Stanford 机器学习练习 Part 2 Logistics Regression
xindoo 发表于 2022/04/16 01:58:18 2022/04/16
【摘要】 以下是我学习Andrew Ng machine learning 课程时logistic regression的相关代码,仅作为参考,因为是初学,暂时没办法做出总结。 sigmoid.m function g = sigmoid(z) %SIGMOID Compute sigmoid functoon % J = SIGMO...
sigmoid.m
%   J = SIGMOID(z) computes the sigmoid of z.
% You need to return the following variables correctly
g = zeros(size(z));
% ====================== YOUR CODE HERE ======================
% Instructions: Compute the sigmoid of each value of z (z can be a matrix,
%               vector or scalar).
g = (1 + e.^(-z)).^(-1);
end
function p = predict(theta, X)
%PREDICT Predict whether the label is 0 or 1 using learned logistic
%regression parameters theta
%   p = PREDICT(theta, X) computes the predictions for X using a
%   threshold at 0.5 (i.e., if sigmoid(theta'*x) >= 0.5, predict 1)
m = size(X, 1); % Number of training examples
p = zeros(m, 1);
% Instructions: Complete the following code to make predictions using
%               your learned logistic regression parameters.
%               You should set p to a vector of 0's and 1's
val = sigmoid(X*theta);
for i=1:m
   if val(i)>0.5
       p(i) = 1;
   else
       p(i) = 0;
   end
end
function out = mapFeature(X1, X2)
% MAPFEATURE Feature mapping function to polynomial features
%   MAPFEATURE(X1, X2) maps the two input features
%   to quadratic features used in the regularization exercise.
%   Returns a new feature array with more features, comprising of
%   X1, X2, X1.^2, X2.^2, X1*X2, X1*X2.^2, etc..
%   Inputs X1, X2 must be the same size
degree = 6;
out = ones(size(X1(:,1)));
for i = 1:degree
    for j = 0:i
        out(:, end+1) = (X1.^(i-j)).*(X2.^j);
    end
end
end
function [J, grad] = costFunction(theta, X, y)
%COSTFUNCTION Compute cost and gradient for logistic regression
%   J = COSTFUNCTION(theta, X, y) computes the cost of using theta as the
%   parameter for logistic regression and the gradient of the cost
%   w.r.t. to the parameters.
% Initialize some useful values
m = length(y); % number of training examples
J = 0;
grad = zeros(size(theta));
% Instructions: Compute the cost of a particular choice of theta.
%               You should set J to the cost.
%               Compute the partial derivatives and set grad to the partial
%               derivatives of the cost w.r.t. each parameter in theta
% Note: grad should have the same dimensions as theta
h = sigmoid(X*theta);
J = m^-1 * sum(((-1) * y.*log(h)).-((1- y).*log(1 - h)));
grad = m^-1 * ((h.-y)'*X)';
end
function [J, grad] = costFunctionReg(theta, X, y, lambda)
%COSTFUNCTIONREG Compute cost and gradient for logistic regression with regularization
%   J = COSTFUNCTIONREG(theta, X, y, lambda) computes the cost of using
%   theta as the parameter for regularized logistic regression and the
%   gradient of the cost w.r.t. to the parameters.
J = 0;
theta(1) = 0;
tmp = lambda/(2*m)*sum(theta.^2);
J = J + tmp;
grad = m^-1 * ((h.-y)'*X)' + lambda/m * theta;
end
% Create New Figure
figure; hold on;
% Instructions: Plot the positive and negative examples on a
%               2D plot, using the option 'k+' for the positive
%               examples and 'ko' for the negative examples.
pos = find(y==1); neg = find(y == 0);
% Plot Examples
plot(X(pos, 1), X(pos, 2), 'k+','LineWidth', 2, ...
'MarkerSize', 7);
plot(X(neg, 1), X(neg, 2), 'ko', 'MarkerFaceColor', 'y', ...
'MarkerSize', 7);
文章来源: xindoo.blog.csdn.net,作者:xindoo,版权归原作者所有,如需转载,请联系作者。
原文链接:xindoo.blog.csdn.net/article/details/38031869
