相交链表 | 环形链表
跳动的bit 发表于 2022/04/27 07:13:58 2022/04/27
【摘要】 3.相交链表<难度系数⭐>📝 题述:给你两个单链表的头节点 headA 和 headB ,请你找出并返回两个单链表相交的起始节点。如果两个链表没有交点,返回 null。(保证整个链式结构中不存在环且函数返回结果后,链表必须保持其原始结构。)⚠ 注意,其一,以下这种结构实际并不存在,因为3和1可以同时指向4,但4不能同时指向5和6。其二,这里比较的是节点的地址,不是节点的值💨 示例1:输...
3.相交链表<难度系数⭐>
💨 示例1:
输入:intersectVal = 8, listA = [4,1,8,4,5], listB = [5,0,1,8,4,5], skipA = 2, skipB = 3
输出:Intersected at ‘8’
💨 示例2:
输入:intersectVal = 2, listA = [0,9,1,2,4], listB = [3,2,4], skipA = 3, skipB = 1
输出:Intersected at ‘2’
💨 示例3:
输入:intersectVal = 0, listA = [2,6,4], listB = [1,5], skipA = 3, skipB = 2
输出:null
🧷 平台:Visual studio 2017 && windows
🔑 核心思想:
常规暴力求解,A链表的每个节点和B链表的每个节点比较,如果有相同的就是交点,如果没有就不相交 (注意是节点的地址),时间复杂度O(N^2)
对常规的方法进行优化:分别算出A和B的长度 lenA、lenB,让长的链表先走|lenA-lenB|,再同时走找交点,时间复杂度O(N)
请添加图片描述
leetcode原题
#include<stdio.h>
#include<stdlib.h>
typedef int SLTDataType;
struct ListNode
	int val;
	struct ListNode *next;
struct ListNode *getIntersectionNode(struct ListNode *headA, struct ListNode *headB)
    struct ListNode* curA = headA;
    struct ListNode* curB = headB;
    int lenA = 0, lenB = 0;
    //计算链表的长度
    while(curA)
        lenA++;
        curA = curA->next;
    while(curB)
        lenB++;
        curB = curB->next;
    //先假设A长B短
    struct ListNode* longList = headA;
    struct ListNode* shortList = headB;
    //如果假设错了,就交换下
    if(lenA < lenB)
        longList = headB;
        shortList = headA;
    //让长的走差距步
    int gap = abs(lenA-lenB);
    while(gap--)
        longList = longList->next;
    //长的和短的同时走
    while(longList && shortList)
        //找到了,相交
        if(longList == shortList)
            return longList;
        //没找到继续走
        shortList = shortList->next;
    //没找到,不相交
    return NULL;
int main()
	struct ListNode* n1 = (struct ListNode*)malloc(sizeof(struct ListNode));
	n1->val = 4;
	struct ListNode* n2 = (struct ListNode*)malloc(sizeof(struct ListNode));
	n2->val = 1;
	struct ListNode* m1 = (struct ListNode*)malloc(sizeof(struct ListNode));
	m1->val = 5;
	struct ListNode* m2 = (struct ListNode*)malloc(sizeof(struct ListNode));
	m2->val = 0;
	struct ListNode* m3 = (struct ListNode*)malloc(sizeof(struct ListNode));
	m3->val = 1;
	struct ListNode* u1 = (struct ListNode*)malloc(sizeof(struct ListNode));
	u1->val = 8;
	struct ListNode* u2 = (struct ListNode*)malloc(sizeof(struct ListNode));
	u2->val = 4;
	struct ListNode* u3 = (struct ListNode*)malloc(sizeof(struct ListNode));
	u3->val = 5;
	//上节点
	n1->next = n2;
	n2->next = u1;
	u1->next = u2;
	u2->next = u3;
	u3->next = NULL;
	//下节点
	m1->next = m2;
	m2->next = m3;
	m3->next = u1;
	u1->next = u2;
	u2->next = u3;
	u3->next = NULL;
	getIntersectionNode(n1, m1);
	return 0;
4.环形链表<难度系数⭐>
📝 题述:给定一个链表,判断链表中是否有环。
如果链表中有某个节点,可以通过连续跟踪 next 指针再次到达,则链表中存在环。 为了表示给定链表中的环,我们使用整数 pos 来表示链表尾连接到链表中的位置(索引从 0 开始)。 如果 pos 是 -1,则在该链表中没有环。注意:pos 不作为参数进行传递,仅仅是为了标识链表的实际情况。如果链表中存在环,则返回 true 。 否则,返回 false 。
带环链表不能轻易的去遍历,否则会死循环
💨 示例1:
输入:head = [3,2,0,-4], pos = 1
输出:true
💨 示例2:
输入:head = [1,2], pos = 0
输出:true
💨 示例3:
输入:head = [1], pos = -1
输出:false
🔑 核心思想:
快慢指针,如果快指针和慢指针相遇了就是带环的,否则快指针指向空时就是不带环的
请添加图片描述
leetcode原题
#include<stdio.h>
#include<stdlib.h>
#include<stdbool.h>
struct ListNode
	int val;
bool hasCycle(struct ListNode* head)
    struct ListNode *slow = head, *fast = head;
    while(fast && fast->next)
        slow = slow->next;
        fast = fast->next->next;
        //相遇即带环
        if(slow == fast)
            return true;
    //不带环
    return false;
