【人工智能】机器学习之使用Python生成ID3决策树及使用sklearn的决策树算法对葡萄酒数据集进行分类
南蓬幽 发表于 2022/04/22 10:33:36 2022/04/22
【摘要】 ❤❤❤ID3算法 ✅✅决策树的思想:给定一个集合,其中的每个样本由若干属性表示,决策树通过贪心的策略不断挑选最优的属性。常见的决策树算法有ID3,C4.5,CART算法等。 💤💤💤ID3算法: baseEntropy = self.calcShannonEnt(dataset) # 基础熵 num = len(dataset) # 样本总数 ...
❤❤❤ID3算法
✅✅决策树的思想:
💤💤💤ID3算法:
        #子集中的概率
        subDataSet = self.splitDataSet(dataset, i, val)
        prob = len(subDataSet) / float(num)
        # 条件熵
        newEntropy += prob * self.calcShannonEnt(subDataSet)
        # 信息增益
        infoGain = baseEntropy - newEntropy
💯1.先写绘图树方法,函数。
decisionNode = dict(boxstyle="sawtooth", fc="0.8")
leafNode = dict(boxstyle="round4", fc="0.8")
arrow_args = dict(arrowstyle="<-")
def plotNode(nodeTxt, centerPt, parentPt, nodeType):
    createPlot.ax1.annotate(nodeTxt, xy=parentPt, xycoords='axes fraction', \
                            xytext=centerPt, textcoords='axes fraction', \
                            va="center", ha="center", bbox=nodeType, arrowprops=arrow_args)
def getNumLeafs(myTree):
    numLeafs = 0
    firstStr = list(myTree.keys())[0]
    secondDict = myTree[firstStr]
    for key in secondDict.keys():
        if type(secondDict[key]).__name__ == 'dict':
            numLeafs += getNumLeafs(secondDict[key])
        else:
            numLeafs += 1
    return numLeafs
def getTreeDepth(myTree):
    maxDepth = 0
            thisDepth = getTreeDepth(secondDict[key]) + 1
        else:
            thisDepth = 1
        if thisDepth > maxDepth:
            maxDepth = thisDepth
    return maxDepth
def plotMidText(cntrPt, parentPt, txtString):
    xMid = (parentPt[0] - cntrPt[0]) / 2.0 + cntrPt[0]
    yMid = (parentPt[1] - cntrPt[1]) / 2.0 + cntrPt[1]
    createPlot.ax1.text(xMid, yMid, txtString)
def plotTree(myTree, parentPt, nodeTxt):
    numLeafs = getNumLeafs(myTree)
    depth = getTreeDepth(myTree)
    cntrPt = (plotTree.xOff + (1.0 + float(numLeafs)) / 2.0 / plotTree.totalw, plotTree.yOff)
    plotMidText(cntrPt, parentPt, nodeTxt)
    plotNode(firstStr, cntrPt, parentPt, decisionNode)
    plotTree.yOff = plotTree.yOff - 1.0 / plotTree.totalD
            plotTree(secondDict[key], cntrPt, str(key))
        else:
            plotTree.xOff = plotTree.xOff + 1.0 / plotTree.totalw
            plotNode(secondDict[key], (plotTree.xOff, plotTree.yOff), cntrPt, leafNode)
            plotMidText((plotTree.xOff, plotTree.yOff), cntrPt, str(key))
    plotTree.yOff = plotTree.yOff + 1.0 / plotTree.totalD
def createPlot(inTree):
    fig = plt.figure(1, facecolor='white')
    fig.clf()
    axprops = dict(xticks=[], yticks=[])
    createPlot.ax1 = plt.subplot(111, frameon=False, **axprops)
    plotTree.totalw = float(getNumLeafs(inTree))
    plotTree.totalD = float(getTreeDepth(inTree))
    plotTree.xOff = -0.5 / plotTree.totalw
    plotTree.yOff = 1.0
    plotTree(inTree, (0.5, 1.0), '')
    plt.show()
💯2.ID3决策树类
class ID3Tree(object):
    def __init__(self):
        self.tree = {}  # ID3 Tree
        self.dataSet = []  # 数据集
        self.labels = []  # 标签集
    def getDataSet(self, dataset, labels):
        self.dataSet = dataset
        self.labels = labels
    def train(self):
        # labels = copy.deepcopy(self.labels)
        labels = self.labels[:]
        self.tree = self.buildTree(self.dataSet, labels)
    def buildTree(self, dataSet, labels):
        classList = [ds[-1] for ds in dataSet]  # 提取样本的类别
        if classList.count(classList[0]) == len(classList):  # 单一类别
            return classList[0]
