PAT甲级——1153.Decode Registration Card of PAT(25分)
陈沧夜 发表于 2022/04/29 22:14:48 2022/04/29
【摘要】 A registration card number of PAT consists of 4 parts: the 1st letter represents the test level, name...
  • the 1st letter represents the test level, namely, T for the top level, A for advance and B for basic;
  • the 2nd - 4th digits are the test site number, ranged from 101 to 999;
  • the 5th - 10th digits give the test date, in the form of yymmdd;
  • finally the 11th - 13th digits are the testee’s number, ranged from 000 to 999.
Now given a set of registration card numbers and the scores of the card owners, you are supposed to output the various statistics according to the given queries.
Input Specification:
Each input file contains one test case. For each case, the first line gives two positive integers N (≤104) and M (≤100), the numbers of cards and the queries, respectively.
Then N lines follow, each gives a card number and the owner’s score (integer in [0,100]), separated by a space.
After the info of testees, there are M lines, each gives a query in the format Type Term, where
  • Type being 1 means to output all the testees on a given level, in non-increasing order of their scores. The corresponding Term will be the letter which specifies the level;
  • Type being 2 means to output the total number of testees together with their total scores in a given site. The corresponding Term will then be the site number;
  • Type being 3 means to output the total number of testees of every site for a given test date. The corresponding Term will then be the date, given in the same format as in the registration card.
Output Specification:
For each query, first print in a line Case #: input, where # is the index of the query case, starting from 1; and input is a copy of the corresponding input query. Then output as requested:
  • for a type 1 query, the output format is the same as in input, that is, CardNumber Score. If there is a tie of the scores, output in increasing alphabetical order of their card numbers (uniqueness of the card numbers is guaranteed);
  • for a type 2 query, output in the format Nt Ns where Nt is the total number of testees and Ns is their total score;
  • for a type 3 query, output in the format Site Nt where Site is the site number and Nt is the total number of testees at Site. The output must be in non-increasing order of Nt's, or in increasing order of site numbers if there is a tie of Nt.
If the result of a query is empty, simply print NA.
Sample Input:
8 4
B123180908127 99
B102180908003 86
A112180318002 98
T107150310127 62
A107180908108 100
T123180908010 78
B112160918035 88
A107180908021 98
1 A
2 107
3 180908
2 999
Sample Output:
Case 1: 1 A
A107180908108 100
A107180908021 98
A112180318002 98
Case 2: 2 107
3 260
Case 3: 3 180908
107 2
123 2
102 1
Case 4: 2 999
NA
这题…emmm, 用的柳婼的题解,一开始不太习惯这种题目。
//1 -->T,A,B
//2-4  -->考点 101-999
//5-10 -->data yymmdd
//11-13 -->考试数字 000-999
#include <iostream>
#include <vector>
#include <unordered_map>
#include <algorithm>
using namespace std;
struct node {
    string t;
    int value;
bool cmp(const node &a, const node &b) {
    return a.value != b.value ? a.value > b.value : a.t < b.t;  //三目运算符
int main() {
    int n, k, num;
    string s;
    cin >> n >> k;
    vector<node> v(n);
    for (int i = 0; i < n; i++)
        cin >> v[i].t >> v[i].value;
    for (int i = 1; i <= k; i++) {
        cin >> num >> s;
        printf("Case %d: %d %s\n", i, num, s.c_str()); //c_str()将string转化为c语言的数组
        vector<node> ans;
        int cnt = 0, sum = 0;
        if (num == 1) {
            for (int j = 0; j < n; j++)
                if (v[j].t[0] == s[0]) ans.push_back(v[j]);
        else if (num == 2) {
            for (int j = 0; j < n; j++) {
                if (v[j].t.substr(1, 3) == s) {
                    cnt++;
                    sum += v[j].value;
            if (cnt != 0) printf("%d %d\n", cnt, sum);
        else if (num == 3) {
            unordered_map<string, int> m;
                if (v[j].t.substr(4, 6) == s) m[v[j].t.substr(1, 3)]++;
            for (auto it : m) ans.push_back({it.first, it.second});
        sort(ans.begin(), ans.end(),cmp);
        for (int j = 0; j < ans.size(); j++)
            printf("%s %d\n", ans[j].t.c_str(), ans[j].value);
        if (((num == 1 || num == 3) && ans.size() == 0) || (num == 2 && cnt ==
        0)) printf("NA\n");
    return 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
文章来源: blog.csdn.net,作者:沧夜2021,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/CANGYE0504/article/details/104203645
