Leetcode 74. Search a 2D Matrix
xindoo 发表于 2022/04/16 00:49:44 2022/04/16
【摘要】 题目链接:Search a 2D Matrix Write an efficient algorithm that searches for a value in an m x n matri...
Write an efficient algorithm that searches for a value in an m x n matrix. This matrix has the following properties:
* Integers in each row are sorted from left to right.
* The first integer of each row is greater than the last integer of the previous row.
  这道题很简单,为此专门写篇博客其实算博客凑数了。给你一个每一行每一列都是增序,且每一行第一个数都大于上一行末尾数的矩阵,让你判断某个数在这个矩阵中是否存在。
  假设矩阵是m*n,扫一遍的时间复杂度就是O(m*n),题目中给出的这么特殊的矩阵,时间复杂度可以降到O(m+n),具体代码如下,写的比较挫。
public class Solution {
    public boolean searchMatrix(int[][] matrix, int target) {
        if (matrix.length == 0)
            return false;
        int x = matrix.length;
        int y = matrix[0].length;
        int i = 0, j = 0;
        while (i < x && matrix[i][j] <= target) {
            i++;
        if (i > 0) i--;
        while (j < y) {
            if (j < y && matrix[i][j] == target)
                return true;
            j++;
        return false;
文章来源: xindoo.blog.csdn.net,作者:xindoo,版权归原作者所有,如需转载,请联系作者。
原文链接:xindoo.blog.csdn.net/article/details/51869982
