Leetcode 377. Combination Sum IV
xindoo 发表于 2022/04/16 01:00:11 2022/04/16
【摘要】 题目链接:Combination Sum IV Given an integer array with all positive numbers and no duplicates, find...
Given an integer array with all positive numbers and no duplicates, find the number of possible combinations that add up to a positive integer target.
  赤裸裸的完全背包,属于动态规划的范畴,大家有兴趣可以在网上搜索下其他资料。个人觉得动态规划还是比较难理解的,更难给别人讲清楚,所以这里我直接附上我的代码供大家参考。
public class Solution {
    public int combinationSum4(int[] nums, int target) {
        int[] dp = new int[target+1];
        dp[0] = 1;
        for (int i = 1; i <= target; i++) {
            for (int j = 0; j < nums.length; j++) {
                if (i >= nums[j]) {
                    dp[i] += dp[i-nums[j]];
        return dp[target];
文章来源: xindoo.blog.csdn.net,作者:xindoo,版权归原作者所有,如需转载,请联系作者。
原文链接:xindoo.blog.csdn.net/article/details/52049281
