MapReduce使用
红目香薰 发表于 2022/04/30 23:38:58 2022/04/30
【摘要】 ​ maven:<dependency> <groupId>org.apache.hadoop</groupId> <artifactId>hadoop-client</artifactId> <version>2.7.3</version> </dependency>MapActionpackage com.item.test;import org.ap...
 maven:
<dependency>
    </dependency>
MapAction
import org.apache.hadoop.io.LongWritable;
import org.apache.hadoop.io.Text;
import org.apache.hadoop.mapreduce.Mapper;
import java.io.IOException;
public class MapAction extends Mapper<LongWritable, Text, Text, LongWritable> {
    @Override
    protected void map(LongWritable key, Text value, Context context) throws IOException, InterruptedException {
        String[] split = value.toString().split(" ");
        for (String s : split) {
            context.write(new Text(s), new LongWritable(1));
ReduceAction
import org.apache.hadoop.mapreduce.Reducer;
public class ReduceAction extends Reducer<Text, LongWritable, Text, LongWritable> {
    @Override
    protected void reduce(Text key, Iterable<LongWritable> values, Context context) throws IOException, InterruptedException {
        long count = 0;
        for (LongWritable value : values) {
            count += value.get();
        context.write(key, new LongWritable(count));
Action
import org.apache.hadoop.conf.Configuration;
import org.apache.hadoop.fs.Path;
import org.apache.hadoop.mapreduce.Job;
import org.apache.hadoop.mapreduce.lib.input.FileInputFormat;
import org.apache.hadoop.mapreduce.lib.output.FileOutputFormat;
public class Action {
    public static void main(String[] args) throws IOException, ClassNotFoundException, InterruptedException {
        Configuration conf = new Configuration();
        Job job = Job.getInstance(conf);
        job.setJarByClass(Action.class);
        job.setMapperClass(MapAction.class);
        job.setReducerClass(ReduceAction.class);
        job.setMapOutputKeyClass(Text.class);
        job.setMapOutputValueClass(LongWritable.class);
        job.setOutputKeyClass(Text.class);
        job.setOutputValueClass(LongWritable.class);
        FileInputFormat.setInputPaths(job,new Path("/abcd/info.txt"));
        FileOutputFormat.setOutputPath(job,new Path("/infos"));
        boolean b = job.waitForCompletion(true);
        System.exit(b?0:1);
 生成jar包
 讲jar放在【/opt/soft/hadoop/share/hadoop/mapreduce】中
预先上传文件作用记录【info.txt】
asdasd asd asdhkajshas jdhasjk djkas hdas hdj sa
dashkj dajks d jksa hdas hjkd haksj dsa
dsaji djkas  kjdsah jdh askjdhkjash kj
adhjks djak dja hsjkdsakhd
hadoop fs -mkdir /abcd
hadoop fs -put info.txt /abcd
执行
hadoop jar T9_1.jar com/item.test/Action /abcde/info.txt /infos
查看结果
hadoop fs -cat /infos/part-r-00000