        if len(dataSet[0]) == 1:  # 没有属性需要划分了
            return self.classify(classList)
        bestFeat = self.findBestSplit(dataSet)  # 选取最大增益的属性序号
        bestFeatLabel = labels[bestFeat]
        tree = {bestFeatLabel: {}}  # 构造一个新的树结点
        del (labels[bestFeat])  # 从总属性列表中去除最大增益属性
        featValues = [ds[bestFeat] for ds in dataSet]  # 抽取最大增益属性的取值列表
        uniqueFeatValues = set(featValues)  # 选取最大增益属性的数值类别
        for value in uniqueFeatValues:  # 对于每一个属性类别
            subLabels = labels[:]
            subDataSet = self.splitDataSet(dataSet, bestFeat, value)  # 分裂结点
            subTree = self.buildTree(subDataSet, subLabels)  # 递归构造子树
            tree[bestFeatLabel][value] = subTree
        return tree
    # 计算出现次数最多的类别标签
    def classify(self, classList):
        items = dict([(classList.count(i), i) for i in classList])
        return items[max(items.keys())]
    # 计算最优特征
    def findBestSplit(self, dataset):
        numFeatures = len(dataset[0]) - 1
        bestInfoGain = 0.0
        bestFeat = -1  # 初始化最优特征向量轴
        # 遍历数据集各列,寻找最优特征轴
        for i in range(numFeatures):
            featValues = [ds[i] for ds in dataset]
            newEntropy = 0.0
            # 按列和唯一值,计算信息熵
            for val in uniqueFeatValues:
                prob = len(subDataSet) / float(num) # 子集中的概率
            infoGain = baseEntropy - newEntropy # 信息增益
            if infoGain > bestInfoGain: # 挑选最大值
                bestInfoGain = baseEntropy - newEntropy
                bestFeat = i
        return bestFeat
    # 从dataset数据集的feat特征中,选取值为value的数据
    def splitDataSet(self, dataset, feat, values):
        retDataSet = []
        for featVec in dataset:
            if featVec[feat] == values:
                reducedFeatVec = featVec[:feat]
                reducedFeatVec.extend(featVec[feat + 1:])
                retDataSet.append(reducedFeatVec)
        return retDataSet
    # 计算dataSet的信息熵
    def calcShannonEnt(self, dataSet):
        num = len(dataSet)  # 样本集总数
        classList = [c[-1] for c in dataSet]  # 抽取分类信息
        labelCounts = {}
        for cs in set(classList):  # 对每个分类进行计数
            labelCounts[cs] = classList.count(cs)
        shannonEnt = 0.0
        for key in labelCounts:
            prob = labelCounts[key] / float(num)
            shannonEnt -= prob * log2(prob)
        return shannonEnt
    # 预测。对输入对象进行ID3分类
    def predict(self, tree, newObject):
        #    判断输入值是否为“dict”
        while type(tree).__name__ == 'dict':
            key = list(tree.keys())[0]
            tree = tree[key][newObject[key]]
        return tree
💲💲💲给出数据集,标签集:
dataSet = [[1, 1, 1, 1,1, 1, ‘Yes’],
[2, 1, 2, 1,1, 1, ‘Yes’],
[2, 1, 1, 1,1, 1, ‘Yes’],
[1, 1, 2, 1,1, 1, ‘Yes’],
[3, 1, 1, 1,1, 1, ‘Yes’],
[1,2, 1, 1,2, 2, ‘Yes’],
[2, 2, 1, 2,2, 2, ‘Yes’],
[2, 2, 1, 1,2, 1, ‘Yes’],
[2, 2, 2, 2,2, 1, ‘No’],
[1,3, 3, 1,3, 2, ‘No’],
[3, 3, 3, 3,3, 1, ‘No’],
[3, 1, 1, 3,3, 2, ‘No’],
[1, 2, 1, 2,1, 1, ‘No’],
[3,2, 2, 2,1, 1, ‘No’],
[2, 2, 1, 1,2, 2, ‘No’],
[3, 1, 1, 3,3, 1, ‘No’],
[1, 1, 2, 2,2, 1, ‘No’],]
    #'色泽', '根蒂', '敲声', '纹理','脐部', '触感'
    features = ['seze', 'gendi', 'qiaosheng', 'wenli','qibu', 'chugan']
💞💞完整代码
from math import log2
import treePlotter
    def __init__(self):
    def train(self):
            return classList[0]
        return tree
    # 计算出现次数最多的类别标签
    # 计算最优特征
        bestInfoGain = 0.0
        # 遍历数据集各列,寻找最优特征轴
            newEntropy = 0.0
            # 按列和唯一值,计算信息熵
                bestFeat = i
        return bestFeat
