SpringBoot启动错误:Error starting ApplicationContext.
小小谢先生 发表于 2022/04/16 01:47:46 2022/04/16
【摘要】 Error starting ApplicationContext. To display the auto-configuration report re-run your application with 'debug' enabled.2017-11-16 15:32:12.994 ERROR 2668 --- [ ...
  1. Error starting ApplicationContext. To display the auto-configuration report re-run your application with 'debug' enabled.
  2. 2017-11-16 15:32:12.994 ERROR 2668 --- [ main] o.s.b.d.LoggingFailureAnalysisReporter :
  3. ***************************
  4. APPLICATION FAILED TO START
  5. ***************************
  6. Description:
  7. Cannot determine embedded database driver class for database type NONE
  8. Action:
  9. If you want an embedded database please put a supported one on the classpath. If you have database settings to be loaded from a particular profile you may need to active it (no profiles are currently active).
原因是:springboot启动时会自动注入数据源和配置jpa
解决:在@SpringBootApplication中排除其注入
@SpringBootApplication(exclude={DataSourceAutoConfiguration.class,HibernateJpaAutoConfiguration.class})
  1. //@SpringBootApplication
  2. @SpringBootApplication(exclude={DataSourceAutoConfiguration.class,HibernateJpaAutoConfiguration.class})
  3. public class CreditApplication {
  4. public static void main(String[] args) {
  5. SpringApplication.run(CreditApplication.class, args);
  6. }
  7. }
加上如上配置即可。
文章来源: blog.csdn.net,作者:小小谢先生,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/xiewenrui1996/article/details/116398452
