Leetcode 623. Add One Row to Tree
xindoo 发表于 2022/04/16 02:56:31 2022/04/16
【摘要】 题目链接:leetcode 623 Given the root of a binary tree, then value v and depth d, you need to add a r...
题目链接:leetcode 623
Given the root of a binary tree, then value v and depth d, you need to add a row of nodes with value v at the given depth d. The root node is at depth 1.
  题目很简单,在树的第d层加一层,值为v。递归增加一层就好了。代码如下
 * Definition for a binary tree node.
 * public class TreeNode {
 *     int val;
 *     TreeNode left;
 *     TreeNode right;
 *     TreeNode(int x) { val = x; }
public class Solution {
    public TreeNode addOneRow(TreeNode root, int v, int d) {
        if (null == root)
            return null;
        if (1 == d) {
            TreeNode left = new TreeNode(v);
            left.left = root;
            root = left;
        else if (2 == d) {
            TreeNode right = new TreeNode(v);
            left.left = root.left;
            right.right = root.right;
            root.left = left;
            root.right = right;
        else {
            addOneRow(root.left,  v, d-1);
            addOneRow(root.right, v, d-1);
        return root;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
文章来源: xindoo.blog.csdn.net,作者:xindoo,版权归原作者所有,如需转载,请联系作者。
原文链接:xindoo.blog.csdn.net/article/details/73743520
