MyBatis的Dao层实现方式
兮动人 发表于 2022/04/20 09:31:51 2022/04/20
【摘要】 1. 传统开发方式 2. 代理开发方式 2.1 代理开发方式介绍 2.2 编写UserMapper接口 2.3 测试代理方式 3. 知识小节 1. 传统开发方式编写UserDao接口public interface UserDao { List<User> findAll() throws IOException;}编写UserDaoImpl实现public class UserD...
1. 传统开发方式
  1. 编写UserDao接口
  1. 编写UserDaoImpl实现
public class UserDaoImpl implements UserDao {
	public List<User> findAll() throws IOException {
	    InputStream resourceAsStream = Resources.getResourceAsStream("SqlMapConfig.xml");
	    SqlSessionFactory sqlSessionFactory = new SqlSessionFactoryBuilder().build(resourceAsStream);
	    SqlSession sqlSession = sqlSessionFactory.openSession();
	    List<User> userList = sqlSession.selectList("userMapper.findAll");
	    sqlSession.close();
	    return userList;
  • SqlMapConfig.xml
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE configuration PUBLIC "-//mybatis.org//DTD Config 3.0//EN" "http://mybatis.org/dtd/mybatis-3-config.dtd">
<configuration>
    <!--加载外部properties-->
    <properties resource="jdbc.properties"></properties>
    <!--自定义别名-->
    <typeAliases>
        <typeAlias type="com.xdr630.domain.User" alias="user" />
    </typeAliases>
    <!--数据源的环境-->
    <environments default="development">
        <environment id="development">
            <transactionManager type="JDBC"></transactionManager>
            <dataSource type="POOLED">
                <property name="driver" value="${jdbc.driver}"/>
                <property name="url" value="${jdbc.url}"/>
                <property name="username" value="${jdbc.username}"/>
                <property name="password" value="${jdbc.password}"/>
            </dataSource>
        </environment>
    </environments>
    <!--加载配置映射文件-->
    <mappers>
        <mapper resource="com/xdr630/mapper/UserMapper.xml"></mapper>
    </mappers>
</configuration>
  • jdbc.properties
jdbc.driver=com.mysql.jdbc.Driver
jdbc.url=jdbc:mysql://localhost:3306/test
jdbc.username=root
jdbc.password=1234
  • UserMapper.xml
<!DOCTYPE mapper PUBLIC "-//mybatis.org//DTD Config 3.0//EN" "http://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="userMapper">
<!--查询操作-->
    <select id="findAll" resultType="com.xdr630.domain.User">
        select * from user
    </select>
</mapper>
  1. 测试传统方式
@Test
public void testTraditionDao() throws IOException {
	// 创建 Dao 层对象
    UserDao userDao = new UserDaoImpl();
    List<User> all = userDao.findAll();
    System.out.println(all);
2. 代理开发方式
2.1 代理开发方式介绍
  • 采用 Mybatis 的代理开发方式实现 DAO 层的开发,这种方式是进入企业的主流。
  • Mapper 接口开发方法只需要程序员编写Mapper 接口(相当于Dao 接口),由Mybatis 框架根据接口定义创建接口的动态代理对象,代理对象的方法体同上边Dao接口实现类方法。
  • Mapper 接口开发需要遵循以下规范:
1、 Mapper.xml文件中的namespace与mapper接口的全限定名相同
2、 Mapper接口方法名和Mapper.xml中定义的每个statement的id相同
3、 Mapper接口方法的输入参数类型和Mapper.xml中定义的每个sql的parameterType的类型相同
4、 Mapper接口方法的输出参数类型和Mapper.xml中定义的每个sql的resultType的类型相同
2.2 编写UserMapper接口
2.3 测试代理方式
@Test
public void testProxyDao() throws IOException {
    //获得MyBatis框架生成的UserMapper接口的实现类
    UserMapper userMapper = sqlSession.getMapper(UserMapper.class);
    User user = userMapper.findById(1);
    System.out.println(user);
    sqlSession.close();
  • 有输入参数的情况,查询 id
3. 知识小节
MyBatis的Dao层实现的两种方式:
  • 手动对Dao进行实现:传统开发方式
  • 代理方式对Dao进行实现:
