从零开始学Pytorch(十八)之kaggle图像分类
小小谢先生 发表于 2022/04/16 01:59:39 2022/04/16
【摘要】 我们将运用在前面几节中学到的知识来参加Kaggle竞赛,该竞赛解决了CIFAR-10图像分类问题。比赛网址是https://www.kaggle.com/c/cifar-10. import numpy as npimport torchimport torch.nn as nnimport torch.optim as optimi...
  1. import numpy as np
  2. import torch
  3. import torch.nn as nn
  4. import torch.optim as optim
  5. import torchvision
  6. import torchvision.transforms as transforms
  7. import torch.nn.functional as F
  8. import torch.optim as optim
  9. from torchvision import datasets, transforms
  10. import os
  11. import time
获取和组织数据集
比赛数据分为训练集和测试集。训练集包含 50,000 图片。测试集包含 300,000 图片。两个数据集中的图像格式均为PNG,高度和宽度均为32像素,并具有三个颜色通道(RGB)。图像涵盖10个类别:飞机,汽车,鸟类,猫,鹿,狗,青蛙,马,船和卡车。 为了更容易上手,我们提供了上述数据集的小样本。“ train_tiny.zip”包含 80 训练样本,而“ test_tiny.zip”包含100个测试样本。它们的未压缩文件夹名称分别是“ train_tiny”和“ test_tiny”。
图像增强
  1. data_transform = transforms.Compose([
  2. transforms.Resize(40),
  3. transforms.RandomHorizontalFlip(),
  4. transforms.RandomCrop(32),
  5. transforms.ToTensor()
  6. ])
  7. trainset = torchvision.datasets.ImageFolder(root='/home/kesci/input/CIFAR102891/cifar-10/train'
  8. , transform=data_transform)
  9. data = [d[0].data.cpu().numpy() for d in trainset]
  10. # 图像增强
  11. transform_train = transforms.Compose([
  12. transforms.RandomCrop(32, padding=4), #先四周填充0,再把图像随机裁剪成32*32
  13. transforms.RandomHorizontalFlip(), #图像一半的概率翻转,一半的概率不翻转
  14. transforms.ToTensor(),
  15. transforms.Normalize((0.4731, 0.4822, 0.4465), (0.2212, 0.1994, 0.2010)), #R,G,B每层的归一化用到的均值和方差
  16. ])
  17. transform_test = transforms.Compose([
  18. transforms.ToTensor(),
  19. transforms.Normalize((0.4731, 0.4822, 0.4465), (0.2212, 0.1994, 0.2010)),
  20. ])
导入数据集
  1. train_dir = '/home/kesci/input/CIFAR102891/cifar-10/train'
  2. test_dir = '/home/kesci/input/CIFAR102891/cifar-10/test'
  3. trainset = torchvision.datasets.ImageFolder(root=train_dir, transform=transform_train)
  4. trainloader = torch.utils.data.DataLoader(trainset, batch_size=256, shuffle=True)
  5. testset = torchvision.datasets.ImageFolder(root=test_dir, transform=transform_test)
  6. testloader = torch.utils.data.DataLoader(testset, batch_size=256, shuffle=False)
  7. classes = ['airplane', 'automobile', 'bird', 'cat', 'deer', 'dog', 'forg', 'horse', 'ship', 'truck']
定义模型
ResNet-18网络结构:ResNet全名Residual Network残差网络。Kaiming He 的《Deep Residual Learning for Image Recognition》获得了CVPR最佳论文。他提出的深度残差网络在2015年可以说是洗刷了图像方面的各大比赛,以绝对优势取得了多个比赛的冠军。而且它在保证网络精度的前提下,将网络的深度达到了152层,后来又进一步加到1000的深度。
Image Name
Image Name
  1. class ResidualBlock(nn.Module): # 我们定义网络时一般是继承的torch.nn.Module创建新的子类
  2. def __init__(self, inchannel, outchannel, stride=1):
  3. super(ResidualBlock, self).__init__()
  4. #torch.nn.Sequential是一个Sequential容器,模块将按照构造函数中传递的顺序添加到模块中。
  5. self.left = nn.Sequential(
  6. nn.Conv2d(inchannel, outchannel, kernel_size=3, stride=stride, padding=1, bias=False),
  7. # 添加第一个卷积层,调用了nn里面的Conv2d()
  8. nn.BatchNorm2d(outchannel), # 进行数据的归一化处理
  9. nn.ReLU(inplace=True), # 修正线性单元,是一种人工神经网络中常用的激活函数
  10. nn.Conv2d(outchannel, outchannel, kernel_size=3, stride=1, padding=1, bias=False),
  11. nn.BatchNorm2d(outchannel)
  12. )
  13. self.shortcut = nn.Sequential()
  14. if stride != 1 or inchannel != outchannel:
  15. self.shortcut = nn.Sequential(
  16. nn.Conv2d(inchannel, outchannel, kernel_size=1, stride=stride, bias=False),
