JavaScript Canvas实现复杂酷炫的爱心表白用
芝士味的椒盐 发表于 2022/04/18 21:28:51 2022/04/18
【摘要】 👨🏻‍🎓博主介绍:大家好,我是芝士味的椒盐,一名在校大学生,热爱分享知识,很高兴在这里认识大家🌟🌈擅长领域:Java、大数据、运维、电子🙏🏻如果本文章各位小伙伴们有帮助的话,🍭关注+👍🏻点赞+🗣评论+📦收藏,相应的有空了我也会回访,互助!!!🤝另本人水平有限,旨在创作简单易懂的文章,在文章描述时如有错,恳请各位大佬指正,在此感谢!!!@[TOC] 浏览器动态演示 源...
@[TOC]
浏览器动态演示
源码
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<title>酷炫爱心表白</title>
<style>
body {
  background-color: #000;
  margin: 0;
  overflow: hidden;
  background-repeat: no-repeat;
}</style>
</head>
<body>
<canvas id="canvas" width="1400" height="600"></canvas>
<script>
var canvas = document.getElementById("canvas");
canvas.width = window.innerWidth;
canvas.height = window.innerHeight;
// Initialize the GL context
var gl = canvas.getContext('webgl');
if(!gl){
  console.error("Unable to initialize WebGL.");
//Time
var time = 0.0;
//************** Shader sources **************
var vertexSource = `
attribute vec2 position;
void main() {
	gl_Position = vec4(position, 0.0, 1.0);
var fragmentSource = `
precision highp float;
uniform float width;
uniform float height;
vec2 resolution = vec2(width, height);
uniform float time;
#define POINT_COUNT 8
vec2 points[POINT_COUNT];
const float speed = -0.5;
const float len = 0.25;
float intensity = 1.3;
float radius = 0.008;
//https://www.shadertoy.com/view/MlKcDD
//Signed distance to a quadratic bezier
float sdBezier(vec2 pos, vec2 A, vec2 B, vec2 C){
	vec2 a = B - A;
	vec2 b = A - 2.0*B + C;
	vec2 c = a * 2.0;
	vec2 d = A - pos;
	float kk = 1.0 / dot(b,b);
	float kx = kk * dot(a,b);
	float ky = kk * (2.0*dot(a,a)+dot(d,b)) / 3.0;
	float kz = kk * dot(d,a);
	float res = 0.0;
	float p = ky - kx*kx;
	float p3 = p*p*p;
	float q = kx*(2.0*kx*kx - 3.0*ky) + kz;
	float h = q*q + 4.0*p3;
	if(h >= 0.0){
		h = sqrt(h);
		vec2 x = (vec2(h, -h) - q) / 2.0;
		vec2 uv = sign(x)*pow(abs(x), vec2(1.0/3.0));
		float t = uv.x + uv.y - kx;
		t = clamp( t, 0.0, 1.0 );
		// 1 root
		vec2 qos = d + (c + b*t)*t;
		res = length(qos);
	}else{
		float z = sqrt(-p);
		float v = acos( q/(p*z*2.0) ) / 3.0;
		float m = cos(v);
		float n = sin(v)*1.732050808;
		vec3 t = vec3(m + m, -n - m, n - m) * z - kx;
		// 3 roots
		vec2 qos = d + (c + b*t.x)*t.x;
		float dis = dot(qos,qos);
		res = dis;
		qos = d + (c + b*t.y)*t.y;
		dis = dot(qos,qos);
		res = min(res,dis);
		qos = d + (c + b*t.z)*t.z;
		dis = dot(qos,qos);
		res = min(res,dis);
		res = sqrt( res );
	return res;
//http://mathworld.wolfram.com/HeartCurve.html
vec2 getHeartPosition(float t){
	return vec2(16.0 * sin(t) * sin(t) * sin(t),
							-(13.0 * cos(t) - 5.0 * cos(2.0*t)
							- 2.0 * cos(3.0*t) - cos(4.0*t)));
//https://www.shadertoy.com/view/3s3GDn
float getGlow(float dist, float radius, float intensity){
	return pow(radius/dist, intensity);
float getSegment(float t, vec2 pos, float offset, float scale){
	for(int i = 0; i < POINT_COUNT; i++){
		points[i] = getHeartPosition(offset + float(i)*len + fract(speed * t) * 6.28);
	vec2 c = (points[0] + points[1]) / 2.0;
	vec2 c_prev;
	float dist = 10000.0;
	for(int i = 0; i < POINT_COUNT-1; i++){
		//https://tinyurl.com/y2htbwkm
		c_prev = c;
		c = (points[i] + points[i+1]) / 2.0;
		dist = min(dist, sdBezier(pos, scale * c_prev, scale * points[i], scale * c));
	return max(0.0, dist);
void main(){
	vec2 uv = gl_FragCoord.xy/resolution.xy;
	float widthHeightRatio = resolution.x/resolution.y;
	vec2 centre = vec2(0.5, 0.5);
	vec2 pos = centre - uv;
	pos.y /= widthHeightRatio;
	//Shift upwards to centre heart
	pos.y += 0.02;