int main()
	n1->val = 1;
	n2->val = 2;
	struct ListNode* n3 = (struct ListNode*)malloc(sizeof(struct ListNode));
	n3->val = 3;
	struct ListNode* n4 = (struct ListNode*)malloc(sizeof(struct ListNode));
	n4->val = 4;
	struct ListNode* n5 = (struct ListNode*)malloc(sizeof(struct ListNode));
	n5->val = 5;
	n1->next = n2;
	n2->next = n3;
	n3->next = n4;
	n4->next = n5;
	n5->next = n3;
	hasCycle(n1);
	return 0;
其实这道题并不难,相对较难的是这道题的延伸:
🧿 slow一次走一步,fast一次走两步,fast一定可以相遇slow吗?请证明
请添加图片描述
slow一次走一步,fast一次走两步时,它们一定可以相遇
slow进环时,fast已经在环里走一会了,那么这时在环内就产生了fast追赶slow的现象。假设环的长度是C、slow进环时,fast和slow之间的距离是N,那么进环后fast和slow之间的距离变化是:
N
N-1
N-2
2
1
0   
slow和fast之间的距离是0的时候就能相遇,同时也说明了N为奇或偶时都能相遇
最简单的理解就是:fast每次都以一步的距离追赶slow,slow走一步,fast走二步可以等同于slow不走,fast走一步,
🧿 slow一次走一步,fast一次走n步(n > 2,3,4,5…),fast一定可以相遇slow吗?请证明
请添加图片描述
slow一次走一步,fast一次走n步时,它们不一定可以相遇
假设slow一次走1步,fast一次走3步,假设环的长度是C、slow进环时,fast和slow之间的距离是N。那么进环后fast和slow之间的距离变化是:
偶     奇
N      N
N-2   N-2
N-4   N-4
2     1
0    -1   -1相当于它们的距离变成了C-1
slow和fast之间的距离是0的时候就能相遇,同时说明N是偶数时,就一定能相遇(假设N是奇数,且C-1也是奇数,就永远不能相遇)
最简单的理解就是:fast每次都以2步的距离追赶slow,slow走一步,fast走三步可以等同于slow不走,fast走二步,
💨 总结
fast一次走x步,slow一次走y步都是可以的,但最重要的是追赶过程中的步差x-y。步差是1,一定能追上;步差不是1,不一定能追上
5.环形链表<难度系数⭐⭐>
📝 题述:给定一个链表,返回链表开始入环的第一个节点。 如果链表无环,则返回 null。为了表示给定链表中的环,我们使用整数 pos 来表示链表尾连接到链表中的位置(索引从 0 开始)。 如果 pos 是 -1,则在该链表中没有环。注意,pos 仅仅是用于标识环的情况,并不会作为参数传递到函数中。说明:不允许修改给定的链表。进阶:使用 O(1) 空间解决此题
💨 示例1:
输出:返回索引为 1 的链表节点
💨 示例2:
输出:返回索引为 0 的链表节点
💨 示例3:
输出:返回 null
🔑 核心思想:
思路一,一个指针从相遇点走,另一个指针从head走,它们会在入口点相遇(待证)
请添加图片描述
思路二,把相遇点的位置断开,这时就变成了相交问题(调用之前实现的相交函数)
请添加图片描述
leetcode原题
#include<stdio.h>
#include<stdlib.h>
struct ListNode
	int val;
//思路一
struct ListNode* detectCycle1(struct ListNode *head)
    //结束条件:无环,快指针走到空了;有环,返回入环的节点
        slow = slow->next;
        //相遇了
        if(slow == fast)
            //记录相遇的节点
            struct ListNode* meet = slow;
            //头节点和相遇点同时走,它们会在入口点相遇,也就是说在入口点时,头节点和相遇点是相同的
            while(head != meet)
                head = head->next;
                meet = meet->next;
            //有环,返回相遇节点
            return meet;
    //无环,返回空
    return NULL;
//思路二
    //计算链表的长度
    while(curA)
        lenA++;
        curA = curA->next;
    while(curB)
        lenB++;
        curB = curB->next;
    //先假设A长B短
    //如果假设错了,就交换下
    if(lenA < lenB)
        longList = headB;
        shortList = headA;
    //让长的走差距步
    while(gap--)
    //长的和短的同时走
        //找到了,相交
            return longList;
        //没找到继续走
    //没找到,不相交
    return NULL;
struct ListNode* detectCycle2(struct ListNode *head)
   struct ListNode *slow, *fast;
   slow = fast = head;
       slow = slow->next;
       //带环相遇点
       if(slow == fast)
           //断开
           struct ListNode* next = meet->next;
           meet->next = NULL;
           return getIntersectionNode(head, next);
   return NULL;
int main()
	n1->val = 1;
	n2->val = 2;
	n3->val = 3;
	n4->val = 4;
	n5->val = 5;
	n1->next = n2;
	n2->next = n3;
	n3->next = n4;
	n4->next = n5;
	n5->next = n3;
	detectCycle1(n1);
	detectCycle2(n1);
	return 0;
🧿 证明:一个指针从相遇点走,另一个指针从head走,它们会在入口点相遇
假设链表头到入口点的距离是L,假设相遇点到入口点的距离是X,假设环的长度是C。
错误推论:当快慢指针相遇时,慢指针走的长度是L+X,快指针走的长度是L+C+X,由此就可以推出2(L+X) = L+C+X,再推出L+X=C,L= C-X。看似没毛病,但实际这个推导是错的,因为slow进环前,fast不一定在环里只走一圈
请添加图片描述
正确推论:慢指针走的长度是L+X,快指针走的长度是L+N * C+X (N表示圈数&&N>=1)。由此就可以推出2(L+X) = L+N * C+X ,再推出L+X=N*C,L=N * C-X,可分解为L=(N-1) * C+C-X,(N-1) * C表示从相遇点走了N-1圈,C-X表示相遇点到入口的距离。最后通过这个公式就可以推出一个指针从链表头走,一个指针从相遇点走,会在入口点相遇。
请添加图片描述
请添加图片描述
