Sentinel服务熔断实战(sentinel整合ribbon+openFeign+fallback)
别团等shy哥发育 发表于 2022/04/23 15:57:13 2022/04/23
【摘要】 @toc源码地址:gitee仓库地址 1、Ribbon系列 1.1 启动nacos和sentinel 1.2 创建两个服务提供者payment9003和payment9004  新建cloudalibaba-provider-payment9003/9004两个一样的做法  由于9003和9004除了端口号不一样,其他几乎一致,这里只演示9003端口的搭建方式。  pom.xml <dep...
@toc
源码地址:gitee仓库地址
1、Ribbon系列
image-20220416234815852
image-20220416234829591
image-20220416235040599
  pom.xml
  <dependencies>
        <!--SpringCloud ailibaba nacos -->
        <dependency>
            <groupId>com.alibaba.cloud</groupId>
            <artifactId>spring-cloud-starter-alibaba-nacos-discovery</artifactId>
        </dependency>
        <dependency><!-- 引入自己定义的api通用包,可以使用Payment支付Entity -->
            <groupId>com.atguigu.springcloud</groupId>
            <artifactId>cloud-api-commons</artifactId>
            <version>${project.version}</version>
        </dependency>
        <!-- SpringBoot整合Web组件 -->
        <dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-actuator</artifactId>
        </dependency>
        <!--日常通用jar包配置-->
        <dependency>
            <artifactId>spring-boot-devtools</artifactId>
            <scope>runtime</scope>
            <optional>true</optional>
        </dependency>
        <dependency>
            <groupId>org.projectlombok</groupId>
            <artifactId>lombok</artifactId>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-test</artifactId>
            <scope>test</scope>
        </dependency>
    </dependencies>
  application.yml
server:
  port: 9003
spring:
  application:
  cloud:
    nacos:
      discovery:
        server-addr: localhost:8848 #配置Nacos地址
management:
  endpoints:
    web:
      exposure:
        include: '*'
  记得修改不同的端口号
  主启动类
@SpringBootApplication
@EnableDiscoveryClient
public class PaymentMain9003
            SpringApplication.run(PaymentMain9003.class, args);
  业务类
@RestController
public class PaymentController
    @Value("${server.port}")
    private String serverPort;
    public static HashMap<Long,Payment> hashMap = new HashMap<>();
    static
        hashMap.put(1L,new Payment(1L,"28a8c1e3bc2742d8848569891fb42181"));
        hashMap.put(2L,new Payment(2L,"bba8c1e3bc2742d8848569891ac32182"));
        hashMap.put(3L,new Payment(3L,"6ua8c1e3bc2742d8848569891xt92183"));
    @GetMapping(value = "/paymentSQL/{id}")
    public CommonResult<Payment> paymentSQL(@PathVariable("id") Long id)
        Payment payment = hashMap.get(id);
        CommonResult<Payment> result = new CommonResult(200,"from mysql,serverPort:  "+serverPort,payment);
        return result;
  这里为了测试,并没有去连接数据库,模拟了几个数据,效果都是一样的。
  启动服务并测试业务类是否正常:http://localhost:9003/paymentSQL/1
image-20220416235755999
  http://localhost:9004/paymentSQL/1
image-20220416235931322
   两个服务提供者搭建成功。
1.3 搭建服务消费者order84
1.3.1 基础模块搭建
  新建cloudalibaba-consumer-nacos-order84
image-20220417000034209
  pom.xml
<dependencies>
        <dependency>
        </dependency>
        <!--SpringCloud ailibaba sentinel -->
        <dependency>
            <artifactId>spring-cloud-starter-alibaba-sentinel</artifactId>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <!--日常通用jar包配置-->
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <scope>test</scope>
        </dependency>
    </dependencies>
  application.yml
server:
  port: 84
spring:
  application:
  cloud:
    nacos:
      discovery:
    sentinel:
      transport:
        #配置Sentinel dashboard地址
        dashboard: localhost:8080
        #默认8719端口,假如被占用会自动从8719开始依次+1扫描,直至找到未被占用的端口
        port: 8719
#消费者将要去访问的微服务名称(注册成功进nacos的微服务提供者)
service-url:
  nacos-user-service: http://nacos-payment-provider
  主启动类
public class OrderNacosMain84
            SpringApplication.run(OrderNacosMain84.class, args);
  业务类
  负载均衡配置:
@Configuration
public class ApplicationContextConfig
    @Bean
    @LoadBalanced
    public RestTemplate getRestTemplate()
        return new RestTemplate();
  CircleBreakerController
@RestController
@Slf4j
public class CircleBreakerController
    public static final String SERVICE_URL = "http://nacos-payment-provider";
    @Resource
    private RestTemplate restTemplate;
    @RequestMapping("/consumer/fallback/{id}")
    @SentinelResource(value = "fallback")
     public CommonResult<Payment> fallback(@PathVariable Long id)
        CommonResult<Payment> result = restTemplate.getForObject(SERVICE_URL + "/paymentSQL/"+id,CommonResult.class,id);
        if (id == 4) {
