
set fdm=marker
set number
set tabstop=4
set softtabstop=4
set shiftwidth=4
set backspace=2
syntax on
imap jj <esc>
map <F9> : call Compile() <CR>
map <F5> : call Debug() <CR>
map <F6> : call Run() <CR>
map <F8> : ! xcodebuild <CR>
map <F12> : ! subl ./% <CR>
map <F2> : ! python3 % <CR>
colors evening
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
"main command
"打开语法高亮
syntax on
"使用配色方案
colorscheme desert
"打开文件类型检测功能
filetype on
"不同文件类型采用不同缩进
filetype indent on
"允许使用插件
filetype plugin on
"关闭vi模式
set nocp
"与windows共享剪贴板
set clipboard+=unnamed
"取消VI兼容,VI键盘模式不易用
set nocompatible
"显示行号, 或set number
set nu
"历史命令保存行数
set history=100
"当文件被外部改变时自动读取
set autoread
"取消自动备份及产生swp文件
set nobackup
set nowb
set noswapfile
"允许使用鼠标点击定位
set mouse=a
"允许区域选择
"高亮光标所在行
set cursorline
"取消光标闪烁
set novisualbell
"总是显示状态行
set laststatus=2
"状态栏显示当前执行的命令
set showcmd
"标尺功能,显示当前光标所在行列号
set ruler
"设置命令行高度为3
set cmdheight=3
"粘贴时保持格式
set paste
"高亮显示匹配的括号
set showmatch
"在搜索的时候忽略大小写
set ignorecase
"高亮被搜索的句子
set hlsearch
"在搜索时,输入的词句的逐字符高亮(类似firefox的搜索)
set incsearch
"继承前一行的缩进方式,特别适用于多行注释
set autoindent
"为C程序提供自动缩进
set smartindent
"使用C样式的缩进
set cindent
"制表符为4
set tabstop=4
"统一缩进为4
set softtabstop=4
set shiftwidth=4
"允许使用退格键,或set backspace=2
set backspace=eol,start,indent
set whichwrap+=<,>,h,l
"取消换行
set nowrap
"启动的时候不显示那个援助索马里儿童的提示
set shortmess=atI
"在被分割的窗口间显示空白,便于阅读
set fillchars=vert:\ ,stl:\ ,stlnc:\
"光标移动到buffer的顶部和底部时保持3行距离, 或set so=3
set scrolloff=3
"设定默认解码
set fenc=utf-8
set fencs=utf-8,usc-bom,euc-jp,gb18030,gbk,gb2312,cp936
"设定字体
set guifont=Courier_New:h11:cANSI
set guifontwide=新宋体:h11:cGB2312
"设定编码
set enc=utf-8
set fileencodings=ucs-bom,utf-8,chinese
set langmenu=zh_CN.UTF-8
language message zh_CN.UTF-8
source $VIMRUNTIME/delmenu.vim
source $VIMRUNTIME/menu.vim
"自动补全
set completeopt=longest,menu
"自动补全命令时候使用菜单式匹配列表
set wildmenu
autocmd FileType ruby,eruby set omnifunc=rubycomplete#Complete
autocmd FileType python set omnifunc=pythoncomplete#Complete
autocmd FileType javascript set omnifunc=javascriptcomplete#CompleteJS
autocmd FileType html set omnifunc=htmlcomplete#CompleteTags
autocmd FileType css set omnifunc=csscomplete#CompleteCSS
autocmd FileType xml set omnifunc=xmlcomplete#CompleteTags
autocmd FileType java set omnifunc=javacomplete#Complet
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
0x03具体操作
占坑待填。
文章来源: gwj1314.blog.csdn.net,作者:小哈里,版权归原作者所有,如需转载,请联系作者。
原文链接:gwj1314.blog.csdn.net/article/details/79700994