	float scale = 0.000015 * height;
	float t = time;
	//Get first segment
  float dist = getSegment(t, pos, 0.0, scale);
  float glow = getGlow(dist, radius, intensity);
  vec3 col = vec3(0.0);
	//White core
  col += 10.0*vec3(smoothstep(0.003, 0.001, dist));
  //Pink glow
  col += glow * vec3(1.0,0.05,0.3);
  //Get second segment
  dist = getSegment(t, pos, 3.4, scale);
  //White core
  //Blue glow
  col += glow * vec3(0.1,0.4,1.0);
	//Tone mapping
	col = 1.0 - exp(-col);
	//Gamma
	col = pow(col, vec3(0.4545));
	//Output to screen
 	gl_FragColor = vec4(col,1.0);
//************** Utility functions **************
window.addEventListener('resize', onWindowResize, false);
function onWindowResize(){
	gl.viewport(0, 0, canvas.width, canvas.height);
  gl.uniform1f(widthHandle, window.innerWidth);
  gl.uniform1f(heightHandle, window.innerHeight);
//Compile shader and combine with source
function compileShader(shaderSource, shaderType){
  var shader = gl.createShader(shaderType);
  gl.shaderSource(shader, shaderSource);
  gl.compileShader(shader);
  if(!gl.getShaderParameter(shader, gl.COMPILE_STATUS)){
  	throw "Shader compile failed with: " + gl.getShaderInfoLog(shader);
  return shader;
//From https://codepen.io/jlfwong/pen/GqmroZ
//Utility to complain loudly if we fail to find the attribute/uniform
function getAttribLocation(program, name) {
  var attributeLocation = gl.getAttribLocation(program, name);
  if (attributeLocation === -1) {
  	throw 'Cannot find attribute ' + name + '.';
  return attributeLocation;
function getUniformLocation(program, name) {
  var attributeLocation = gl.getUniformLocation(program, name);
  	throw 'Cannot find uniform ' + name + '.';
//************** Create shaders **************
//Create vertex and fragment shaders
var vertexShader = compileShader(vertexSource, gl.VERTEX_SHADER);
var fragmentShader = compileShader(fragmentSource, gl.FRAGMENT_SHADER);
//Create shader programs
var program = gl.createProgram();
gl.attachShader(program, vertexShader);
gl.attachShader(program, fragmentShader);
gl.linkProgram(program);
gl.useProgram(program);
//Set up rectangle covering entire canvas
var vertexData = new Float32Array([
  -1.0,  1.0, 	// top left
  -1.0, -1.0, 	// bottom left
   1.0,  1.0, 	// top right
   1.0, -1.0, 	// bottom right
//Create vertex buffer
var vertexDataBuffer = gl.createBuffer();
gl.bindBuffer(gl.ARRAY_BUFFER, vertexDataBuffer);
gl.bufferData(gl.ARRAY_BUFFER, vertexData, gl.STATIC_DRAW);
// Layout of our data in the vertex buffer
var positionHandle = getAttribLocation(program, 'position');
gl.enableVertexAttribArray(positionHandle);
gl.vertexAttribPointer(positionHandle,
  2, 				// position is a vec2 (2 values per component)
  gl.FLOAT, // each component is a float
  false, 		// don't normalize values
  2 * 4, 		// two 4 byte float components per vertex (32 bit float is 4 bytes)
  0 				// how many bytes inside the buffer to start from
//Set uniform handle
var timeHandle = getUniformLocation(program, 'time');
var widthHandle = getUniformLocation(program, 'width');
var heightHandle = getUniformLocation(program, 'height');
var lastFrame = Date.now();
var thisFrame;
function draw(){
  //Update time
	thisFrame = Date.now();
  time += (thisFrame - lastFrame)/1000;
	lastFrame = thisFrame;
	//Send uniforms to program
  gl.uniform1f(timeHandle, time);
  //Draw a triangle strip connecting vertices 0-4
  gl.drawArrays(gl.TRIANGLE_STRIP, 0, 4);
  requestAnimationFrame(draw);
draw();
</script>
</body>
</html>