            throw new IllegalArgumentException ("IllegalArgumentException,非法参数异常....");
        }else if (result.getData() == null) {
            throw new NullPointerException ("NullPointerException,该ID没有对应记录,空指针异常");
        return result;
  上面代码在id=1/2/3时正常,id=4时抛出IllegalArgumentException异常,大于4的时候抛出空指针异常。
  这里的测试目的:fallback管运行异常,blockHandler管配置违规
  上面并没有配置@SentinelResource,会直接给客户返回error页面,非常不友好。
1.3.2 只配置fallback
//    @SentinelResource(value = "fallback")
    @SentinelResource(value = "fallback",fallback = "handlerFallback")
        if (id == 4) {
        return result;
//    //fallback方法
    public CommonResult handlerFallback(@PathVariable  Long id,Throwable e) {
        Payment payment = new Payment(id,"null");
        return new CommonResult<>(444,"兜底异常handlerFallback,exception内容  "+e.getMessage(),payment);
  注意:这里并没有配置sentinel。
  访问测试:
  http://localhost:84/consumer/fallback/1
image-20220417000937192
  http://localhost:84/consumer/fallback/4
image-20220417000956764
  http://localhost:84/consumer/fallback/5
image-20220417001012956
  此时就执行指定的fallback,对调用者比较友好。
1.3.3 只配置blockHandler
    @SentinelResource(value = "fallback",blockHandler = "blockHandler")
        if (id == 4) {
        return result;
//    //fallback方法
//    public CommonResult handlerFallback(@PathVariable  Long id,Throwable e) {
//        Payment payment = new Payment(id,"null");
//        return new CommonResult<>(444,"兜底异常handlerFallback,exception内容  "+e.getMessage(),payment);
    //blockHandler
    public CommonResult blockHandler(@PathVariable  Long id, BlockException blockException) {
        return new CommonResult<>(445,"blockHandler-sentinel限流,无此流水: blockException  "+blockException.getMessage(),payment);
  这里需要配置下sentinel
image-20220417001348466
image-20220417001420614
  异常超过2次以后,断路器打开,断电跳闸,系统被保护。
image-20220417001915291
  测试:
  第一次访问:http://localhost:84/consumer/fallback/4
image-20220417002558240
  发现还是给了个error页面,注意,我们上面配置的是当异常数大于2的时候断路器才会打开。
  再访问几次。
image-20220417002701266
   可以看到,被限流了。
1.3.4 fallback和blockHandler都配置
//    @SentinelResource(value = "fallback",fallback = "handlerFallback")
//    @SentinelResource(value = "fallback",blockHandler = "blockHandler") //blockHandler负责在sentinel里面配置的降级限流
            fallback = "handlerFallback",
            blockHandler = "blockHandler",
        if (id == 4) {
        return result;
    //fallback方法
//    //blockHandler
image-20220417002941407
   这里需要配置Sentinel流控
image-20220417003808238
  配置解释:1秒只能处理1个请求,否则就限流。
  我们测试,http://localhost:84/consumer/fallback/4,一直频繁访问触发限流降级。
image-20220417004423470
  ==结论:若 blockHandler 和 fallback 都进行了配置,则被限流降级而抛出 BlockException 时只会进入 blockHandler 处理逻辑。==
1.3.5 忽略属性配置
image-20220417004520079
  我们给@SentinelResource注解添加配置exceptionsToIgnore = {IllegalArgumentException.class}
  此时如果我们传的参数id=4,则会忽略IllegalArgumentException异常。
  此时再访问:http://localhost:84/consumer/fallback/4
image-20220417004715815
   此时异常打印到前台了,对用户不友好。
2、Feign系列
  我们一般服务调用都是使用OpenFeign的,在FeignClient中统一处理fallback
2.1 修改84模块。
  在服务消费者(order84)模块中引入OpenFeign
 <!--SpringCloud openfeign -->
        <dependency>
            <groupId>org.springframework.cloud</groupId>
            <artifactId>spring-cloud-starter-openfeign</artifactId>
        </dependency>
image-20220417005307090
2.2 配置文件application.yml中激活Sentinel对Feign的支持
image-20220417005354023
2.3 业务类
  带@FeignClient注解的业务接口
 * 使用 fallback 方式是无法获取异常信息的,
 * 如果想要获取异常信息,可以使用 fallbackFactory参数
@FeignClient(value = "nacos-payment-provider",fallback = PaymentFallbackService.class)//调用中关闭9003服务提供者
public interface PaymentService
    public CommonResult<Payment> paymentSQL(@PathVariable("id") Long id);
  fallback = PaymentFallbackService.class的实现类
@Component
public class PaymentFallbackService implements PaymentService
    @Override
    public CommonResult<Payment> paymentSQL(Long id)
        return new CommonResult<>(44444444,"服务降级返回,-------PaymentFallbackService",new Payment(id, "errorSerial......"));
  Controller:
image-20220417014201295
  主启动类
  添加@EnableFeignClients启动Feign的功能
image-20220417014252214
  访问测试:http://localhost:84/consumer/paymentSQL/1
image-20220417014508218
  测试84调用9003,此时故意关闭9003微服务提供者,看84消费侧自动降级,不会被耗死
  关闭9003的服务提供者
image-20220417014536417
  再次访问http://localhost:84/consumer/paymentSQL/1
image-20220417014600726
  可以看到,已经出发了服务降级。返回的是我们在FeignClient接口中指定的falback。
3、三种熔断框架比较
image-20220417014729090
  到此,Sentinel整合服务熔断的测试就介绍完了,关于Sentinel限流那块配置太多,不好细讲,最好去看看官网。我去年也发过限流的文章,去我SpringCloud Alibaba专栏里面找
