ubuntu Python 升级
陈沧夜 发表于 2022/05/05 00:15:46 2022/05/05
【摘要】 安装时ubuntu提示: DEPRECATION: Python 3.4 support has been deprecated. pip 19.1 will be the last one supporting it. Please upgrade your Python as Python 3.4 won't be maintai...
安装时ubuntu提示:
  1. DEPRECATION: Python 3.4 support has been deprecated. pip 19.1 will be the last one
  2. supporting it. Please upgrade your Python as Python 3.4 won't be maintained after March
  3. 2019 (cf PEP 429).
 所以我们要升级一下版本:
  1. wget https://www.python.org/ftp/python/3.7.3/Python-3.7.3.tar.xz
  2. xz -d Python-3.7.3.tar.xz
  3. tar -xvf Python-3.7.3.tar
  4. cd Python-3.7.3
  5. ./configure --with-ssl
  6. sudo make
  7. sudo make install
如果不成功,安装依赖再试一下:
sudo apt-get install -y zlib*
 接着修改软连接
  1. sudo rm -rf /usr/bin/python3
  2. sudo rm -rf /usr/bin/pip3
  3. sudo ln -s /usr/local/python3/bin/python3.7 /usr/bin/python3
  4. sudo ln -s /usr/local/python3/bin/pip3.7 /usr/bin/pip3
重启即可
文章来源: blog.csdn.net,作者:沧夜2021,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/CANGYE0504/article/details/89348522
