oracle连接失败-ORA-12537
snowofsummer 发表于 2022/04/22 16:55:08 2022/04/22
【摘要】 数据库报错日志信息:ORA-12537客户端报错信息:监听日志报错:监听状态:oracle权限:故障解决方案:参考Doc ID 1069517.1检查发现grid用户无权限访问oracle目录权限:解决方案:Solution is to make sure file system for database home has setuid/suid set, database binary($...
数据库报错日志信息:
ORA-12537
客户端报错信息:
监听日志报错:
监听状态:
oracle权限:
故障解决方案:
参考Doc ID 1069517.1
解决方案:
Solution is to make sure file system for database home has setuid/suid set, database binary($RDBMS_HOME/bin/oracle) has correct ownership and permission, and listener owner is able to access database oracle binary (as listener owner, "ls -l $RDBMS_HOME/bin/oracle" will tell)