        retDataSet = []
        return retDataSet
    # 计算dataSet的信息熵
        labelCounts = {}
        shannonEnt = 0.0
        return shannonEnt
    # 预测。对输入对象进行ID3分类
        #    判断输入值是否为“dict”
        return tree
if __name__ == '__main__':
    def createDataSet():
        dataSet = [[1, 1, 1, 1,1, 1, 'Yes'],
                   [2, 1, 2, 1,1, 1, 'Yes'],
                   [2, 1, 1, 1,1, 1, 'Yes'],
                   [1, 1, 2, 1,1, 1, 'Yes'],
                   [3, 1, 1, 1,1, 1, 'Yes'],
                   [1,2, 1, 1,2, 2, 'Yes'],
                   [2, 2, 1, 2,2, 2, 'Yes'],
                   [2, 2, 1, 1,2, 1, 'Yes'],
                   [2, 2, 2, 2,2, 1, 'No'],
                   [1,3, 3, 1,3, 2, 'No'],
                   [3, 3, 3, 3,3, 1, 'No'],
                   [3, 1, 1, 3,3, 2, 'No'],
                   [1, 2, 1, 2,1, 1, 'No'],
                   [3,2, 2, 2,1, 1, 'No'],
                   [2, 2, 1, 1,2, 2, 'No'],
                   [3, 1, 1, 3,3, 1, 'No'],
                   [1, 1, 2, 2,2, 1, 'No'],]
        return dataSet, features
    id3 = ID3Tree()  # 创建一个ID3决策树
    ds, labels = createDataSet()
    id3.getDataSet(ds, labels)
    id3.train()  # 训练ID3决策树
    print(id3.tree)  # 输出ID3决策树
    print(id3.predict(id3.tree,{'seze':2,'gendi':2,'qiaosheng':1,'wenli':1,'qibu':1,'chugan':1}))
    treePlotter.createPlot(id3.tree)
💥💥生成决策树:
💌💌💌ID3算法实例
💨💨1.使用sklearn的决策树算法对葡萄酒数据集进行分类,要求:
(1)划分训练集和测试集(测试集占20%)
(2)对测试集的预测类别标签和真实标签进行对比
(3)输出分类的准确率
(4)调整参数比较不同算法(ID3, CART)的分类效果。
🕳🕳2. 利用给定ID3算法,画出下列训练集的决策树。
🍇🍇🍇1.葡萄酒分类
🚲🚲🚲(1)划分训练集和测试集(测试集占20%)
test_size等于几就是测试集占比
x_train, x_test, y_train, y_test = train_test_split(
X, Y, test_size=0.2, random_state=0)
🚓🚓(2)对测试集的预测类别标签和真实标签进行对比
预测类别标签
y_predict = clf.predict(x_test)
对比
pd.concat([pd.DataFrame(x_test), pd.DataFrame(y_test), pd.DataFrame(y_predict)], axis=1)
🛹🛹(3)输出分类的准确率
clf.fit(x_train, y_train)
score = clf.score(x_test, y_test)
🏍🛵🏍(4)调整参数比较不同算法(ID3, CART)的分类效果。
采用ID3算法进行计算
clf = tree.DecisionTreeClassifier(criterion=“entropy”)
采用CART算法进行计算
clf = tree.DecisionTreeClassifier(criterion=“gini”)
🚀🚀🚀完整代码:
# 导入相关库
from sklearn.model_selection import train_test_split
from sklearn import tree
from sklearn.datasets import load_wine
import pandas as pd
# 导入数据集
wine = load_wine()
X = wine.data
Y = wine.target
features_name = wine.feature_names
print(features_name)
print(pd.concat([pd.DataFrame(X), pd.DataFrame(Y)], axis=1))
# 打印数据
# 划分数据集,数据集划分为测试集占20%;
# 采用ID3算法进行计算
clf = tree.DecisionTreeClassifier(criterion="entropy")
# 采用CART算法进行计算
# clf = tree.DecisionTreeClassifier(criterion="gini")
# 获取模型
print('准确率为:', score)
# 对测试集的预测类别标签和真实标签进行对比
print(pd.concat([pd.DataFrame(x_test), pd.DataFrame(y_test), pd.DataFrame(y_predict)], axis=1))
🚀🚀🚀结果:
🛰🛰🌌2.只需修改数据集,标签集即可
🚩🚩部分代码:
        dataSet = [[1, 1, 1, 1, 'No'],
                   [1, 1, 1, 2,  'No'],
                   [2, 1, 1, 1,  'Yes'],
                   [3, 2, 1, 1,  'Yes'],
                   [3, 3, 2, 1,  'Yes'],
                   [3, 3, 2, 2,  'No'],
                   [2, 3, 2, 2,  'Yes'],
                   [1, 2, 1, 1,  'No'],
                   [1, 3, 2, 1,  'Yes'],
                   [3, 2, 2, 1,  'Yes'],
                   [1, 2, 2, 2,  'Yes'],
                   [2, 2, 1, 2,  'Yes'],
                   [2, 1, 2, 1,  'Yes'],
                   [3, 2, 1, 2,  'No'], ]
        features = ['outlook', 'temp', 'humidity', 'windy']
    print(id3.predict(id3.tree, {'outlook': 2, 'temp': 2, 'humidity': 1, 'windy': 1}))
🍽🍽🌼🌼结果:
评论(0