  17. nn.BatchNorm2d(outchannel)
  18. )
  19. # 便于之后的联合,要判断Y = self.left(X)的形状是否与X相同
  20. def forward(self, x): # 将两个模块的特征进行结合,并使用ReLU激活函数得到最终的特征。
  21. out = self.left(x)
  22. out += self.shortcut(x)
  23. out = F.relu(out)
  24. return out
  25. class ResNet(nn.Module):
  26. def __init__(self, ResidualBlock, num_classes=10):
  27. super(ResNet, self).__init__()
  28. self.inchannel = 64
  29. self.conv1 = nn.Sequential( # 用3个3x3的卷积核代替7x7的卷积核,减少模型参数
  30. nn.Conv2d(3, 64, kernel_size=3, stride=1, padding=1, bias=False),
  31. nn.BatchNorm2d(64),
  32. nn.ReLU(),
  33. )
  34. self.layer1 = self.make_layer(ResidualBlock, 64, 2, stride=1)
  35. self.layer2 = self.make_layer(ResidualBlock, 128, 2, stride=2)
  36. self.layer3 = self.make_layer(ResidualBlock, 256, 2, stride=2)
  37. self.layer4 = self.make_layer(ResidualBlock, 512, 2, stride=2)
  38. self.fc = nn.Linear(512, num_classes)
  39. def make_layer(self, block, channels, num_blocks, stride):
  40. strides = [stride] + [1] * (num_blocks - 1) #第一个ResidualBlock的步幅由make_layer的函数参数stride指定
  41. # ,后续的num_blocks-1个ResidualBlock步幅是1
  42. layers = []
  43. for stride in strides:
  44. layers.append(block(self.inchannel, channels, stride))
  45. self.inchannel = channels
  46. return nn.Sequential(*layers)
  47. def forward(self, x):
  48. out = self.conv1(x)
  49. out = self.layer1(out)
  50. out = self.layer2(out)
  51. out = self.layer3(out)
  52. out = self.layer4(out)
  53. out = F.avg_pool2d(out, 4)
  54. out = out.view(out.size(0), -1)
  55. out = self.fc(out)
  56. return out
  57. def ResNet18():
  58. return ResNet(ResidualBlock)
训练和测试
  1. # 定义是否使用GPU
  2. device = torch.device("cuda" if torch.cuda.is_available() else "cpu")
  3. # 超参数设置
  4. EPOCH = 20 #遍历数据集次数
  5. pre_epoch = 0 # 定义已经遍历数据集的次数
  6. LR = 0.1 #学习率
  7. # 模型定义-ResNet
  8. net = ResNet18().to(device)
  9. # 定义损失函数和优化方式
  10. criterion = nn.CrossEntropyLoss() #损失函数为交叉熵,多用于多分类问题
  11. optimizer = optim.SGD(net.parameters(), lr=LR, momentum=0.9, weight_decay=5e-4)
  12. #优化方式为mini-batch momentum-SGD,并采用L2正则化(权重衰减)
  13. # 训练
  14. if __name__ == "__main__":
  15. print("Start Training, Resnet-18!")
  16. num_iters = 0
  17. for epoch in range(pre_epoch, EPOCH):
  18. print('\nEpoch: %d' % (epoch + 1))
  19. net.train()
  20. sum_loss = 0.0
  21. correct = 0.0
  22. total = 0
  23. for i, data in enumerate(trainloader, 0):
  24. #用于将一个可遍历的数据对象(如列表、元组或字符串)组合为一个索引序列,同时列出数据和数据下标,
  25. #下标起始位置为0,返回 enumerate(枚举) 对象。
  26. num_iters += 1
  27. inputs, labels = data
  28. inputs, labels = inputs.to(device), labels.to(device)
  29. optimizer.zero_grad() # 清空梯度
  30. # forward + backward
  31. outputs = net(inputs)
  32. loss = criterion(outputs, labels)
  33. loss.backward()
  34. optimizer.step()
  35. sum_loss += loss.item() * labels.size(0)
  36. _, predicted = torch.max(outputs, 1) #选出每一列中最大的值作为预测结果
  37. total += labels.size(0)
  38. correct += (predicted == labels).sum().item()
  39. # 每20个batch打印一次loss和准确率
  40. if (i + 1) % 20 == 0:
  41. print('[epoch:%d, iter:%d] Loss: %.03f | Acc: %.3f%% '
  42. % (epoch + 1, num_iters, sum_loss / (i + 1), 100. * correct / total))
  43. print("Training Finished, TotalEPOCH=%d" % EPOCH)
文章来源: blog.csdn.net,作者:小小谢先生,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/xiewenrui1996/article/details/105131001
