【愚公系列】2022年05月 .NET架构班 063-分布式中间件 .NET Core下Elasticsearch的基本使用
愚公搬代码 发表于 2022/05/10 00:08:03 2022/05/10
【摘要】 一、.NET Core下Elasticsearch的基本使用 1.前提 1.1 jdkjava是当前比较流行的一种编程语言,当我们开始学习java的时候肯定会先要安装jdk,然后进行环境变量控制。JRE(Java Runtime Environment ) Java运行环境,用来运行JAVA程序的。JDK(Java Development Kit) Java开发工具包,包含JRE。因此只...
1.前提
1.1 jdk
  • JRE(Java Runtime Environment ) Java运行环境,用来运行JAVA程序的。
  • JDK(Java Development Kit) Java开发工具包,包含JRE。因此只需要下载安装JDK即可中。
  • JDK是Sun Microsystems针对Java开发员的产品,JSP运行环境需要JDK的支持。
  • JDK 是整个Java的核心,包括了Java运行环境,Java工具和Java基础的类库。
java官网:http://www.oracle.com/
依次点击:资源》下载》JDK
选择最新版本进行安装就可以了
安装完记得设置变量环境。输入:java -version验证是否安装成功
1.2 Elasticsearch准备
Elasticsearch官网:​https://www.elastic.co/cn/downloads/elasticsearch
先进入到Elasticsearch中,进入到config目录中
# ======================== Elasticsearch Configuration =========================
# NOTE: Elasticsearch comes with reasonable defaults for most settings.
#       Before you set out to tweak and tune the configuration, make sure you
#       understand what are you trying to accomplish and the consequences.
# The primary way of configuring a node is via this file. This template lists
# the most important settings you may want to configure for a production cluster.
# Please consult the documentation for further information on configuration options:
# https://www.elastic.co/guide/en/elasticsearch/reference/index.html
# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
cluster.name: my-application-cluster
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
node.name: node-1
# Add custom attributes to the node:
#node.attr.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
#path.data: /path/to/data
# Path to log files:
#path.logs: /path/to/logs
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
network.host: localhost
# Set a custom port for HTTP:
http.port: 9200
cluster.routing.allocation.disk.threshold_enabled: false
http.cors.enabled: true
http.cors.allow-origin: "*"
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when this node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
#discovery.seed_hosts: ["host1", "host2"]
# Bootstrap the cluster using an initial set of master-eligible nodes:
#cluster.initial_master_nodes: ["node-1", "node-2"]
# For more information, consult the discovery and cluster formation module documentation.
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
#gateway.recover_after_nodes: 3
# For more information, consult the gateway module documentation.
# ---------------------------------- Various -----------------------------------
# Require explicit names when deleting indices:
#action.destructive_requires_name: true
elasticsearch.bat
1.3 可视化工具kibana下载
地址:https://www.elastic.co/cn/downloads/past-releases/
启动kibana
登录kibana
查看kibana
2.使用
2.1 nuget安装包
NEST和Elasticsearch版本对应上
NEST
2.2 相关接口和类
Product模型类
/// <summary>
/// 商品
/// </summary>
public class Product
    public string Id { set; get; }
    public string ProductCode { set; get; }    //商品编码
    public string ProductUrl { set; get; }         // 商品主图 text
    public string ProductTitle { set; get; }       //商品标题
    public string ProductDescription { set; get; }     // 图文描述
    public decimal ProductVirtualprice { set; get; } // 商品虚拟价格
    public decimal ProductPrice { set; get; }       //价格
    public int ProductSort { set; get; }    //商品序号
    public int ProductSold { set; get; }        //已售件数
    public int ProductStock { set; get; }       //商品库存
    public string ProductStatus { set; get; } // 商品状态
    public int score { set; get; } //商品级别
ProductService服务类
/// <summary>
/// 商品服务实现
/// </summary>
public class ProductService : IProductService
    private readonly IMongoCollection<Product> _products;
    public ProductService()
        #region 1、单实例连接
                var node = new Uri("http://localhost:9200");
                // var defaultIndex = "products";
                var settings = new ConnectionSettings(node);
                //.DefaultIndex(defaultIndex);
                elasticClient = new ElasticClient(settings);
            #endregion
    public void Create(Product Product)
        elasticClient.Index(Product,idx => idx.Index("products"));
2.3 使用
/// <summary>
/// 商品控制器
/// </summary>
[ApiController]
[Route("Product")]
public class ProductController : ControllerBase
    private readonly IProductService _productService;
    public ProductController(IProductService productService)
        _productService = productService;
    /// <summary>
    /// 添加商品
    /// </summary>
    /// <param name="product"></param>
    /// <returns></returns>
    [HttpPost]
    public ActionResult<Product> PostProduct(Product product)
        _productService.Create(product);
        return CreatedAtAction("GetProduct", new { id = product.Id }, product);
Elasticsearch是依赖于java开发的,所以必须得有java环境才能运行,但Elasticsearch是支持多语言的完全适用于.NET Core。
